Go to Post If you want to prove your worth, prove it by creation, not destruction. - DanL [more]
Unread 05-04-2015, 13:04
16skittles 16skittles is offline
Code Monkey
FRC #0648
Rookie Year: 2012
16skittles is an unknown quantity at this point
Deploying to cRIO in 2015?
This year, in the transition from the cRIO to the RoboRIO, FIRST also decided to switch development environments from the Eclipse fork WindRiver to just plain Eclipse. WindRiver was proprietary, and licensed to teams like us on a year-to-year basis.
I have plans to build a practice/teaching robot and we don't have any spare RoboRIOs lying around, so unless we put in a fairly large fundraising push a cRIO would be the obvious choice. I also have things to maintain on old robots based on the cRIO. The problem is, WindRiver's license is now expired and I can't deploy to the cRIO. Is there a way to manually deploy without WindRiver? I can still compile the program alright, it's just when I go to deploy that it complains about licensing.
Unread 06-04-2015, 13:29
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
Rookie Year: 1997
jhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond repute
Re: Deploying to cRIO in 2015?
http://www.chiefdelphi.com/forums/sh...d.php?t=133952
