Go to Post "Programming is 1% talent and 99% not getting distracted by the Internet." - FRC4ME [more]
Thread Tools Rating: Thread Rating: 4 votes, 5.00 average. Display Modes
Unread 28-04-2015, 13:52
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
VEX Pro Parts Feedback, 2015
Now that champs has completed, what were the strengths and areas of improvement for the VEXPro line of COTS products, including WCP? What new products would teams like to see that are in the same core vein as the current VEXPro or WCP products? In what useful or unique ways did you use these products that you wish to share? What nuances or undocumented features did you find with them?
  • I really like the WCP clamping bearing blocks + Cams. They went on in no time using a hole saw, and once tuned lasted the entire season with little to no maintenance. They're a bear to get on after powder-coating, but that's a good thing IMO. I plan to come out with a printable encoder mount specifically for this block since we couldn't seem to properly strain relief our encoder wires for them to stay in using the normal WCD methods.
  • VEXPro Single Reduction Clamping Gearbox: the King of experimenting with gear ratios in a prototyping environment when combined with a 2nd-stage sprocket reduction. Most intake or lift gearboxes have 2 stages, and this plastic assembly sets up for 2 stages and an encoder very nicely, without needing a chain/belt tensioner. We used it for a lift, but we could have easily used it for a single-speed drive train as well.
  • WCP WCD Gearboxes: we experimented with both single and double-speed in the offseason and couldn't be more pleased with how well these work in a WCD setup. It would have been nice to have slower 2-speed options for 6" wheels for the actual season, but we found that we could easily work with what was available. We were very meticulous in initial assembly on the production bot, and only had to perform maintenance on one gearbox one time during the season (the live bearing wanted to come out of the low dog gear, but we re-pressed it using channel-locks and it stayed ... ha).
  • Omni Wheels with VersaKey and VersaHub - in a WCD drive setup, we found that we didn't need any bolts to keep the omnis attached to the hubs. The VersaKey matched pattern combined with axle spacers did everything we needed. This was a pleasant discovery.
  • BAG Motor - for all of Champs we ran this thing at 80-90% of peak power, and it performed flawlessly. It was put into a brief inadvertent stall once or twice, and still did not burn out. It will be my go-to medium power motor from now on.
  • Request: longer belts. The VEXPro belts are very inexpensive 5mm HTD belts, and I'd like to use the 15mm width version for more lifts in the future. Sourcing long belts was tough as many places were out of stock this season. Lifts come in all different lengths, usually with an overlapped portion where two ends of chain/belt meet - so I'd also be happy with purchasing the 15mm belt by the foot/meter.
  • Challenge for your Interns: Create a brake mechanism that easily assembles into a gearbox, combines with the Clamping Gearbox, or fits nicely with/on of the other VEXPro products. Bonus points if it fits directly onto a Versaplanetary gearbox or WCP Bearing Block. Holding a game piece steady at a specific height seemed to be a barrier for some teams this season since they didn't realize they needed it until after then entire subsystem was assembled. I never got the chance to redesign ours so it'd take up less space. I'd like to see what you guys came up with.
Unread 28-04-2015, 13:57
Tim Sharp Tim Sharp is online now
Tim Sharp
FRC #3959 (Morgan County Mech Tech)
Team Role: Coach
Rookie Year: 2012
Tim Sharp is a splendid one to beholdTim Sharp is a splendid one to beholdTim Sharp is a splendid one to beholdTim Sharp is a splendid one to beholdTim Sharp is a splendid one to beholdTim Sharp is a splendid one to beholdTim Sharp is a splendid one to behold
Re: VEX Pro Parts Feedback, 2015
The re-design of the 6-inch Mecanums was successful. We ran 1 set all season long and had absolutely no problems at all. The rubber on the rollers will wear out long before the tabs break.
Unread 28-04-2015, 14:05
Dan Petrovic's Avatar
Dan Petrovic Dan Petrovic is online now
Got my degree and ready for more!
FRC #0166 (Chop Shop)
Dan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond repute
I was really impressed with the Versaplanetary gearboxes and especially with how easy it was to swap motors out. We burnt up a few RS-550's this weekend and being able to replace them so easily was huge.
