Go to Post it's not because the kids look up to him that [Dave] gets picked on, it's really because it's just so much fun. - MissInformation [more]
Unread 23-04-2015, 21:03
pabeekm's Avatar
pabeekm pabeekm is offline
Master of typos
AKA: Patricia
FRC #0900 (Zebracorns)
Rookie Year: 2012
pabeekm has a reputation beyond reputepabeekm has a reputation beyond reputepabeekm has a reputation beyond reputepabeekm has a reputation beyond reputepabeekm has a reputation beyond reputepabeekm has a reputation beyond reputepabeekm has a reputation beyond reputepabeekm has a reputation beyond reputepabeekm has a reputation beyond reputepabeekm has a reputation beyond reputepabeekm has a reputation beyond repute
Pushing pool noodles
What have you guys found to be successful for herding noodles?
Unread 23-04-2015, 21:31
Peyton Yeung's Avatar
Peyton Yeung Peyton Yeung is offline
45 Alumni
AKA: Peyton Yeung
FRC #0461 (Westside Boiler Invasion)
Team Role: Coach
Peyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond repute
Re: Pushing pool noodles
Leaving a tote on the ground is pretty good if you push it around.
461 Westside Boiler Invasion
2016 Tippy Quarter finalist, Warren Finalist, IN State Semi Finalist,B^3 Double Finalist
2015 Indy Semi finalist, Purdue Quarter Finalist, IN State Quarter Finalist, CORI QF, R2OC Finalist, RAGE Winner
2014 Boilermaker Semi finalist, Crossroads Quarter Finalist, & CAGE Quarter Finalist
45 Technokats
2013 Boilermaker Quarter finalist
2012 CAGE Semi finalist & Queen City Champion
2011 CAGE Quarter finalist & Midwest Semi finalist
2010 CAGE Quarter finalist, Boilermaker Champion, & Washington DC Quarter Finalist
Unread 23-04-2015, 21:47
thehotsauceman's Avatar
thehotsauceman thehotsauceman is offline
Team Captain, Electrical, Driver
AKA: Sean Munson
FRC #0016 (Bomb Squad)
Team Role: Driver
Rookie Year: 2014
thehotsauceman is a jewel in the roughthehotsauceman is a jewel in the roughthehotsauceman is a jewel in the rough
Zip ties trimmed down and positioned to where they make kind of like a brush work well.
What's better than Robotics? What's better than the competitions? What's better than winning in a competitive atmosphere? The only thing that comes to mind is Dean Kamen's Denim Jacket.
Unread 23-04-2015, 23:43
BBray_T1296's Avatar
BBray_T1296 BBray_T1296 is offline
I am Dave! Yognaut
AKA: Brian Bray
FRC #1296 (Full Metal Jackets)
Rookie Year: 2010
BBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond repute
We found that the larger computer fans do a decent job of blowing the noodles out of our path, though I'm not sure they made it to the competition bot.
If molecular reactions are deterministic, are all universes identical?
RIP David Shafer: you will be missed
Unread 23-04-2015, 23:44
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Rookie Year: 2013
The chassis. We built the KOP chassis as a 4-wheel omni, and it pushes noodles around pretty decently. Any "flat" wheel arrangement should be able to do this if you have a surface that drops to within an inch of the floor.
If your chassis has drop-center wheels or must be higher for other considerations, a piece of a push broom should work nicely. Actually, what would probably work best (haven't actually tried) would be one of those applicators that you can find in the roofing and paving section of the home improvement store. They're about 24-30" wide but only one bundle of bristles deep. It works pretty well at sweeping leaves and pine straw off the roof, which sounds like a tougher job than sweeping pool noodles across carpet.
Unread 24-04-2015, 00:31
daliberator's Avatar
daliberator daliberator is offline
Ace Machinist
AKA: Henry O'Callaghan
FRC #4536 (MinuteBots)
Team Role: Mechanical
Rookie Year: 2014
daliberator will become famous soon enoughdaliberator will become famous soon enough
We cut up some 1/8 inch hard plastic strips about 1-1/2" in width and mounted them to the front and the back of our frame and they have worked pretty well from what my driver has told me. Thanks to 2052 for the stock! If you want to stop by our pits in Carver, we'd be happy to show them to you.
4536 Team Captain
www.minutebots.org
Unread 24-04-2015, 23:40
The other Gabe's Avatar
The other Gabe The other Gabe is offline
Too many events, not enough time
AKA: I'm a volunteer now!
no team (2046 Bear Metal Alumn)
Rookie Year: 2012
The other Gabe has much to be proud ofThe other Gabe has much to be proud ofThe other Gabe has much to be proud ofThe other Gabe has much to be proud ofThe other Gabe has much to be proud ofThe other Gabe has much to be proud ofThe other Gabe has much to be proud ofThe other Gabe has much to be proud ofThe other Gabe has much to be proud of
2605 has a cool bendy PVC pushy thing that passively articulates to go over the scoring platform... easier to watch than it is to explain: (close one on red)
Do the best you can with what you are given
FRC 2046 2012-2015
Field Scout lead 2014-2015
