FMS pre match disabled mode
Before a match starts, does the FMS give teleop disabled signals or auto disabled signals? We have some code running only in auto disabled, and it didn't run in our first practice match.
Re: FMS pre match disabled mode
Per the FMS whitepaper it goes
We had a related, possibly same issue at the GKC regional. We use LabVIEW and had coded it to read our autonomous mode from the dashboard when the robot mode was set to Auton Disabled. This worked flawlessly in the shop. At the regional though we just stayed in the default auton mode (do nothing). I asked the same question you just did and I was told that the robot mode is Teleop Disabled before Autonomous. We changed the code to also read the variable when in Teleop Disabled and never had that problem again.
If the field has been e-stopped while in autonomous mode and reset, it will begin in autonomous disabled, so be sure to test that your code will still work in this situation. Is there a way we can get the incorrect documentation corrected? |
There is a report errors form at the bottom.
This is terrible. Any insight into why this is the case?
#10
I'm not sure, but it appeared that the field was e-stopped in autonomous mode, the field failed to fully reset itself for the next match. Several of us had to restart our network adapters, or change our team numbers in our driver station back and forth. A robot on the opposite side even had to restart their robot to get communications to start working.
My guess is that the e-stop procedure wasn't fully tested/updated for this year, and still has a few little glitches. |
#11
My reported error was deleted from the page, and I have received no response to the email I provided. Do you know of another way to get in touch with the people who maintain that website?
#13
I believe the reported errors are private. Mine don't show up after I refresh, however they typically get incorporated within a few days. I noticed that it was updated today and removed the differentiation between teleop and autonomous disabled.
#14
Thanks - somehow I totally missed that the page had been changed when I went to go check.
