Go to Post "Things don't get done unless somebody does them." - CaptainKirby [more]
Unread 04-04-2015, 02:17 AM
rellimcire rellimcire is offline
Robolopes Software Advisor
AKA: Eric Miller
FRC #2339 (Robolopes)
rellimcire is an unknown quantity at this point
Implementing Own Sendable
Has anyone ever implemented their own Sendable object in Java and used with the Smartdashboard?
I have tried and failed miserably. The behavior I see when I try to use my implementation is that dashboard locks up and fails to receive any data. Restarting the dashboard and removing use of my class seems to fix the problem.
Attached is my SendablePosition class. A trival sample usage would the following in robotInit.
Code:
Smartdashboard.putData("test posit ", new SendablePosition(0,0));
A more useful example would be the following in teleopPeriodic.
Code:
Smartdashboard.putData("joystick posit ", new SendablePosition(driveStick.getX(), driveStick.getY()));
(where "driveStick" is the joystick controlling our drive)
Has anyone else seen this behavior? Has anyone else tried anything like this?
Unread 04-04-2015, 03:52 PM
Ben Wolsieffer Ben Wolsieffer is offline
Dartmouth 2020
AKA: lopsided98
FRC #2084 (Robots by the C)
Rookie Year: 2011
Ben Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud of
Re: Implementing Own Sendable
Have you created a Widget and type to view the position on the SmartDashboard? Without one, nothing should happen when you call "SmartDashboard.putData()", so I'm not sure why the SmartDashboard freezes.
We wrote a few Sendables for our robot, if you want to see examples:
WheelController
Robot Code (Sendable)
SmartDashboard Widget
SmartDashboard Type
ParameterCommand
SmartDashboard Type
Let me know if you want explanations of how the code works.
2016 North Shore District - Semifinalists and Excellence in Engineering Award
2015 Northeastern University District - Semifinalists and Creativity Award
2014 Granite State District - Semifinalists and Innovation in Control Award
2012 Boston Regional - Finalists
Unread 04-05-2015, 10:42 AM
AKA: Eric Miller
Thanks, very helpful. I missed entirely the need to create Smartdashboard widgets and types. Working my way through the docs and your code.
