Go to Post They had a well made scouting form on the bottom was a check box with nothing next to it, when asked what the box was for they said. "Oh thats the jerk box" Since then one of our team goals is "Stay out of the jerk box" - Gary Stearns [more]
Unread 16-04-2015, 15:19
thatprogrammer's Avatar
thatprogrammer thatprogrammer is offline
AKA: Ahad Bawany
no team (None)
Rookie Year: 2014
thatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond repute
Need assistance finding bearing housing for thunderhex bearings.
My team needs to use a pillow block or something similar to hold a thunder hex bearing. We can't use the clamp on bearing block because it is much too big. An alternate that would still allow the use of a hex shaft would also work. Thanks.
Unread 16-04-2015, 15:23
Joe G.'s Avatar
Joe G. Joe G. is online now
Taking a few years (mostly) off
AKA: Josepher
no team (Formerly 1687, 5400)
Rookie Year: 2007
Joe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond repute
Send a message via AIM to Joe G.
Re: Need assistance finding bearing housing for thunderhex bearings.
The thunderhex bearing has the same outer diameter as the 1/2" round bearing. Any of the numerous housings designed for these bearings, including the VexPro versadrive clamp on bearing block or the versaframe side bearing mount, should work fine.
FIRST is not about doing what you can with what you know. It is about doing what you thought impossible, with what you were inspired to become.
2007-2010: Student, FRC 1687, Highlander Robotics
2012-2014: Technical Mentor, FRC 1687, Highlander Robotics
2015-2016: Lead Mentor, FRC 5400, Team WARP
2016-???: Volunteer and freelance mentor-for-hire
Unread 16-04-2015, 15:25
Bob Steele's Avatar
Bob Steele Bob Steele is online now
Professional Steamacrit Hunter
AKA: Bob Steele
FRC #1983 (Skunk Works Robotics)
Team Role: Coach
Bob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond repute
What do you wish to mount the bearing to? tubing? plate? block?
Simplest solution is to use the flanged bearing and make a plate that it presses into. Which thunderhex bearing do you have? radial or flanged?
You can hold the flanged bearing in by putting three small screws around the outside (tapped into the plate) if you have a load which would push it out of a simple hole. Usually they will hold pretty well.
You can also hold the bearing in by using shaft collars...
Raisbeck Aviation High School TEAM 1983 - Seattle, Washington
Las Vegas 07 WINNER w/ 1425/254...Seattle 08 WINNER w/ 2046/949.. Oregon 09 WINNER w/1318/2635..SEA 10 RCA ..Spokane 12 WINNER w/2122/4082 and RCA...Central Wa 13 WINNER w/1425/753..Seattle 13 WINNER w/948/492 & RCA ..Spokane 13 WINNER w/2471/4125.. Spokane 14 - DCA --Auburn 14 - WINNER w/1318/4960..District CMP 14 WINNER w/1318/2907, District CMA.. CMP 14 Newton Finalist w 971/341/3147 ... Auburn Mountainview 15 WINNER w/1318/3049 - Mt Vernon 15 WINNER w/1318/4654 - Philomath 15 WINNER w/955/847 -District CMP 15 WINNER w/955/2930 & District CMA -CMP Newton -Industrial Design Award
Unread 16-04-2015, 15:31
Sperkowsky's Avatar
Sperkowsky Sperkowsky is offline
Professional Multitasker
AKA: Samuel Perkowsky
FRC #2869 (Regal Eagles)
Team Role: Leadership
Rookie Year: 2014
Sperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond repute
If you have a 3d printer that's something that could be modeled and printed pretty easily
Unread 18-04-2015, 17:38
AKA: Ahad Bawany
no team (None)
Rookie Year: 2014
Thanks for the help, we're looking into maybe using it in a press-fit situation. 3d printing is an option, but we've had bad luck with it in the past.