Originally Posted by Koko Ed View Post
The sign applause was definately one of the best moments I had ever witnessed at a FIRST event.
Who knew silence could be so loud?
Mayhem in Merrimack hosts: 2005-2016 - Week Zero hosts in partnership with FIRST HQ: 2014-2016
Unread 28-04-2015, 14:21
Adam Freeman's Avatar
Adam Freeman Adam Freeman is offline
Forever HOT!
FRC #0148 (Robowranglers)
Adam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond repute
VEX needs to find a way to make the Versaplanetary gearboxes weigh essentially nothing...
I mean, they are so versitile and easy to use that when you have (10) 2 stage gearboxes, (2) 3 stage gearboxes on your robot, all of a sudden it starts to get pretty heavy or nearly over-weight.
In all seriousness, we used almost exclusively all VEXpro parts for mechanism gearboxes, bearings, shaft collars, and drivetrain components (belts, pulleys, wheels, etc...). I can't even think of what else to ask for...all the products offer such high quality and versitility for a robot designer.
*Edit - We actually ended up not using VEXpro belts for the drivetrain. We had to switch from the 9mm VEXpro belts to 15mm wide, 5mm pitch Kevlar corded belts from Mcmaster (http://www.mcmaster.com/#timing-belts/=wyasp5) because we were skipping and failing them on our practice bot drive system. Forgot about that. We will not be using the 9mm belts or any non-kevlar belts on our drive systems any more. Just doesn't seem worth it to risk failing a belt and an inopertune time of a competition.
2005 FIRST World Champions (330, 67, 503)
2009 FIRST World Champions (111, 67, 971)
2010 FIRST World Champions (294, 67, 177)
Last edited by Adam Freeman : 28-04-2015 at 16:27. Reason: Forgot about the belt change...
Unread 28-04-2015, 14:36
Andrew Lawrence
Posts: n/a
Take this with a grain of salt based on where I'm from, but the WCP 32DP gears have to be some of my favorite products so far. They make getting a large reduction in a lightweight and compact packaging simpler and more effective than planetary gearboxes (and in my experiences, more reliable). The seamless integration with pinions for the BAG motor, RS775, and RS550 alongside their perfectly chosen gear sizes (in 20, 40, 60, and 80 teeth) make it so that most any mechanism (especially intakes) can be powered off of one or two stages to get the perfect reduction.
These are a product I haven't seen widely used or known about that I feel would greatly help teams accomplish some of their more complex or weight-dependent design goals.
Unread 28-04-2015, 14:45
Bryce2471's Avatar
Bryce2471 Bryce2471 is offline
Alumnus
AKA: Bryce Croucher
FRC #2471 (Team Mean Machine)
Team Role: Mechanical
Rookie Year: 2007
Bryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud of
I have been hoping that a major FRC supplier would start stocking and selling 32dp gears, for a couple years now. I went the whole season without knowing that WCP was doing it.
Thanks for bringing it up, but it's a little too late, since I just came back from the last competition of my high school FRC career.
FLL Team Future imagineers
2010 Oregon State Championships: Winners
2011 International Invite: First place Robot design, Second Place Robot Performance
FRC Team Mean Machine
2012 Seattle: Winning alliance
2013 Portland: Winning alliance
2013 Spokane: Winning alliance
2014 Wilsonville: Winning alliance
2014 Worlds: Deans List Winner
Unread 28-04-2015, 14:38
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
We had several instances of the motor adapters in the Veraaplanetaries slipping on the motor shafts. And yes they were the proper ones, and they were cleaned prior to assembling, properly torqued, and loctite applied.
Unread 28-04-2015, 14:48
Thad House Thad House is offline
Volunteer, WPILib Contributor
no team (Waiting for 2021)
Rookie Year: 2010
Thad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond repute
Our robot was essentially a VexPro demo bot. We used the clamping gearboxes, 4 inch mecanums, gears, VPs, hubs, linear elevator kit, and most importantly ThunderHex.
