Go to Post I like my eyeballs where they are ::safety:: - ,4lex S. [more]
Unread 23-03-2015, 14:42
glennword's Avatar
glennword glennword is offline
Resident Solidworks Guru
AKA: Glenn
FRC #4146 (Sabercat Robotics)
Team Role: Student
Rookie Year: 2012
glennword is a splendid one to beholdglennword is a splendid one to beholdglennword is a splendid one to beholdglennword is a splendid one to beholdglennword is a splendid one to beholdglennword is a splendid one to behold
Alternative to VIAIR compressors?
Here is a compressor I found on amazon, and it seems to satisfy all FIRST requirements for compressors.
Namely:
Nominal 12 Volt operating voltage
Nominal 30 liter per minute flow rate (~1.05 cfm)
Rated for 150 psi
Use of this compressor would be advantageous because of it's increased (but still legal) flow rate over the standard .88 cfm VIAIR compressors. Are there any inspectors out there who want to weigh in on the legality of this item? Or anyine else who has an opinion/idea/thought on the matter? It would be awesome to use it if we could use this. Thanks in advance
"Whether you think you can, or you think you can't--you're right."
-Henry Ford
