Go to Post teams that REALLY deserve to win will find ways to overcome a marginal officiating decision. Also, teams that REALLY deserved to win will try not to put themselves in that position. - Chris Hibner [more]
Unread 28-03-2015, 15:13
Sav01027's Avatar
Sav01027 Sav01027 is offline
AKA: Sav Sidorov
FRC #5897 (Apex Robotics)
Team Role: Leadership
Rookie Year: 2015
Sav01027 is an unknown quantity at this point
Autonomous Inconsistencies
We're coding an Autonomous mode in preparation for our next regional, and we're running into a very odd issue. We have our code set up so that it calls methods into the autonomous code (i.e. drive() would make it drive forward a set number of encoder rotations).
The issue that we're having is that when we enable the robot to run Auto, it acts unpredictably. Say, one time it would do it perfectly, but the next it would turn for a different number of degrees, or drive for a different distance, while running on identical code.
We have tried resetting the code and the roboRio, as well as checking the encoder values in Teleop. At least in Teleop, the encoders seem to be working fine.
Has anyone encountered this problem before, or has a solution for it?
Thanks
