Go to Post It’s not that we don’t have the time to teach first principals; it’s more that we (FIRST) don’t need to. - Jack Jones [more]
Unread 06-04-2015, 16:59
kiettyyyy's Avatar
kiettyyyy kiettyyyy is offline
FRC #1538 (The Holy Cows)
kiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond repute
Send a message via AIM to kiettyyyy
Re: USB ports going away during match
Originally Posted by MrForbes View Post
Actually one of the controllers was dropping, and the other stayed "lit up" on the DS display. And we changed the dropping controller with another one during one of the last matches, and the problem persisted, with no apparent change.
We can look at power settings, but I'm a bit confused why something like that would make the USB port come and go several times during a match, while the control is being used continuously? Although I do understand that Windows works in strange and mysterious ways.
I wonder if this is the advanced setting? btw this is on my desktop, which also runs Windows 7. I could probably end global climate change by leaving the setting as is, rather than allowing the pesky USB hub to run all the time!
Jim, this is the setting that you'd be looking for.
-Kiet Chau
2004-2008 - Software Developer/Driver on Team #968
2008-2011 - Software Developer/Coach/Mentor/"Engineer" on Team #968
2011-Present - Mentor & Engineer on Team #1538
www.team1538.com
Unread 06-04-2015, 17:05
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Thanks for all the suggestions, everyone!
We have several things to check. We have not been plugging in the DS laptop charger during matches, it's been running on battery all the time.
I don't have the laptop here, hopefully it made it home on the bus Saturday night, and I can check it in an hour or so when I drop off the robot at school.
Unread 06-04-2015, 19:16
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Failing to take advantage of the provided power at the field is not a good idea. It's too easy for Windows to kick in power-saving features if you're not plugged in. And if you do successfully disable them all, you're going to run down the battery much faster than "normal".
Unread 07-04-2015, 10:10
billbo911's Avatar
billbo911 billbo911 is offline
I prefer you give a perfect effort.
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
billbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond repute
Hi Jim,
Here is something that most likely was not the cause of the issues you were experiencing, but definitely should be considered when you are taking steps to make your DS 's performance stable and reliable.
As an FTAA twice this year, I saw several teams have issues if they had not "Locked" the location of their controllers in the DS software. When not locked, the controllers can show up in different order and locations in the DS. When your controls "go away" it is likely they will not return to where you want them if they are not locked. A locked device will always show up in the same position, regardless of which USB port it is plugged into, nor what order the device(s) are detected, as long as you are not using two identical devices.
Here are the details of the locking process from this document.
Re-Arranging and Locking Devices
The 2015 Driver Station has the capability of "locking" a USB device into a specific slot. This is done automatically if the device is dragged to a new position and can also be triggered by double clicking on the device. "Locked" devices will show up with an underline under the device. A locked device will reserve it's slot even when the device is not connected to the computer (shown as grayed out and underlined). Devices can be unlocked (and unconnected devices removed) by double clicking on the entry.
Note: If you have two or more of the same device, they should maintain their position as long as all devices remain plugged into the computer in the same ports they were locked in. If you switch the ports of two identical devices the lock should follow the port, not the device. If you re-arrange the ports (take one device and plug it into a new port instead of swapping) the behavior is not determinate (the devices may swap slots). If you unplug one or more of the set of devices, the positions of the others may move, they should return to the proper locked slots when all devices are reconnected.
Example: The image above (see attachment) shows 4 devices:
A Locked "Logitech Attack 3" joystick. This device will stay in this position unless dragged somewhere else or unlocked
An unlocked "Logitech Extreme 3D" joystick
An unlocked "Gamepad F310 (Controller)" which is a Logitech F310 gamepad
A Locked, but disconnected "MadCatz GamePad (Controller)" which is a MadCatz Xbox 360 Controller
In this example, unplugging the Logitech Extreme 3D joystick will result in the F310 Gamepad moving up to slot 1. Plugging in the MadCatz Gamepad (even if the devices in Slots 1 and 2 are removed and those slots are empty) will result in it occupying Slot 3.
