Go to Post We are all insane aren't we? I just want to build a robot now. :P - Lowfategg [more]
Unread 28-04-2015, 13:48
Jared Russell's Avatar
Jared Russell Jared Russell is offline
Taking a year (mostly) off
FRC #0254 (The Cheesy Poofs), FRC #0341 (Miss Daisy)
Jared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond repute
Re: 2015 RoboRIO/Control System Feedback
Originally Posted by Jared View Post
-Timertasks don't work properly if they are started before connecting to the driver station, but work if the reset button is pushed on the roboRIO. Troubleshooting this behavior is difficult, and it's never comforting when resetting or redeploying code puts the controller in a different state than a cold boot.
-Java timertask timing is worse than in previous years.
We ran into the first issue at CVR...the problem is that the scheduleAtFixedRate() method schedules execution relative to the timestamp of the first execution (and the RoboRIO initially assumes it is turned on at the beginning of the epoch), but when the robot connects to the driver station, the local clock is synched to the driver station time. Your code freaks out because it thinks it has ~45 years worth of work to do in order to catch up, and as a result your TimerTask hogs the entire CPU. TL;DR, never use scheduleAtFixedRate(). Thanks to Joe Hershberger for helping us to figure this out.
As for TimerTask timing being bad otherwise, this is because of some incomplete JNI between the HAL and WPIlibJ. Whereas LabView and C++ use the onboard hardware timer to generate interrupts for calling recurring tasks, the current implementation of TimerTask uses Thread.sleep(), which is quite unreliable. We would schedule 5 ms periods and get around 5 ms most of the time, but we would see several 10+ ms periods per second, and occasionally even 200+ ms periods.
We hacked our WPIlib JAR with some additional JNI to get to the FPGA timer and were much, much happier with our timing jitter. I think Tom submitted a patch to WPIlib, so hopefully this will be fixed for next year. It took us a long, long time to figure it all out...
Unread 28-04-2015, 14:14
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
FRC #1296 (Full Metal Jackets)
wireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond repute
Send a message via AIM to wireties
I generally loved the new control systems and the Talon SRX motor controllers this year. Just a few requests:
1 - Please reconfigure the kernel to include POSIX message queues and semaphores. Embedded Linux is incomplete w/o these primitives.
2 - Please make it easier to use static priorities in threads. Many teams roll their own software solutions and we can't do the same things we did with VxWorks.
3 - Please use latching connectors on the roboRio. It is nearly a crime that we use the old PWM connectors in a high vibration environment.
4 - Please do not use Silverlight. It requires the client be Windoze and install a bunch of crap.
TIA
Fast, cheap or working - pick any two!
Unread 28-04-2015, 19:31
RyanShoff RyanShoff is offline
FRC #4143 (Mars Wars)
Rookie Year: 2012
RyanShoff is a splendid one to beholdRyanShoff is a splendid one to beholdRyanShoff is a splendid one to beholdRyanShoff is a splendid one to beholdRyanShoff is a splendid one to beholdRyanShoff is a splendid one to behold
Requiring Silverlight to manage a Linux device bugged me.
If we left the robot on for a long time, maybe 15-30 minutes, the robot would freak out. Planning to debug that later.
Ryan Shoff
4143 Mars/Wars
CheapGears.com
Unread 29-04-2015, 11:00
Thad House Thad House is offline
Volunteer, WPILib Contributor
no team (Waiting for 2021)
Rookie Year: 2010
Thad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond repute
This was actually an issue at Worlds, since Chrome dropped NPAPI support the week before. So we spent about 10 minutes trying to connect to the webdash, until I remembered, and we switched to IE. I would prefer to use chrome, which means they should switch to something chrome supports, and not silverlight.
All statements made are my own and not the feelings of any of my affiliated teams.
Teams 1510 and 2898 - Student 2010-2012
Team 4488 - Mentor 2013-2016
Co-developer of RobotDotNet, a .NET port of the WPILib.
Unread 29-04-2015, 11:26
Rookie Year: 2012
This chrome://flags/#enable-npapi and click enable will work for another year or so until Google has said they will really remove it.
Ryan Shoff
4143 Mars/Wars
CheapGears.com
Unread 30-04-2015, 00:19
timytamy's Avatar
timytamy timytamy is offline
AKA: Tim
FRC #3132 (The Thunder Down Under)
Team Role: Electrical
Rookie Year: 2010
timytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant future
I agree it seems wrong, however maybe have a look at Pipelight (http://pipelight.net/cms/installation.html). Seemed to work ok for me (admittedly, I only opened the management page and clicked around, I didn't do any serious work with the roboRIO this year).
