Go to Post Nah, I never crash or break anything... - Elgin Clock [more]
Unread 15-04-2015, 20:50
Sparkyshires Sparkyshires is offline
AKA: Michael Shires
FRC #0384 (Sparky)
Sparkyshires is an unknown quantity at this point
error with NavX MXP connected to the Serial Port
Hey guys, title pretty much says it all. About two weeks ago, we installed the new NavX MXP and set it up. We downloaded their code from their github repo and we're using that. The only problem is that I'm not sure that I'm using it properly. I'm no expert in using the serial port on the roboRIO, and I have a feeling that something somewhere is going wrong. Does anybody know where this error might be coming from? our code is at https://github.com/Sparky384/Team384Year2015
Code:
Error on line 115 of SerialPort.cpp: HAL - VISA: Resource Locked
	at /home/lvuser/FRCUserProgram() [0x23b4c]
	at /home/lvuser/FRCUserProgram() [0x1194c]
	at startRoutine(void*)
Thanks for your time! If you have any questions about the code feel free to ask them. All the relevant gyro calls are in the drivetrain subsystem file.
"Measure with a micrometer, mark with chalk, cut with an axe."
Unread 15-04-2015, 21:35
slibert slibert is offline
Software Mentor
AKA: Scott Libert
FRC #2465 (Kauaibots)
slibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud of
Re: error with NavX MXP connected to the Serial Port
Code:
Took a quick look at the code you've linked to. Looked around and couldn't find any code attempting to initialize the navX MXP. Looked in Subsystems\DriveTrain.cpp, but didn't see anything there except a Gyro instance.
Note that you need to use one of the classes in the navX MXP folder, not the Gyro class from the WPI Library (that only works w/the kit-of-parts gyro). See the example Robot.cpp file in the navX MXP folder for an example.
Perhaps the latest code is not checked in - or I'm looking in the wrong place. Can you please point me to the exact file and line number where the navX MXP initialization is occuring? Also, I didn't see a RobotMap.cpp file anywhere, though I did see RobotMap.h - maybe a sign not everything is checked in?
Unread 15-04-2015, 22:45
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
Code:
Code:
sPort = new SerialPort(57600,SerialPort::kMXP);
navX = new AHRS(sPort, 60);
imu = new IMU(sPort, 60);
You should choose either AHRS or IMU, not both.
It's in the gyro branch.
Unread 16-04-2015, 09:26
AKA: Michael Shires
FRC #0384 (Sparky)
Ok, thanks. Which one would you recommend? and if I delete the double initialization do you think that'll fix the error?
Unread 16-04-2015, 17:44
AKA: Michael Shires
FRC #0384 (Sparky)
Hey guys, it worked! I deleted the AHRS initialization and it worked. The only other thing is that there is this other error message that I wasn't seeing cause it was drowned out by the first. It is this:
Code:
Error on line 143 of Command.cpp: A pointer parameter to a method is NULL: subsystem
	at /home/lvuser/FRCUserProgram() [0x38884]
	at /home/lvuser/FRCUserProgram() [0x1b078]
	at /home/lvuser/FRCUserProgram() [0x17b34]
	at /home/lvuser/FRCUserProgram() [0x1f6f4]
	at /home/lvuser/FRCUserProgram() [0x16b78]
	at /home/lvuser/FRCUserProgram() [0x1fa88]
	at /home/lvuser/FRCUserProgram() [0x20ca8]
	at /home/lvuser/FRCUserProgram() [0x16acc]
	at __libc_start_main
Would you know what might be causing this?
