Go to Post The biggest thing is you don't have to make your robot like another teams. Come up with something unique and go from there. RAISE THE BAR..... - camtunkpa [more]
Unread 28-04-2015, 22:26
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Re: Localization of A Omni-Directional Robot
Originally Posted by cad321 View Post
What about 2 omni wheels placed perpendicular to each other that drag along the floor. As the one in the y axis moves, it gives you your position in the y axis
That's true only if there is no vehicle rotation. If there is going to be vehicle rotation, you need either a) a gyro, or b) a third follower wheel... and you'll need to integrate (vector sum) the vehicle movements.
You might find this post of interest (and also the rest of the post in that thread).
Unread 28-04-2015, 22:59
cad321 cad321 is online now
Jack of all trades, Master of none
AKA: Brian Wagg
FRC #2386 (Trojans)
Rookie Year: 2012
cad321 is just really nicecad321 is just really nicecad321 is just really nicecad321 is just really nice
I corrected my post to include the gyro. I was thinking of it in my head but forgot to add it in. The third follower wheel for rotation is a good idea as well.
Unread 30-04-2015, 15:01
vrcprogrammer vrcprogrammer is offline
vrcprogrammer is an unknown quantity at this point
This all looks great, how would you recommend using a gyro with the three follower wheels.
Thanks
Unread 30-04-2015, 22:56
AlexanderTheOK AlexanderTheOK is offline
Guy
Rookie Year: 2012
AlexanderTheOK is just really niceAlexanderTheOK is just really niceAlexanderTheOK is just really niceAlexanderTheOK is just really nice
Thanks
Well first of all, what is your issue with simply putting encoders on all four of your wheels? If you are going for the X/killough/omni/whateveryouwishtocalllit drive you already have TWO sets of "mouse wheels". Theyre your drive wheels! Even without the gyro you can get rotational odometry. (I have tried this when we were prototyping swerve code on a vex base and it wasn't all too terrible. A gyro is still better, but odometry can determine your angle)
Ether's papers on controlling an omnidirectional drive apply in the reverse direction in order to find your movement based on encoders.
Unread 30-04-2015, 23:44
AKA: Brian Wagg
FRC #2386 (Trojans)
Rookie Year: 2012
The biggest issue with this method is wheel slippage. Say I accelerate to quickly, or I get into a pushing match and my wheels start to spin because they lost traction. All of a sudden my robot thinks it's 5 feet further forward than it actually is. By getting feedback from unpowered wheels or a laser, you know that whatever movement you detect should in theory be the exact actual movement of your robot.
Unread 02-05-2015, 08:58
This is the exact reason I am trying to use the follower wheels, but I would like a way to use the gyro/ultrasonics, to check the data, is this needed, or are the followers accurate enough?