For convenience, Pipelight installation on Ubuntu (and derivatives):
Code:
sudo add-apt-repository ppa:pipelight/stable && sudo apt-get update && sudo apt-get install --install-recommends pipelight-multi && sudo pipelight-plugin --update
Tim W
FIRST® Team 3132 - The Thunder Down Under
Sydney, Australia
Website | Facebook | Youtube
Unread 28-04-2015, 00:49
billbo911's Avatar
billbo911 billbo911 is offline
I prefer you give a perfect effort.
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
billbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond repute
The mDNS SmartDashboard issue cost us a match thursday at champs. I hope they can figure that and maybe a few other mDNS issues out for next year. Having to restart Driver Stations when running back to back matches is sometimes very odd.
Originally Posted by Alan Anderson View Post
I saw lots of teams with lots of control system issues this year. None of them was really the fault of the control system itself. When the instructions are followed by someone who actually pays attention to them, and who is not sloppy with the wiring, things just work. The roboRIO's web console is great, and the rework of the DS-to-robot communication protocol seemed to make a positive difference in connectivity. I just wish Windows weren't so unpredictable in how it deals with switching between networks with and without DNS active.
I completely agree with both of these quotes.
What I believe would make a huge improvement to the quirkiness of mDNS is to put a "Restart mDNS" button on the DS. It would give all users a really quick way to connect to the field and RR. Restarting the DS, changing the team number and changing it back, disabling and re-enabling the NIC all work, but they are all more difficult processes than what is needed.
CalGames 2009 Autonomous Champion Award winner
Sacramento 2010 Creativity in Design winner, Sacramento 2010 Quarter finalist
2011 Sacramento Finalist, 2011 Madtown Engineering Inspiration Award.
2012 Sacramento Semi-Finals, 2012 Sacramento Innovation in Control Award, 2012 SVR Judges Award.
2012 CalGames Autonomous Challenge Award winner ($$$).
2014 2X Rockwell Automation: Innovation in Control Award (CVR and SAC). Curie Division Gracious Professionalism Award.
2014 Capital City Classic Winner AND Runner Up. Madtown Throwdown: Runner up.
2015 Innovation in Control Award, Sacramento.
2016 Chezy Champs Finalist, 2016 MTTD Finalist
Unread 28-04-2015, 12:50
MrRoboSteve MrRoboSteve is offline
Mentor
AKA: Steve Peterson
FRC #3081 (Kennedy RoboEagles)
Rookie Year: 2011
MrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond repute
The developers got a lot of feedback about the DS connection issues at the field. Based on historic response to feedback, it will likely be a focus for them in the off season.
the Weidmuller connectors seem to be happiest with 20 gauge wire, but teams seem to want to use 18 gauge or thicker. This makes inserting the wires without risking short circuits more difficult than it ought to be.
Agreed. I saw a bunch of this last year as CSA, less this year as FTAA but I suspect a lot of it was dealt with by our crack CSA crews. I tell teams that, if you can't give the wires a good tug, they're not in there well enough.
2016-17 events: 10000 Lakes Regional, Northern Lights Regional, FTC Burnsville Qualifying Tournament
2011 - present · FRC 3081 Kennedy RoboEagles mentor
2013 - present · event volunteer at 10000 Lakes Regional, Northern Lights Regional, North Star Regional, Lake Superior Regional, Minnesota State Tournament, PNW District 4 Glacier Peak, MN FTC, CMP
http://twitter.com/MrRoboSteve · www.linkedin.com/in/speterson
Unread 28-04-2015, 13:33
Bryan Herbst's Avatar
Bryan Herbst Bryan Herbst is offline
AKA: Bryan
FRC #2052 (KnightKrawler)
Rookie Year: 2007
Bryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond repute
From what I heard from folks at FIRST, NI has an update ready to go that fixes the need to restart the DS (or toggle the team number) between back to back matches.
It wasn't released during the season due to the complexity involved with trying to ensure that every team got a mid-competition season update, but *should* be available sometime during the offseason.
Overall, the new control system has been great. I love the web config, and I have dreamt of being able to use more modern versions of Java for years.
The most annoying problems I ran into were also the most common (mDNS being slow on the field and Axis camera configuration), so I have faith that they will improve for 2016. We've already seen some improvements, so hopefully another few months will make it even better.
As Alan mentioned, the Weidmuller connectors are easy for teams to wire incorrectly. Too many teams have copper splayed out around the connection. Hopefully this will get better as teams gain more experience with the connectors (and with their robot shorting out on the field).
Team 2052- Knightkrawler
Mentor and volunteer
