Go to Post I would much rather educate the audience than dumb-down the game. - dlavery [more]
Unread 19-03-2015, 13:27
Technobots Technobots is offline
FRC #0743
Technobots is an unknown quantity at this point
Exclamation Activation Code for Driver Station Update
I'm confused!
I recently attended the NYC FRC Regional and was told that the driver station had to be updated. They gave me the update download and allowed me to continue using the current version of the driver station. Now that I have the download for the update, I cant activate it because there is no activation code.
Please help!
Unread 19-03-2015, 15:32
jimbo493's Avatar
jimbo493 jimbo493 is offline
Quasi Mentor
AKA: Jimmy
FRC #3357 (The COMETS)
Team Role: Electrical
Rookie Year: 2011
jimbo493 is on a distinguished road
Re: Activation Code for Driver Station Update
You use the same code you used for your original install at the start of the season that came in the KOP
Unread 19-03-2015, 15:44
Conor Ryan Conor Ryan is offline
I'm parking robot yacht club.
FRC #4571 (Robot Yacht Club)
Conor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond repute
I think you get 40 days before you have to activate it.
Unread 20-03-2015, 22:04
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
The activation should only be necessary if you want to show a camera feed on the default (LabVIEW) Dashboard.
If you installed the post-Kickoff update and activated it then, the previous license activation is supposed to be found automatically. Just leave the serial number blank.
If you need to view the camera and this is the first time you have updated the Driver Station this season, you will have to provide a LabVIEW serial number. There are two of them in the Spare Parts case if you can't find the one assigned to your team (it was printed on the LabVIEW envelope in the Kit of Parts). If you use LabVIEW for programming, your serial number can be found on the "About LabVIEW" dialog under the Help menu.
Unread 21-03-2015, 00:38
MrTechCenter's Avatar
MrTechCenter MrTechCenter is offline
INTENSITY
AKA: Harsharan "Harsh" Dhaliwal
FRC #2073 (Eagleforce)
Rookie Year: 2010
MrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant future
If you don't need the LabView Updatea and only the driver station updates, then only select the option to install the FRC Utilities Update. It will still ask for the serial number but you can just skip it.
2011 Sacramento Regional Finalists; 2011 MadTown Throwdown VIP Excellence in Engineering Award; 2012 Sacramento Regional Innovation in Control Award; 2012 Silicon Valley Regional Judges' Award; 2012 CalGames Autonomous Challenge Award; 2012 MadTown Throwdown Finalists; 2013 P0W3RH0U53 PWNAGE Gracios Professionalism Award; 2014 Central Valley Regional Innovation in Control; 2014 Sacramento Regional Innovation in Control; 2014 Curie Division Gracious Professionalism Award; 2015 Sacramento Regional Innovation in Control
