Go to Post The robots that rise to the top will not be the ones that do everything poorly, but the ones that are breathtaking at one thing. Be that robot. - DampRobot [more]
Thread Tools Rating: Thread Rating: 3 votes, 5.00 average. Display Modes
Unread 20-03-2015, 19:09
Hsifeulbhsifder Hsifeulbhsifder is offline
Programmer
AKA: Zaeem Mohamed
FRC #5428 (Breaking Bots)
Rookie Year: 2015
Hsifeulbhsifder is on a distinguished road
Trouble deploying code from new laptop
Our team had originally began deploying code via the classmate, but since have updated to another laptop, running Windows 7 with an i7 4700 processor. The laptop had worked wonderfully during actual competition and driving, but it did not allow me to deploy code, stating that there were 'Too many authentication failures". This also occurred with another laptop, which was a Mac-book. However, only with the classmate, did the code successfully deploy, so I'm wondering if it even is possible to use another laptop for building. It may have to do with the fact that I had changed the admin password on the roboRIO, but then again, it only affected the new laptops, and not the classmate. Any help would be appreciated. Thanks.
Unread 20-03-2015, 19:14
Jared's Avatar
Jared Jared is offline
Rookie Year: 2012
Jared has a reputation beyond reputeJared has a reputation beyond reputeJared has a reputation beyond reputeJared has a reputation beyond reputeJared has a reputation beyond reputeJared has a reputation beyond reputeJared has a reputation beyond reputeJared has a reputation beyond reputeJared has a reputation beyond reputeJared has a reputation beyond reputeJared has a reputation beyond repute
Re: Trouble deploying code from new laptop
It is likely because you changed the password on the roboRIO. Messing with these settings has caused problems for other teams, and I would really recommend changing it back. It'll only make it easier for others to help you when you get to competition - plus, if you forget the password, there's no easy way to change it without contacting NI.
I think you (or your team) changed settings on the classmate that use your new password but didn't make these changes on your new laptop or your macbook.
Unread 21-03-2015, 20:20
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
You should definitely remove the admin password. Having it there complicates things. Unfortunately, I don't think you will be able to do that without completely reimaging the roboRIO.
Unread 23-03-2015, 19:35
Programmer
AKA: Zaeem Mohamed
Rookie Year: 2015
Thanks for the help, but is there anyway to input the password into eclipse, or possibly the build files, so that it can deploy using the password, or is there an easier way of removing the password without having to re-flash the rio. Thanks.
Unread 23-03-2015, 23:14
Software Architect
You can put the password in the build preferences. You probably have already done that on the Classmate.
According to a couple of the Beta Test teams, you cannot remove the password without reloading the roboRIO image. The option to do so is not part of the BusyBox Linux shell.
Unread 24-03-2015, 01:02
plnyyanks's Avatar
plnyyanks plnyyanks is offline
Data wins arguments.
AKA: Phil Lopreiato
FRC #1124 (The ÜberBots), FRC #2900 (The Mighty Penguins)
Rookie Year: 2010
plnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond repute
I don't have access to a RIO to test with, but it seems possible to change a password with a config file and chpasswd. Although chpasswd isn't available in the busybox version on my phone (v1.23.1), so go figure...
Phil Lopreiato - "It's a hardware problem"
Team 1124 (2010 - 2013), Team 1418 (2014), Team 2900 (2016)
FRC Notebook The Blue Alliance for Android
Unread 24-03-2015, 09:06
Software Architect
Originally Posted by plnyyanks View Post
...it seems possible to change a password with a config file and chpasswd.
Changing a password is simple. Doing so is what caused the deployment failures described in the original post. Removing a password is not supported.
Unread 25-03-2015, 11:54
ozrien's Avatar
ozrien ozrien is offline
Omar Zrien
AKA: Omar
ozrien has a reputation beyond reputeozrien has a reputation beyond reputeozrien has a reputation beyond reputeozrien has a reputation beyond reputeozrien has a reputation beyond reputeozrien has a reputation beyond reputeozrien has a reputation beyond reputeozrien has a reputation beyond reputeozrien has a reputation beyond reputeozrien has a reputation beyond reputeozrien has a reputation beyond repute
Is there a reason to change the Rio's password? It makes csa-ing more difficult and breaks code deployment. There is no upside, even if you hack the scripts to make it work
Unread 25-03-2015, 14:15
virtuald's Avatar
virtuald virtuald is offline
RobotPy Guy
AKA: Dustin Spicuzza
FRC #1418 (), FRC #1973, FRC #4796, FRC #6367 ()
virtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant future
I suspect that people are (correctly) conditioned to change passwords when there's an option to do so, particularly if the password is empty. It's "more secure", after all.
Of course, since you can anonymous FTP on the roborio with impunity, seems like it's a silly thing to do.
Maintainer of RobotPy - Python for FRC
Creator of pyfrc (Robot Simulator + utilities for Python) and pynetworktables/pynetworktables2js (NetworkTables for Python & Javascript)
2017 Season: Teams #1973, #4796, #6369
Team #1418 (remote mentor): Newton Quarterfinalists, 2016 Chesapeake District Champion, 2x Innovation in Control award, 2x district event winner
Team #1418: 2015 DC Regional Innovation In Control Award, #2 seed; 2014 VA Industrial Design Award; 2014 Finalists in DC & VA
Team #2423: 2012 & 2013 Boston Regional Innovation in Control Award
Resources: FIRSTWiki (relaunched!) | My Software Stuff
