Thread Tools |
Rating:
Display Modes |
Re: compressor is heating up to the point it blows hose
Are you running the VIAIR 90 C? We too had this issue, for the practice bot we switched the compressor to a Thomas 215 which is rated for 100% duty. We retained the 90C for the competition bot because it only needs to run in short bursts.
Check this last year thread http://www.chiefdelphi.com/forums/sh...d.php?t=129321 To my knowledge only these 3 compressors are 100% duty and FRC legal (at least according to 2014 rules)
See comparison list I compiled last year http://www.chiefdelphi.com/forums/at...1&d=1399302557 |
When they say "10% Duty Cycle", over what period of time is the 10%? 2.5 minutes on (for a match), and 22 minutes off?
You cannot call it 100% duty cycle. Besides being incorrect, it is very misleading. Comparing apples to apples, Viair 90C is 9% Duty cycle, just 1% less than Thomas 215. Which means that difference is marginal. Having even small fan cooling off compressor will make more impact than switching from Viair 90C to Thomas 215. Especially considering that Thomas 215 is 3 times more expensive that Viair 90C. If you can spare 4 pounds on you robot Viair 250C-IG is much better choice for less money. |
Personally the fact that Viair rates theirs at 9% makes me trust their specs more and the fact that Thomas rates theirs at 10% makes me suspicious of their specs. Fact is that real world numbers rarely come out so nice so Viair advertising 9% makes me think it is based on actual data determined by real world testing w/o rounding it up to 10% which would look better on the data sheet. |
#10
Moved all of our metal fittings down to the compressor for the heat sink value today. It fixed the problem with the added help of throwing more ballast to the back of the robot.
We did discover one trick that we did last year without knowing how it helped. We used a plastic elbow push fitting as the first non metal fitting last year. The extra heavier thermoset housing helped isolate some of the heat before it got to the tubing. |
#11
Thanks for all the replys. We learned a lot from going through them with the team.
#12
http://www.gd-thomas.com/workareasho....aspx?id=24872 |
#13
Art,
Can you tell us which compressor you are using? |
#14
Ah, I am not part of the team this year (few different reasons). So I am not using anything this year. Last year we were using only standard equipment that came in a tote (Viair 90C). But I did a research last year and if you remember you contributed to this thread http://www.chiefdelphi.com/forums/sh...d.php?t=129321. If i'd be still on the team I would insist to use VIAIR 250C-IG. It just make sense to me
![]() In this thread I stepped in to address the statement that Thomas 215 had 100% duty cycle, which I knew was incorrect. Last edited by ArtemusMaximus : 27-03-2015 at 16:43. |
#15
Art,
Sorry, I was speaking to the OP, Arthur Canada. There seems to be four compressors that everyone is using these days. The original Thomas 415 which is heavy but a great work horse. (Top and side ports are legal) The Viair 90C (The top port is not legal for FRC and the nickel plated check valve must be in place.) Viair 250 (The included stainless steel hose must be attached for FRC rules) Thomas 215 (the top and side ports are both legal to use and this compressor does not require an external check valve) The two small compressor run very hot as there is little thermal mass to absorb the heat generated. External cooling can be applied provided no modification to the compressor is made. (Do not use the screws to mount other devices.) |
