Go to Post Can we just get over this inane lawyering of the rules and get back to building robots? . - dlavery [more]
Unread 17-04-2015, 22:19
jman4747's Avatar
jman4747 jman4747 is offline
Just building robots
AKA: Josh
FRC #4080 (Team Reboot)
Team Role: CAD
Rookie Year: 2011
jman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond repute
Ultra massive repository of mechanical devises
I found this YouTube channel over a year ago while looking for animations of planetary gear drives. I wasn't ready for the 10+ different gear shifting mechanisms, 40+ different ratchets, maybe 20+ different one way clutches?
If you want examples of 5 different mixing machines or your inner Ether is calling and you just need to spend an hour looking at untold numbers of kinematic chains with several different versions of each than this is the place.
It is basically a channel consisting of well over 1,700 10-30 sec long Autodesk Inventor animations of various mechanical devises, and nothing else.
I picked out 4 that may be applicable to FRC provided you were actually able to fabricate them.
#1 Two-way anti-reverse transmission 1b: https://www.youtube.com/watch?v=5DBfEdX5Ow8
#2 Snap motion 16: https://www.youtube.com/watch?v=BwABcO1k2l0
#3 Ratchet mechanism 28 https://www.youtube.com/watch?v=drAELRHyHgI
#4 Spring toggle mechanism 5 https://www.youtube.com/watch?v=vYSJn0U0kXI
And three more I just can't pass up
#1 Speed control of spring motor: https://www.youtube.com/watch?v=ehjgr3AYKvM
#2 Synchronic toothed clutch 1: https://www.youtube.com/watch?v=On1vXQ_ATu4
#3 Slider-crank mechanism having a pause at both ends of stroke 3: https://www.youtube.com/watch?v=s0Lx-6c9JYk
No, not just one "Slider-crank mechanism having a pause at both ends of stroke" but the third... of how many?
PS: I DID NOT make any of these but I thought CD might like to see it.
Alumni, CAD Designer, machinist, and Mentor: FRC Team #4080
Mentor: Rookie FTC Team "EVE" #10458, FRC Team "Drewbotics" #5812
#banthebag
#RIBMEATS
#1620
