| Thread Tools |
Rating:
Display Modes |
Best Way to Launch unusual items?
We were talking and whats the best way to launch unusual items, such as lunacy balls, breakaway balls, frisbees, footballs and other random object you could also find around the shop?
Re: Best Way to Launch unusual items?
A specially designed hammer?
Catapult/Slingshot, unless you know a way to make a wheeled shooter account for every shape change
Do you want to launch these objects more than 30 ft?
Wheeled shooter with suspension to account for various ball sizes.
Preferably
This or use a large foam wheel, similar to 118 in 2013.
This faux TED talk covers some of the parameters of odd items being launched.
When you're shooting a variety of various shaped items long distances, wheeled shooters aren't going to perform as well. Wheeled shooters as we know them in FRC work best with objects that can roll / spin - balls, frisbees, etc. We are abe to design such precise and repeatable wheeled shooters because we are shooting such an incredibly narrow range of items - a single game piece, with manufacturing tolerances being the only varying factor. Wheeled shooters also shoot multiple game pieces in quick succession really well, which doesn't seem like is needed here. Wheeled shooters are solving the wrong problem.
A catapult cares much less about the geometry of what is inside it - it brings itself and its object up to speed and stops at the angle producing the desired trajectory. Obviously this will have varying results with each game piece as well, but I think it's a better solution for the constraints at hand. Take a look at what 16 did in 2012 as a starting point. |
#10
Most FRC grippers are made specifically to hold a certain size/shape/weight piece, so most of the usual tricks won't work. Some sort of speed-controlled catapult/ballista (I'm thinking motors and encoders) could be used to get everything up to an appropriate/consistent speed. To hold the pieces, I'd try a gripper that can accommodate many shapes, probably by having multiple pneumatic arms that curl in on the "game piece". You can use the thing on the other side of your wrist as a rough template.
#11
The argument was started while going over the design of our hockey puck shooter on whether we should go:
air powered(paintball gun like) inline wheel shooter(ultimate ascent) top wheel shooter with roller bottom(baseball shooter) Spring loaded plate(pinball) Slingshot or is there something else more efficient to shoot the put accurately at really high speeds for our challenge. |
#12
i've seen 3996 use a hammer to kick basketballs back in 2012
#13
This is an amazing opportunity to make plywood ghetto prototypes and do some good ol' fashioned testing. The three main things that peoples are suggesting are catapults, slingshots, hammers (all easy to prototype) and wheeled shooters (more difficult but doable).
Things like air power can probably be crossed off the list because getting a seal on a lunacy ball would be... lunacy (sorry, I had to) as well as accommodating the different shapes and sizes of the other pieces. I think that a catapult would work best in this application but have no real experience (and neither does anyone else as far as I'm aware). Unless someone here can point to an off-season project they've done shooting multiple different gamepieces I would take everything with a large grain of salt. Implementation is an entirely new can of worms. If you do go for a catapult there are multiple options; lots of motor, stored energy and release (surgical tubing/spring), pneumatic, something else I've inevitably forgotten. Each option has advantages and disadvantages. Last edited by Scott Kozutsky : 28-04-2015 at 18:49. |
#14
and as for a slingshot i know people (my team included) made kickers that were a piece of lexan held back and then released to exert a force to kick the soccer balls. |
#15
33 using a catapult to full court shoot in 2014 https://www.youtube.com/watch?v=1-oWAS9_Rl4 Last edited by Scott Kozutsky : 28-04-2015 at 19:04. |