CalGames 2009 Autonomous Champion Award winner
Sacramento 2010 Creativity in Design winner, Sacramento 2010 Quarter finalist
2011 Sacramento Finalist, 2011 Madtown Engineering Inspiration Award.
2012 Sacramento Semi-Finals, 2012 Sacramento Innovation in Control Award, 2012 SVR Judges Award.
2012 CalGames Autonomous Challenge Award winner ($$$).
2014 2X Rockwell Automation: Innovation in Control Award (CVR and SAC). Curie Division Gracious Professionalism Award.
2014 Capital City Classic Winner AND Runner Up. Madtown Throwdown: Runner up.
2015 Innovation in Control Award, Sacramento.
2016 Chezy Champs Finalist, 2016 MTTD Finalist
Unread 07-04-2015, 10:31
MrForbes's Avatar
AKA: Jim
Thanks, I think the devices were locked, because when the controller dropped out, it was still shown in the #1 slot in gray.
Unread 07-04-2015, 11:22
billbo911's Avatar
Excellent!
That confirms two things at least.
1) It was locked.
2) Winders no longer saw the device.
Now, what the root cause of it going away is still the main focus.
All the advice here should get you to a solid answer. From the timing of when and how the failures occurred, it doesn't sound like a physical problem like a flakey connection or wiring. At least not to me
Unread 06-04-2015, 20:47
plnyyanks's Avatar
plnyyanks plnyyanks is offline
Data wins arguments.
AKA: Phil Lopreiato
FRC #1124 (The ÜberBots), FRC #2900 (The Mighty Penguins)
Rookie Year: 2010
plnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond repute
Some laptops also have "sleep and charge" ports, which stay powered even when the computer sleeps (and I've seen some teams' DS laptops go to sleep during a match). One joystick being plugged into one of these ports and the other not could cause this when one controller stays powered when the computer sleeps.
Again, a closer examination of the laptop's power settings should help.
Phil Lopreiato - "It's a hardware problem"
Team 1124 (2010 - 2013), Team 1418 (2014), Team 2900 (2016)
FRC Notebook The Blue Alliance for Android
Unread 06-04-2015, 21:11
MrForbes's Avatar
AKA: Jim
Thanks again for all the info!
We looked at the laptop, and it has a few issues that are probably causing the problem. The advanced power management setting was set to allow it to turn off the USB hub. There also might be a driver issue, we will work on reinstalling the drivers. And we never got around to making a console to put the laptop, controllers, and charger on, so it was just too inconvenient to carry everything....hence no charger on the field....lesson learned! In past years, we've had the charger with the laptop, it's just something that got overlooked this time.
I think we'll get it straightened out for Champs. And definitely by AIA.
Unread 07-04-2015, 00:50
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
FRC #1296 (Full Metal Jackets)
wireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond repute
Send a message via AIM to wireties
USB connectors (and all others) are rated for a finite number of insertion cycles. In FIRST we tend to connect/disconnect more often that a normal user. If your laptops are 3 years old the connectors might be getting intermittent? If it has not happened yet, it will at some point.
Fast, cheap or working - pick any two!
Unread 07-04-2015, 01:22
nixiebunny nixiebunny is offline
AKA: David Forbes
FRC #4183 (Bit Buckets)
Rookie Year: 2011
nixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond repute
Whatever you do, don't try to read the USB specification for help. The latest one has 534 pages just for power!
--David Forbes
Mentor, Bit Buckets team 4183. Assistant cat herder and dispenser of legendary tales.
Need a Nixie watch? Yes, you do. Ask me.
Unread 06-04-2015, 15:21
angelah angelah is offline
FRC #3547
angelah has a spectacular aura aboutangelah has a spectacular aura about
That's how we spent last year. This year we switched to joysticks because of that problem. A more extreme solution, but it worked for us.
