Go to Post "You fogot the gears!!!!" - The_Gman [more]
Unread 19-04-2015, 13:53
WillNess's Avatar
WillNess WillNess is offline
Programmer
AKA: Will Ness
FRC #4944 (The Hi Fives)
Rookie Year: 2014
WillNess is just really niceWillNess is just really niceWillNess is just really niceWillNess is just really nice
Getting Gyro Working w/ Mecanum Drive
Although our season is over, the programming team is still tasked with completing several things before the start of the next season. One of the more difficult things (and something I struggled with implementing) during the build season was using a gyro to help the drivers. This is the code I've come up with so far, but I only included the drive code, nothing else:
Code:
teleopPeriodic(){
   driveCode();
    public static void driveCode(){
    	RobotMap.calculateTurnSpeedsAndAngles();
        if(OI.stick.getZ() < .1){
        	double subtractValue = 0;
        	if(Robot.turnSpeedForGyroCorrection > .3){
        		subtractValue = Robot.turnSpeedForGyroCorrection - .3;
        	}else{
                         //I do not want to robot traveling past 30%, so this subtractValue will never let it go past 50%
        		subtractValue = 0;
        	RobotMap.setVelocityGyro(OI.stick.getX(), OI.stick.getY(), OI.stick.getZ());
        }else{
        	RobotMap.setVelocity(OI.stick.getX(), OI.stick.getY(), OI.stick.getZ());
        	Robot.setAngle = RobotMap.driveGyro.getAngle();
public static void setVelocity(double x,double y,double z){
		double fMax = Math.sin(-0*Math.PI/4+1*Math.PI/4);
		double fR = Math.sin(x*Math.PI/4+y*Math.PI/4)/fMax;
		double rL = -Math.sin(x*Math.PI/4+y*Math.PI/4)/fMax;
		double fL = -Math.sin(-x*Math.PI/4+y*Math.PI/4)/fMax;
		double rR = Math.sin(-x*Math.PI/4+y*Math.PI/4)/fMax;
    	if(Math.abs(z)<.1){
	    	drivefrontLeft.set(fL);
	    	drivefrontRight.set(fR);
	    	driverearLeft.set(rL);
	    	driverearRight.set(rR);
    	}else{
    		drivefrontLeft.set(fL+z/2);
    		drivefrontRight.set(fR+z/2);
    		driverearLeft.set(rL+z/2);
    		driverearRight.set(rR+z/2);
    public static void setVelocityGyro(double x,double y,double z){
		double errorOfAngles = Robot.actualAngle - Robot.setAngle;
		double turnSpeedRight = 0;
		double turnSpeedLeft = 0;
		if(errorOfAngles > 0){
			if(fL > 0){
				turnSpeedLeft = Math.abs(Robot.turnSpeedForGyroCorrection);
			}else{
				turnSpeedLeft = -Math.abs(Robot.turnSpeedForGyroCorrection);
			turnSpeedRight = 0;
		}else if(errorOfAngles < 0){
			turnSpeedLeft = 0;
			if(fR > 0){
				turnSpeedRight = Math.abs(Robot.turnSpeedForGyroCorrection);
			}else{
				turnSpeedRight = -Math.abs(Robot.turnSpeedForGyroCorrection);
		}else{
			turnSpeedLeft = 0;
			turnSpeedRight = 0;
            drivefrontLeft.set(fL - turnSpeedLeft);
	    drivefrontRight.set(fR - turnSpeedRight);
	    driverearLeft.set(rL - turnSpeedLeft);
	    driverearRight.set(rR - turnSpeedRight);
    public static void calculateTurnSpeedsAndAngles(){
    	double turnValue = 0.02;
    	Robot.actualAngle = RobotMap.driveGyro.getAngle();
    	double angleError = Robot.actualAngle - Robot.setAngle;
    	Robot.turnSpeedForGyroCorrection = angleError * turnValue;
Sorry for the weird spacing, that's just how the copy+paste did it. Any help would be appreciated! Also: This is untested
Outreach Lead // Lead Programmer // Junior
2014 FRC:
Rookie Allstar, Highest Rookie Seed & Semifinalist @ Utah
Rookie Allstar, Highest Rookie Seed & Semifinalist @ Colorado
2015 FRC:
Creativity In Engineering & Semifinalist @ Arizona West
Unread 19-04-2015, 14:30
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Re: Getting Gyro Working w/ Mecanum Drive
What do you mean by help the drivers ?