ThunderHex was probably one of the most impressive things I have seen in FRC in a long time. Bearing slop was a thing of the past. Our practice bot used standard hex on the drive, and our comp bot use ThunderHex. The drive on the comp bot was so much smoother it was incredible. We will be using it for years and years to come, especially since it is cheaper then regular hex from Vex.
The 4 inch mecanums were great. We only had 1 break on the practice bot, and it was broken on arrival. I loved them, but I hope we don't have to use them again (I miss my WCD). But if we do, I trust them, and they were very reliable.
The Linear Elevator Kit was great, at least for the plates. We had issues with the 1/2" OD bearings falling apart, so we had to space out our shuttle a bit more, and go to larger bearings for them. But otherwise they were amazing, and very reliable. No problems at all.
The CIM mounts for the VPs were amazing. We used 1 for our Arm, and 1 for our Lift and they both were solid. Figuring out the best way to cut the CIM shaft took a bit of time, but it wasn't too bad.
All in All, I don't think we had a single problem with any Vex parts this season.
If I was going to make a suggestion, The Ball Shifters could use some improvements. I would love to see a ball shifter designed from the start for WCD, maybe even using the WCP style plates. I love the ball shifter idea, but with how weird the mount is, how much space they take up lengthwise, and cantilevering the gearboxes that far is rough, at least in my eyes.
All statements made are my own and not the feelings of any of my affiliated teams.
Teams 1510 and 2898 - Student 2010-2012
Team 4488 - Mentor 2013-2016
Co-developer of RobotDotNet, a .NET port of the WPILib.
Unread 28-04-2015, 15:01
Michael Hill's Avatar
Michael Hill Michael Hill is offline
FRC #3138 (Innovators Robotics)
Michael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond repute
I don't think we could be much happier with their performance. I don't believe we had to change any of our 4" omni wheels at all (no defense does help the situation). We ran belt for the first time this year, and used the HTD from Vex. Those worked out great. We used the calculator on West Coast Products' website (with the added [I think 0.003"] between the centers). Didn't have any ratcheting issues. We drove the versaplanetary with a BAG pretty hard. We had a lead screw mechanism. We fortunately didn't have any issues with the snap ring in the gearbox from placing axial force on it like other teams. We had to change gear ratios several times, so I got pretty good at disassembling and reassembling them. The only issue I seem to remember was having not enough material in the mounting bolt holes. There are only a few thousands of aluminum with threads (Either 8-32 or 10-32, I can't recall). We started seeing wear on the threads and eventually stripped them out and had to get a new mounting block. I was initially critical about including so many extra pieces with the versaplanetary wishing you could configure what you wanted online to save a couple bucks, but we eventually used some of what we initially considered extra parts, so I'm glad for that.
We did burn out one BAG motor, but we were admittedly pushing it way harder than we should have. MiniCIMs were great. We used them for our strafing and they worked out great. We used a couple of gears that worked out fine. Actually, one of the most useful VEX products we used this year were the Delrin hex spacers. We found ourselves using them in situations where we weren't expecting. Having pre-made consistently sized spacers were pretty handy keeping on hand, and I'll recommend we buy more next year. We did use the nylon versahubs for our drive and they worked out fine, but when we used them on our arm, they didn't work out so hot. There was a little too much play that they allowed so we had to take them off. Lesson learned.
Unread 28-04-2015, 15:04
Mike Marandola Mike Marandola is offline
Lead Bumper Mentor
AKA: Mike Marandola
FRC #0316 (Lunatecs)
Mike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond repute
We used VEXpro 6 inch mecanums and tube axle this year, both with success.
6 inch mecanums: The rollers would occasionally bind up due to dirt and dust getting to the bushings, but that wasn't the wheel's fault and we just had to be conscious of this between matches.
1/2" tube axle: We used the tube axle in conjunction with the AM14U2 and 1/4-20s going through to keep everything solid. The only problem was that it wasn't a consistent diameter along the 3 foot piece. The 1/2" flange bearings that we bought from VP wouldn't fit in some spots. This was easily fixed on the lathe and some emery cloth. We are very pleased with it and would use it again.
