Thread Tools |
Rating:
Display Modes |
Re: Tote bot
There out of stock right now so they must be fairly popular.
Re: Tote bot
Update on the project, we have completed the inner frame. Tested it with 60lbs and the frame has absolutely no sagging. The parts have been chosen, two Andy mark pg27 motors in a staggered configuration, two victor 888, chain drive system, no tension system. Three wheeled design, two drive in the front (tank drive) one office chair swivel wheel in the back. The frame is made of tetrix metal parts.the battery will be mounted in front of the axle, pdp centered above the motors. Low speed gear ratio. Top speed 6-15 mph.
The only problems I have left to solve are finding the correct image for the CRio-II were using, and finding out how to ventilate the systems. And of course, fitting the control system into the box without having to jump on top to smash it in there lol. I'm going to rig the ventilation to shut off when the flaps are open (safety reasons, dam near got a knuckle torn off by a fan) Any help at all, would be greatly appreciated I will post a video of the tote bot Sneaking around the room. |
Re: Tote bot
Update to the project
We have chosen a chain driven mechanism with two Andy mark motors driving them in a tank drive system, with a Omni wheel in the back. Ventilation might be a problem seeing as the tote will be closed. We chose victor motor controllers for the drive motors. Using the old control system will take up a lot of space so space is limited for anything other than the core drive system. Possibly some LED lights or some gizmo to improve the ridiculousness of this robot I will post a photo tomorrow, as it sits the robot is just the tote, we laid the electronics out in the tote to see if it'll all fit. The wheel slots have been cut out of the tote. The sprockets need to be drilled out to accommodate a screw to connect to the motor shaft. The wheels are the old KOP white high grip small wheels. The Omni has yet to be chosen. The robot shouldn't reach too high of a speed overall. Both wheels will be on the same axle to save space, and each will have its own motor. |
Re: Tote bot
The tote has a fair amount of surface area. Heat will pass through the walls to the outside. The plastic is not going to be a good conductor of the heat but it may be good enough. You may want to install one of the large fans that comes in the KOP to circulate the air inside the tote. The more driving around you do, the more heat the Victors will dissipate. This is offset by the air flowing over the tote as you drive. Some of the smaller AC motor controllers (under 50hp) we sell at work get put into large, totally sealed boxes due to the dusty environment they are being used in. There are formulas for calculating the size of the box needed based on the heat generated by the motor controller, the surface area available to dissipate the heat and the ambient temperature. |
Re: Tote bot
Re: Tote bot
Depending on where the totebot will be driven, it can suck in a lot of dirt.
Re: Tote bot
Well, if it's a 120mm computer fan it probably wouldn't be to difficult to get a washable filter for the intake.
Re: Tote bot
Re: Tote bot
Maybe you can add a window motor and make the flaps on top open and close for added effect. |
#10
Re: Tote bot
Re: Tote bot
the large fans are very stupid loud, I wouldn't want to put one in a enclosed space like the tote bot, but I would be willing to use several small ones
#12
Re: Tote bot
Something popping out could be good, say a small version of your school mascot. Otherwise, maybe you can fit in a small single-shot T-shirt cannon powered with surgical tubing, for simplicity. |
