Go to Post That's right 10 years and this is the first time ever that the school wanted anything to do with the FIRST team. - RoteAugen [more]
Thread Tools Rating: Thread Rating: 10 votes, 5.00 average. Display Modes
Unread 19-04-2015, 17:07
Citrus Dad's Avatar
Citrus Dad Citrus Dad is offline
Business and Scouting Mentor
AKA: Richard McCann
FRC #1678 (Citrus Circuits)
Rookie Year: 2012
Citrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond repute
Re: 2015 Championship division simulated rankings
Originally Posted by Spoam View Post
We have all this data available here if anyone wants to use it. Click the download button to get a local copy in csv format. We'll run our own monte carlo analysis later today using various models and post it here, along with some regression analysis on which model gives the most accurate predictions, just for fun.
Wow, thanks!
Unread 19-04-2015, 17:21
forbes's Avatar
forbes forbes is offline
Software developer
AKA: Evan Forbes
FRC #3507 (Ubotics), 694 (StuyPulse)
Rookie Year: 2012
forbes is a splendid one to beholdforbes is a splendid one to beholdforbes is a splendid one to beholdforbes is a splendid one to beholdforbes is a splendid one to beholdforbes is a splendid one to beholdforbes is a splendid one to beholdforbes is a splendid one to behold
Just to verify: the "Highest OPR (no co-op)" column includes auto?
Unread 19-04-2015, 23:19
nuclearnerd's Avatar
nuclearnerd nuclearnerd is offline
Speaking for myself, not my team
AKA: Brendan Simons
FRC #5406 (Celt-X)
Rookie Year: 2014
nuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant future
Originally Posted by CVR View Post
I think a better method would be to use the following:
Red Score =
Red1_(toteOPR + binOPR + litterOPR)
+ Red2_(toteOPR + binOPR + litterOPR)
+ Red3_(toteOPR + binOPR + litterOPR)
+ MAX(Red1_autoOPR, Red2_autoOPR, Red3_autoOPR)
+ MAX(Red1_coopOPR, Red2_coopOPR, Red3_coopOPR)
I think that method, while slightly more complex, will give more accurate results.
There's an issue with this method that may skew predictions for alliances with more than one team that does a lot of co-op. Lets say:
R1 has a "platform OPR of 40, and a co-op OPR of 30
R2 has a "platform OPR of 40 and a co-op OPR of 28
R3 has OPRs of 0 for the sake of argument
By the above method, the red alliance would be predicted to score just 110 points, since we would use R1's co-op average, but not R2's. But if R2 can usually score 40 platform points *and do co-op most of the time*, surely they wouldn't put up their 40 and then spend the rest of the match twiddling their thumbs. They would use the time they normally use on co-op to score more platform points!
(There's also the issue of whether the opposing alliance has a high enough Co-op OPR to ensure co-op will be successful, but now we're getting really complicated.)
Unread 19-04-2015, 23:33
Louisiana Jones's Avatar
Louisiana Jones Louisiana Jones is offline
Jason Jones
AKA: Jason Jones
FRC #1806 (S.W.A.T.)
Team Role: Coach
Rookie Year: 2013
Louisiana Jones will become famous soon enoughLouisiana Jones will become famous soon enough
Is the max coopOPR used for the same event as the Max OPR? If not I see some problems where it may appear that teams score more than they really do, if they coop more at some events, and then stacked more at other events. They would be getting the max points from both.
Unread 20-04-2015, 00:48
Citrus Dad's Avatar
AKA: Richard McCann
Rookie Year: 2012
On the coop OPR I think you need to take a sum of the maxBlue(coopOPR,20)+maxRed(coopOPR,20) as the closest approximation and apply the total to both alliances.
And watching the regionals, the coop points increased with overall scores so that the max coop OPRs should be in an event close to the max OPR.
Unread 19-04-2015, 08:15
MechEng83's Avatar
MechEng83 MechEng83 is online now
Lead Mentor/Engineer
AKA: Mr. Cool
FRC #1741 (Red Alert)
Team Role: Coach
Rookie Year: 2011
MechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond repute
I had the exact same idea actually. The problem with the OPR residual, however, is that it gives you information about the accuracy of the regression with regard to each match, not each robot.
If you took the set of residuals from the matches a robot played in, it makes intuitive sense that that data should contain some level of information about that robot's deviation from their OPR. But is a data set of only 8-12 elements enough for this value to dominate the noise generated by their alliance partners' deviations (and therefore produce a meaningful standard deviation itself)? I dunno.
If some statistics wiz would like to chime in on this, I'd love to hear it.
Originally Posted by themccannman View Post
The problem with trying to use variation or standard deviation with OPR is that the number it spits out pretty much just tells you what their match schedule was like. OPR is already a calculation of how much an alliances score tends to change when certain teams are playing, calculating standard deviation for that basically just going backwards. OPR tries to determine how one robot affects an alliances score, where as SD (with unique alliances) would give you how each alliance affected that robots score.
Unfortunately it's not very useful unless you have actual scouted data for each team to use, in which case you can make much more accurate predictions about rankings. Our scouting system had a little less than an 80% success rate guessing the winners of each match in our division the last two years, and those games were very defense heavy. I would bet on this system approaching a 95% success rate guessing match results this year since the game is much more consistent.
Good points. Thanks for pointing out the flaw in my idea. what I surmise is that this calculation of stdev would be marginally useful at best. This reminds me of a mantra I hear at work quite often: "All models are wrong. Some models are useful."
2016 INWLA GP| INWCH Entrepreneurship | INPMH DCA | INCMP Team Spirit | CAGE Match Winner (w/ 1747 &868), Finalist (1471 w/ 1529 & 1018), Best Fans
2015 ININD Judges Award, Proud "Phyxed Red Card" alliance partners of 1529 & 1720 | INWLA EI | INCMP GP
2014 Boilermaker Creativity | Chesapeake Finalist, Safety, GP, Entrepreneurship | IN State Championship Winner (w/ 868 & 1018) | CAGE Match Winner (w/ 1024, 5402 & 1646)
2013 Boilermaker RCA, Innovation in Controls, Finalist | Crossroads Entrepreneurship | Newton Semi-finalist
2012 Boilermaker Entrepreneurship | Queen City EI | Curie Semi-finalist
2011 Boilermaker RCA, Entrepreneurship
Red Alert Robotics
Unread 19-04-2015, 13:21
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
What probability distribution did you use for the random terms?