If your goal is to use the gyro to provide a field-centric driver interface, that's already part of the Java WPILib:
Code:
     * Drive method for Mecanum wheeled robots.
     * A method for driving with Mecanum wheeled robots. There are 4 wheels
     * on the robot, arranged so that the front and back wheels are toed in 45 degrees.
     * When looking at the wheels from the top, the roller axles should form an X across the robot.
     * This is designed to be directly driven by joystick axes.
     * @param x The speed that the robot should drive in the X direction. [-1.0..1.0]
     * @param y The speed that the robot should drive in the Y direction.
     * This input is inverted to match the forward == -1.0 that joysticks produce. [-1.0..1.0]
     * @param rotation The rate of rotation for the robot that is completely independent of
     * the translation. [-1.0..1.0]
     * @param gyroAngle The current angle reading from the gyro.  Use this to implement field-oriented controls.
    public void mecanumDrive_Cartesian(double x, double y, double rotation, double gyroAngle) {
        if(!kMecanumCartesian_Reported) {
            UsageReporting.report(tResourceType.kResourceType_RobotDrive, getNumMotors(), tInstances.kRobotDrive_MecanumCartesian);
            kMecanumCartesian_Reported = true;
... Or if your goal is to make the bot drive straight when the driver is commanding zero rotation, you could do something like this:
http://www.chiefdelphi.com/forums/at...4&d=1420598437
...Or here's an interesting optional (button-press selectable) driver interface mode for mec that your drivers might like:
Halo Auto-Rotate (Halo-AR) Driver interface
A single 2-axis joystick does field-centric control of forward/reverse
and strafe right/left motion, while the robot automatically and
simultaneously rotates to face the direction it is commanded.
http://www.chiefdelphi.com/media/papers/download/3721
Unread 19-04-2015, 14:49
WillNess's Avatar
Programmer
AKA: Will Ness
Rookie Year: 2014
Code:
Wait so I can just do
RobotMap.robotDrive.mecanumDrive_Cartesian(OI.joys tick0.getX(), OI.joystick0.getY(), OI.joystick0.getZ(), RobotMap.driveGyro.getAngle());
in my teleopPeriodic and it'll do corrections for me? So if I'm driving w/o rotating it'll auto correct for me?
2014 FRC:
2015 FRC:
Unread 19-04-2015, 15:52
Ether's Avatar
Rookie Year: 1969
What you described above will make the driver interface field-centric:
Code:
If you want the vehicle not to rotate when the driver rotate command is zero, you could do something like this:
Unread 19-04-2015, 16:09
WillNess's Avatar
Programmer
AKA: Will Ness
Rookie Year: 2014
So by field-centric, the robot will ALWAYS face one way? How will the robot act when in this mode?
2014 FRC:
2015 FRC:
Unread 19-04-2015, 17:05
Ether's Avatar
Rookie Year: 1969
No.
Check out some of these links.
Unread 19-04-2015, 20:12
WillNess's Avatar
Programmer
AKA: Will Ness
Rookie Year: 2014
I think I'm confused about what field-centric really is. To my understanding it's positioning based on the layout of the field. Could someone explain this to me?
2014 FRC:
2015 FRC:
Unread 19-04-2015, 20:46
Ether's Avatar
Rookie Year: 1969
See the green arrow? Download that PDF and read Page 18.
Unread 19-04-2015, 21:02
WillNess's Avatar
Programmer
AKA: Will Ness
Rookie Year: 2014
Oh I see. That is not what I'm trying to accomplish. I am trying to get the robot not to rotate when the driver rotate command is zero. How do you accomplish this in Java, not in Labview?
2014 FRC:
2015 FRC:
Unread 19-04-2015, 21:23
Ether's Avatar
Rookie Year: 1969
Like this:
Unread 19-04-2015, 23:01
WillNess's Avatar
Programmer
AKA: Will Ness
Rookie Year: 2014
Like this:
Sorry but that doesn't really help me. Like I understand how it works but I don't know how I would implement this in Java.
2014 FRC:
2015 FRC:
