Go to Post Hmmm, the Michelangelo method of robot building. Just cut away anything that doesn't look like a robot. - GaryVoshol [more]
Unread 27-04-2015, 21:43
VijayAT VijayAT is offline
FRC #4901
VijayAT is an unknown quantity at this point
Victor 888 by Arduino Uno R3
This is not an FRC or FIRST related project.
I'm using a Victor 888 and an Arduino Uno R3 to power a BAG motor through PWM. I'm using a FIRST battery.
I found this sample code on Arduino's forums:
#include <SoftwareServo.h>
SoftwareServo servo1;
SoftwareServo servo2;
void setup()
pinMode(9,OUTPUT);
servo1.attach(2);
servo1.setMaximumPulse(2200);
servo2.attach(4);
servo2.setMaximumPulse(2200);
Serial.begin(9600);
Serial.print("Ready");
void loop()
static int value = 0;
static char CurrentServo = 0;
if ( Serial.available()) {
char ch = Serial.read();
switch(ch) {
case 'A':
servo1.attach(2);
CurrentServo='A';
digitalWrite(13,LOW);
break;
case 'B':
servo2.attach(4);
CurrentServo='B';
digitalWrite(13,HIGH);
break;
case '0' ... '9':
value=(ch-'0')*20;
if (CurrentServo=='A')
servo1.write(value);
else if (CurrentServo=='B')
servo2.write(value);
break;
SoftwareServo::refresh();
and this from another Chief Delphi post:
//Simple VEX Pro Victor 888 Driver
unsigned short pin = 9;
signed int dutyCycle = 0;
unsigned int highus = 1500;
unsigned int lowus = 1000;
void setup() {
pinMode(pin, OUTPUT);
digitalWrite(pin, LOW);
Serial.begin(9600);
void loop() {
digitalWrite(pin, HIGH);
delayMicroseconds(highus);
delayMicroseconds(lowus);
if (Serial.available() > 0) {
highus = 5*Serial.parseInt() + 1500;
lowus = 1000;
Serial.print("DS: "+dutyCycle);
I have a VEX Pro VersaPlanetary 10:1 Gearbox and I need the motor to run at 600 RPM, so I can get 60 RPM from the gearbox. I've also looked through Arduino's servo library. Any advice?
Unread 27-04-2015, 22:03
JNajarian JNajarian is offline
Alumni
FRC #0696
Rookie Year: 2012
JNajarian will become famous soon enough
Re: Victor 888 by Arduino Uno R3
Try something like this just to test if your electrical setup works.
Code:
#include <Servo.h>
Servo victor1;
void setup(){
    victor1.attach(2);
void loop(){
    victor1.write(180);//0 being full backwards 90 being no motion and 180 being full forwards
Last time I used a Victor with an Arduino was about two years ago, I don't have the equipment to test this code right now, but this is essentially what I used to run it.
Unread 27-04-2015, 23:21
teslalab2's Avatar
teslalab2 teslalab2 is offline
RogueBotix LLC
VRC #8091
Rookie Year: 2014
teslalab2 will become famous soon enoughteslalab2 will become famous soon enough
I wrote I library for jaguars and victors (though I haven't actually tried it with victors)
in header:
#include "Victor.h"
Victor mycontroller;
void setup()
mycontroller.SetPort(pinnum,true/false) //the boolean is for if its reversed or not.
void loop
mycontroller.Set(from -1 to 1)
this might only work on pin 3,5,6,11, like I said I haven't tried it because I don't own any victors. but if you want it here you go , and you will probably have to recalibrate the controller.
I need a jaguar development board for reprogramming a jaguars bootloader. if you have one that you want to sell, pm me. thanks
Run you CanJaguars on arduino with ArduRIO, you can also easily control Talons, Victors,Jaguars and Sparks on PWM. https://sourceforge.net/projects/ardurio/
Unread 28-04-2015, 00:54
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Team Role: Mechanical
Rookie Year: 2013
I was just about to look for code like this this morning, to see how much processing we can move offboard to an XMOS (just for kicks). Thank you!
