Go to Post Theres just something about a big honkin' robot that's irresistible. - seanwitte [more]
Unread 26-04-2015, 16:32
Deetman Deetman is offline
AKA: Kevin Dieterle
Deetman has a reputation beyond reputeDeetman has a reputation beyond reputeDeetman has a reputation beyond reputeDeetman has a reputation beyond reputeDeetman has a reputation beyond reputeDeetman has a reputation beyond reputeDeetman has a reputation beyond reputeDeetman has a reputation beyond reputeDeetman has a reputation beyond reputeDeetman has a reputation beyond reputeDeetman has a reputation beyond repute
Re: Petition for Better Championship Video
Originally Posted by Metonym View Post
Does MAR still stream audio?
As Dan said above, MAR streams out emcee, game announcer, game sounds and any additional microphones used. The setup has changed since Dan saw it last, but all of our audio goes in to our DJ's audio mixer and then we get one feed from them without any copyrighted music.
Sean definitely nailed the reasons for YouTube... Being able to explain to grandparents over the phone how to watch the event their grandchild is participating is huge. Good luck explaining twitch or livestream or any other streaming service to someone less technically inclined over the phone. Everyone knows how to use YouTube.
There is much more that can be posted on the complexities of webcasting events, but the first and primary for championships is bandwidth. To run 8 streams simultaneously at 720p, you are looking at 16Mbps minimum upload and that is without any overhead and minimum quality settings. Ideally you'd be looking at around 40Mbps upload to comfortably stream 8 720p streams at high quality, which may not even be available from the venue. Assuming that NASA is running the streams through a satellite uplink, I highly doubt that their uplink is capable of sustaining 40Mbps. This doesn't even touch on the reliability required for it and ignores other internet requirements at the venue for the event.
FIRST Mid-Atlantic Volunteer (2012-present)
Team 1014 Alumni (2004-2005)
Team 1712 Mentor (2011-2015)
Unread 26-04-2015, 16:37
dcarr's Avatar
dcarr dcarr is offline
#HoldStrong
AKA: David Carr
FRC #3309 (Friarbots)
dcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond repute
I'm going to have to disagree with you here. From a usability perspective, if all you are doing is clicking a link that brings up the live stream, there is absolutely no difference in any of the major streaming services.
  • Email link to person, post it on Twitter/FB/Website, read it to them over the phone
  • Person visits link, sees video, watches
Team 3309
2016 Los Angeles Chairman's Award Winner
2016 Orange County Regional Winner with 3476 & 6220
Team3309.org
Orange County Robotics Alliance
Unread 26-04-2015, 18:03
AKA: Kevin Dieterle
While yes that is simple, but what if said person isn't on a computer? Are they on a tablet or smart TV? If so, they probably have a YouTube app either preinstalled or installed already. Twitch/Live stream? Probably not. Yes twitch is a legitimate platform but it does not have the brand recognition/familiarity for some outside the FRC community to make them comfortable. This doesn't even touch the technical offerings YouTube has that Twitch/others do not.
Solid LTE should be able to exceed these qualifications comfortably. There are even professional HD casting solutions that load balance between multiple LTE modems to obtain the highest QoS. You could rig something up similar with a consumer router running DD-WRT.
I guarantee that there are people in this very thread that could have run the Championship streams far better than NASA did with consumer grade hardware. That's what's disappointing.
Yes I am aware of such solutions using LTE and they may be feasible to use. I can tell you from experience though that you can't just hook the stuff up and expect it to work. I would want to test my connection at each venue and have solid data trying to use such a system with 40k+ people with cell phones at the venue using the limited wireless bandwidth before I would ever propose such a solution to FIRST.
Consumer grade hardware is just asking for trouble in my opinion. I'm not saying the equipment needs to be the most expensive professional solution available but consumer equipment has a tendency to choke at the worst times in mission critical applications.
Originally Posted by blazingbronco18
Unfortunately, taking the audio from the announcer and emcee isn't very plausible for regional events. As we ran into this problem at the Utah regional, they said that they were not able to connect the announcer and emcee. In they end they got a student announcing the game, for those watching on the stream.
This is one of the advantages and reasons why you see districts leading the way on the live webcast front. We can control and specify much more at our events. MAR for example contracts the same DJ company for all of our events. They have a audio mixer that they use that exactly meets our need for local in venue production and for the webcast. We bring in our video case, make three audio connections, and we are setup on the audio front.
FIRST could probably do more on this front to make sure that guidelines for event audio specify isolated audio, etc. but I don't know what they currently say.
Unread 26-04-2015, 16:39
dcarr's Avatar
#HoldStrong
AKA: David Carr
Team 3309
Team3309.org
Unread 26-04-2015, 17:24
blazingbronco18 blazingbronco18 is offline
FRC #3200 (Raptacon)
Rookie Year: 2011
blazingbronco18 is an unknown quantity at this point
Unread 26-04-2015, 17:59
ArtemusMaximus's Avatar
ArtemusMaximus ArtemusMaximus is offline
Enginerd
FTC #11722
Team Role: Coach
Rookie Year: 2014
ArtemusMaximus is a name known to allArtemusMaximus is a name known to allArtemusMaximus is a name known to allArtemusMaximus is a name known to allArtemusMaximus is a name known to allArtemusMaximus is a name known to all
Originally Posted by Joey1939 View Post
Stream Quality - Comcast
Stream quality also varies greatly from Regional to Regional. Some have excellent streams, whereas other don't have one.
Also, some Regionals did not have webcast at all
