Go to Post Based on EXTENSIVE analysis of this image, I have concluded that we will have to use wires on our robots. I am certain of it. - theCADguy [more]
Unread 03-24-2015, 01:16 PM
DeeWBee DeeWBee is offline
FRC #3630
DeeWBee is an unknown quantity at this point
Updating Speed Using Ultrasonic Sensors
I am trying to create code that will slow down the robot as it gets closer to an object.
So far I have been able to write code that will stop the robot using an "if" statement with the conditional being the range as measured by sonar.
Code:
if(sonar.getRangeInches() < 40) {
             motor.stop();
However, when I modify the code such that I want to change the speed on approach, I get "robotDrive...output not updated enough". Any ideas? I've gotten the code to run by disabling the motor safety, but the sensitivity doesn't change at all.
Code:
            driveTrain.setSensitivity(0.5)
          elseif(sonar.....<30){
            driveTrain.setSensitivty(0.25)......
Unread 03-24-2015, 02:23 PM
otherguy's Avatar
otherguy otherguy is offline
sparkE
AKA: James
FRC #2168 (The Aluminum Falcons)
otherguy is a splendid one to beholdotherguy is a splendid one to beholdotherguy is a splendid one to beholdotherguy is a splendid one to beholdotherguy is a splendid one to beholdotherguy is a splendid one to beholdotherguy is a splendid one to behold
Re: Updating Speed Using Ultrasonic Sensors
* Put your robot on blocks so it wont drive.
* Add print statements to your code that lists the distance and motor output value for each loop itteration.
* Run your code while moving an object in front of the ultrasonic sensor.
There's got to be a case where your if/else logic doesn't result in the motor.drive() method being called.
Also, why are you using the setSensitiviy method, that affects turning not rate of travel.
See: http://team2168.org/javadoc/edu/wpi/...obotDrive.html
http://team2168.org
Last edited by otherguy : 03-24-2015 at 02:29 PM. Reason: question set sensitivity use
Unread 03-24-2015, 07:41 PM
JacobD's Avatar
JacobD JacobD is offline
AKA: Jacob
FRC #1672 (Mahwah Robo T-Birds)
Team Role: Leadership
Rookie Year: 2013
JacobD is an unknown quantity at this point
You can also do something like this. It starts a linear deceleration of the magnitude for mecanum drive. Just change out the numbers and the drive base and it will be fine.
Code:
    		double counter, startDecelDistance, stopDistance, differenceInDistance;
    		startDecelDistance = 20;
    		stopDistance = 40;
    		differenceInDistance = Math.abs(stopDistance-startDecelDistance);
    		while(sonar.getRangeInches() < startDecelDistance && sonar.getRangeInches() > stopDistance) {
    			counter= Math.abs(startDecelDistance - sonar.getRangeInches()) / differenceInDistance;
    			myRobot.mecanumDrivePolar(counter, 0, 0);
    			myRobot.mecanumDrivePolar(0,0,0);
Unread 03-29-2015, 02:43 PM
Djur's Avatar
Djur Djur is offline
WPILib
AKA: Sam Carlberg
Djur will become famous soon enough
If you're using CammandBased java, you should take a look at Gearsbot. It uses PID control to move to a certain distance away from an object and stop, which seems to be exactly what you're trying here.
WPILib dev (RobotBuilder, SmartDashboard, GRIP)
Unread 03-29-2015, 03:00 PM
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Rookie Year: 2013
You might be better off overriding the set method of your motor controller. If you do it there, you only have to do it once, and not worry about it anywhere else.
You may also want to only reduce the throttle if the applied voltage will push you towards the wall, but allow full throttle to push you away from the wall.
Unread 03-29-2015, 03:32 PM
engunneer's Avatar
engunneer engunneer is offline
Alumni turned Mentor
AKA: Branden Gunn
FRC #4761
Rookie Year: 1996
engunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond repute
In addition to everyone else's suggestions, the problem you are having is mostly from the structure of your if statement
Code:
remember that if an if statement returns true, the other elses aren't always evaluated
What you wrote
Code:
If it's <40, then do something
If it's not <40 but is <30, do something else (this can't happen!)
try instead building from one direction to the other
Code:
if(sonar.getRangeInches() >= 40)
            driveTrain.setSensitivity(1);
else if(sonar.....>= 30)
            driveTrain.setSensitivity(0.5);
else /*if(sonar.....< 30)*/
            driveTrain.setSensitivty(0.25);
you can also do it mathematically (y=mx+b)
Code:
driveTrain.setSensitivty(sonar.getRangeInches() / 40)
Student FRC23 (1996-1999), Mentor FRC246 (2000), Mentor FRC1318 (2007-2009), Mentor FRC93 (2011), Mentor FRC2151 (2012), Mentor FRC23 (2013), Mentor FRC4761 (2014-2017)
1998 - National Chairman's Award and Woodie Flowers Award (FRC23, Mike Bastoni ) | 2007 - PNW SF (488, 1595) | 2008 - Oregon RCA - Seattle #2 Seed, SF (488, 1696) | 2009 - Oregon #1 Seed, Winners (1983, 2635) - Seattle SF (945, 2865) - Galileo #2 Seed, SF (973, 25) | 2012 Midwest F (111, 71) | 2014 RIDE Winners (78, 125), Inspector - NEU #24, QF (3479, 3958) - NECMP #35 | 2015 Reading #11, SF (1058, 190), Inspector - RIDE #17, QF(4055, 5494), Inspector - NECMP #57 | 2016 Reading #4, SF (133, 4474), DCA, Inspector - Ride #22, SF (1735, 2067), Creativity, Inspector - NECMP #48, RCA - Archimedes
