Go to Post Yes there are a lot of problems that will pop up solving the problem, but thats the reason we do engineering for. - Arefin Bari [more]
Unread 25-04-2015, 12:31
FRC Team CC FRC Team CC is offline
FRC #6560 (Charging Champions)
Rookie Year: 2012
FRC Team CC is an unknown quantity at this point
[FTC]: Anderson Powerpole Question
Chief Delphi,
We had a question regarding the Anderson Powerpole Connectors (used to replace the unreliable Tamiya connectors). After following the instructions provided in the FTC Wiring Guide, we found that the connectors came apart really easily, and could just be pulled apart without any effort.
Is this supposed to happen? If not, how can we solve the problem?
Thanks,
Charging Champions
The Charging Champions
FTC Team #8660
Facebook Page: https://www.facebook.com/chargingchampions
Follow us on Twitter: @FtcTeamCC
Google Plus: https://plus.google.com/112552147224383900922/posts
Youtube channel: https://www.youtube.com/channel/UCop...G3zsvQKCXF4ESQ
Blog: http://chargingchampionsblog.blogspot.com/
Unread 25-04-2015, 12:43
Foster Foster is offline
Engineering Program Management
VRC #8081 (STEMRobotics)
Foster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond repute
Re: [FTC]: Anderson Powerpole Question
When you say "come apart" do you mean that the pins pull out of the shell? That's an indication that you haven't pushed the pins into the shell far enough.
If you mean that the two ends that mate come apart it means the pins are not in the shell the right way. There is a curve to them that applies the mating surface pressure.
What size are you using?
Foster - VEX Delaware - 17 teams -- Chief Roboteer STEMRobotics.org
2010 - Mentor of the Year - VEX Clean Sweep World Championship
2006-2016, a decade of doing VEX, time really flies while having fun
Downingtown Area Robotics Web site and VEXMen Team Site come see what we can do for you.
Unread 26-04-2015, 14:06
Rookie Year: 2012
We mean that the two ends that are supposed to connect to each other (e.g. the battery end and the charger end) do not click and can be pulled apart very easily.
Here is the link to the Powerpoles that we are using:
http://www.amazon.com/Anderson-Power...rson+Powerpole
How can we solve this problem? Is there some pin or clamping device that holds the two ends together?
Thanks,
Charging Champions
FTC Team #8660
Unread 10-05-2015, 20:49
I posted this on the 25th, no answer, can you make the connection up and try.
Also no sure on something as simple as Power Poles can drag this long on CD...
Unread 11-05-2015, 07:40
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
FTC,
The connector pairs should mate with significant friction to hold them together, provided you do not have tension on the wires that will pull them apart. It is possible that you have bent contacts (as shown in the Powerwerx link above.) If the contacts are bent, (or are not free to move within the housing), the contacts will not mate properly. This occurs for two significant reasons. The first is using an improper crimper. This causes the terminal to be bent and will result in a lot of force needed during contact insertion. The second results from soldering the terminal which may result in excess solder causing the same type of misalignment as with improper crimping. While many crimpers will state they can crimp these contacts, only those specifically designed for APP contacts actually do the job.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 23-05-2015, 22:31
Rookie Year: 2012
Here are the pictures of the Anderson Powerpoles:
It looks like they are inserted correctly. When they are snapped onto another connector, we can hear the click, but they still come apart pretty easily.
ID:	19026  Click image for larger version
ID:	19027  Click image for larger version
ID:	19028  Click image for larger version
FTC Team #8660
Unread 24-05-2015, 07:22
wgardner's Avatar
wgardner wgardner is online now
Team Role: Coach
Rookie Year: 2012
wgardner is a splendid one to beholdwgardner is a splendid one to beholdwgardner is a splendid one to beholdwgardner is a splendid one to beholdwgardner is a splendid one to beholdwgardner is a splendid one to beholdwgardner is a splendid one to behold
I don't see anything glaringly wrong with your pictures (though the way you're connecting red and black to each other is non-standard). And you're putting the wires in both ends, then connecting both ends, and hearing the click? If that's what you're doing, I don't know what else could be wrong. Are there any local teams you could work with in person?
I've attached a few (poor) photos of some of the powerpoles on one of our robots for comparison.
ID:	19030  Click image for larger version
CHEER4FTC website and facebook online FTC resources.
Providing support for FTC Teams in the Charlottesville, VA area and beyond.
Unread 24-05-2015, 15:40
Rookie Year: 2012
Wgardner: Thanks for all of your help.
The Powerpole stay together, but are very loosely connected and can be pulled apart with minimal effort. Looks like we might have to use the forks to keep them together.
Thanks,
Charging Champions
FTC Team #8660
Unread 25-05-2015, 16:22
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Rookie Year: 2013
Thanks,
Charging Champions
If they don't stay together without additional help, they may not be making good electrical contact, either. Here is a document from the ham radio community that has a bit more detail, including the standard configuration of red-black pairs. The standard mnemonic is "Red Right Tongue Top". With the wires toward you, and the dovetail "tongues" on top, red will be on your right. The pictures shown in the ham doc and in the post by wgardner above are taken from the contact side, so red is on the left when the tongues are on top.
Unread 25-05-2015, 16:36
+1
K3FXS here and I've used the above PDF on building my cables. They stick together and they stay together. I'm not sure what you are doing that makes them easy to pull apart. I've had radios suspended by the power pole and they have not fallen.
Unread 26-05-2015, 10:29
Rookie Year: 2012
Thanks for all of your help. We will post on this thread when we are able to fix the issue.
Thanks,
Charging Champions
FTC Team #8660
Unread 27-04-2015, 00:34
Chinske4296 Chinske4296 is offline
FRC #4296
Chinske4296 is an unknown quantity at this point
They come with two pronged inserts to hold the plugs together... The slide in and as long as those stay in there is no way that the plugs can come undone.
Unread 27-04-2015, 00:36
FRC #4296
Here's an image of what I am talking about.
Unread 27-04-2015, 00:41
cadandcookies's Avatar
cadandcookies cadandcookies is offline
Director of Programs, GOFIRST
AKA: Nick Aarestad
FTC #9205 (The Iron Maidens)
cadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond repute
One of the other ways you can minimize disconnections is by securing your wiring using zip ties-- if you immobilize the wire on both sides of the connection, I've never seen the small powerpole connectors disconnect. If you're using them as a battery connection and securely fastening your battery (which you should be), you shouldn't encounter any significant issues. Treat your electronics nicely and they will treat you nicely back!
Never assume the motives of others are, to them, less noble than yours are to you. - John Perry Barlow
tumblr | twitter
'Snow Problem CAD Files: 2015 2016
MN FTC Field Manager, FTA, CSA, Emcee
FLL Maybe NXT Year (09-10) -> FRC 2220 (11-14) -> FTC 9205(14-?)/FRC 2667 (15-16)
VEXU UMN (2015-??)
Volunteer since 2011
2013 RCA Winner (North Star Regional) (2220)
2016 Connect Award Winner (North Super Regional and World Championship) (9205)
  #15   Spotlight this post!
Unread 30-04-2015, 20:38
Rookie Year: 2012
Thanks to all for responding.
Chinske4296: We didn't receive those parts with our Anderson PowerPole kit. Can we buy them separately online?
Thanks,
Charging Champions
FTC Team #8660
