| Thread Tools |
Rating:
Display Modes |
Javascript Robots!
I develop full stack Node.JS professionally, and I've seen the power in Javascript. Would anyone be open to building a collaborative framework for the RoboRIO to code in Javascript?
Seems rather promising to me... |
Re: Javascript Robots!
And I thought this was going to be #teamjavascript
Oh thank you Kamen. |
It wouldn't be that hard if you built it on top of Java's Nashorn interpreter. Summer project?
RobotPy (the python port) is pure python this year, only interfacing to the robot at the HAL layer. If you're going to do this, I would highly recommend going that route instead of trying to write bindings for WPILib. Expect to spend 2 months of effort translating WPILib into Javascript if you want to do a full port. We did C++-based bindings for a number of years, but having everything be pure python (or js) means you can run the actual robot code on your laptop, which is great for testing + simulation. There's a lot you can learn by looking at how RobotPy is implemented -- and if you implement HAL the same way we did, then you can use our HTML/JS simulator interface (not quite ready, but almost there)! If you want to write a robot dashboard in HTML/JS, we've got that covered. |
It's not entirely implausible, we built our own version of java script to use in autonomous coding.
Interesting. Ill definitely look into the HAL interfacing, since Node is extremely capable.
By all means, go for it, but I wouldn't use it.
From: http://nodeguide.com/convincing_the_boss.html Quote:
That explains the 250ms lag spikes I've been seeing every once in a while. Any standard way to mitigate this?
#10
I'd be willing to help out, I write Node/JS every day (in addition to Java/Objective-C), the event'ed/streams Javascript model could be really useful for robot programing. |
#11
Yeah, I'm not concerned with Garbage Collection. It actually really helped with Recycle Rush this year (sorry .)Excellent John, I'd probably set this up as a collaboration-able repo, so I'll definitely contact you if this gets started. EDIT: Nobody caught the pun? ![]() Last edited by weaversam8 : 08-04-2015 at 19:55. Reason: Added pun-ch line. OH! There's another one! |
#12
Garbage collection generally occurs when Java decides it needs more memory for new allocations. Objects that are no longer referenced are eligible to be collected. If you feel as though the garbage collector is running too often, it is likely because you are allocating too many objects too frequently. For example, if you have a loop that creates a new instance of an object in every iteration, those objects can pile up quickly. Last edited by Bryan Herbst : 09-04-2015 at 09:44. |
#14
2) Use a specially-tuned "low latency" garbage collector implementation (you probably need to test that it actually works properly for your application's usage pattern though) 3) Avoid heap allocation (to the extent that you can - just running the required libraries may produce a considerable amount of garbage, you'd need to check this) You might also consider manually triggering a collection frequently so that less work is done each time it runs. For example, you could have it so that every time the robot got a packet from the driver station it would run an iteration of the control code and then do a GC. You would have to see how long the pause is to see if that would be acceptable. |
#15
I AM GAME! I would love to run a Node.js application on the roboRIO and use our DriverStation.js (Node-Webkit) DS with it. (once we get the 2015 protocol unearthed...).
