| Thread Tools |
Rating:
Display Modes |
#16
Re: alliances selection
The difference between a stack of six and a stack of five is only 6 points, and if the stack of six contains no litter, there is no difference in point value at all.
3 stacks of 5 with 2 containers and litter: 36*2+5*2=82 2 stacks of 6 with container and litter: 42*2=84 Only a 2 point difference between the 2 strategies executed perfectly. Now, 3 stacks of 5 with 2 containers and litter at 97%: 82*.97= 79.5 2 stacks of 6 with containers and litter at 75%: 84*.75= 63 Therefore the more consistent stacks of 5 are generally the better option. However, the number of containers your alliance is able to utilize can also factor in to what height you should be building stacks at. If your alliance only has the three containers available to use, stacks of 6 better utilize your containers than stacks of 5. But not much better in the long run if the 6 stacks is less consistent. |
#17
-Ronnie |
#19
Finals match one we fought for the cans with the intention of keeping the first alliance to three capped attacks (one five and two sixes most likely) while we would be able to put up two capped sixes from 3641, a five from us, a four using DHDC'S totes and our container, and possibly another short one if we got lucky with time. We lost the race and therefore could only get two sixes and a five. Finals match two we kept the same plan and lost again, but the other alliance was only able to get three stacks up. Of course we had no idea they would "mess up" so we raced. Had we known that they would only get three, we should've taken the two uncontested containers and then we would likely have gotten another cap and won the match. We were definitely planning on using four containers with five being a stretch goal.
Also, our mechanism was very hard to line up and we hadn't yet practiced lining it up with operator controls instead of by hand. Last edited by Bryce Paputa : 01-04-2015 at 14:23. Reason: why we didn't go for the other ones in teleop |
#20
Three stacks of 5 with 2 RCs is better. It is only 2 points less than 2 stacks of 6 with 2 RCs.
#21