#ballshiftsohard
2015 - Pioneer Valley District Finalists/Upper Darby District Finalists/MAR District Championship #1 Seed and Winners with 225 and 203
2014 - Lenape Seneca District Winners/Chestnut Hill District Winners
2013 - Lenape Seneca District Winners/Chestnut Hill District Finalists
2011 - Philadelphia Regional Finalists
2009 - Finger Lakes Regional Finalists
Unread 28-04-2015, 16:27
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Rookie Year: 2013
Clamping gearboxes worked flawlesly for us. Hex bearings were no problem, WCP bearing blocks, etc all worked fine.
The versaplanetary on our elevator started to fall apart though. The locating pins that kept multiple stages' sides in line with each other and made the whole thing look like a ractangular prism started to fall apart, so the point where we put a hose clamp around the gearbox to stop it from jerking violently every time we moved our elevator. When we opened it up we found that the pin was fine, but the hole it went into had become a slot.
I want 3/8" hex sprockets, or at least versahubs! Why are there no 3/8" hex versahubs!?
Unread 28-04-2015, 18:18
cbale2000's Avatar
cbale2000 cbale2000 is offline
AKA: Chris Bale
FRC #0703 (Phoenix)
Team Role: Leadership
cbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond repute
6" Omni Wheels: We used 7 of these on our robots H-Drive this year. It was our first time using Omni Wheels and we were not disappointed, the wheels held up all year didn't have any issues with durability. The fact that the wheels shipped already assembled was also a huge time-saver.
Our only complaint was that we got quite a bit of material buildup (presumably from the carpet and plastic from the ramps) that proved difficult to clean up and negatively affected traction. We purchased a set of replacement wheels and swapped them out at the MSC as a precaution.
Single Speed, Double Reduction Gearboxs: We've used VexPro Ball Shifters before but this was our first time using the single speed gearboxes. The gearboxes held up all season and required no maintenance after initially assembly.
When we assembled the gearboxes, we did notice that one of the three gearboxes had some difficulty going together (the two pieces of the casing would not close all the way). Later after wiring up the gearboxes, we also noticed one of them ran very rough (sounded like grinding gears, and occasionally the gearbox seemed to "catch" on something). Disassembling and reassembling the gearboxes didn't provide a fix to the problem, but after running the gearbox under power for a while, the issue seemed to resolve itself. We're hoping to get the gearboxes apart again now that the season is over and see if we can diagnose the problem.
VersaPlanetary CIM Adaptor: Having had to make our own adapter (out of a solid block of aluminum) last year, the VexPro CIM Adapter is a welcome addition for our team. The weight savings is excellent and it held up surprisingly well to the weight of a MiniCIM cantilevered off the back of it, and along with a 35:1 Versaplanetary, drove our conveyor system without any issues.
Colson Performa Wheels: When building our tote intake this year, we initially used 4" VexPro Traction wheels, direct driven by VersaPlanetary gearboxes with bag motors, to collect totes into our robot. This proved extremely ineffective during our initial tests, so we started looking for other options. We came across the 4" x 0.875", 1/2" Hex bore Colson wheels which seemed like they would be a great fit for our collector (having heard of how great Colson wheels are from other teams for years). While the Colson wheels were far more effective at grabbing totes then the traction wheels had been, they still didn't have the grip we were looking for, and additionally, the wheels started to wear down after our first competition.
We ended up replacing the Colson wheels with 4" Urethane Drive Rollers (60A) from McMaster for our last two competitions (thanks to team 314 for the idea) which worked much better for tote collection.
We have certainly not written off Colson wheels for future projects, but they were not a good fit for our robot this year.
Suggestions:
  • Standardize wheel widths - Our initial robot design called for 6" Traction wheels, but after deciding to switch to H-Drive, we had to widen our drive base to accommodate the slightly wider 6in Omni-Wheels. Ideally, it would be nice if all same-diameter wheels were interchangeable with no modification.
  • Make a shaft spacer that mates on one side to the VersaKey pattern in wheels and gears - I absolutely hate spacers in a drive system; there is nothing worse than having to chase after a dozen tiny rolling spacers when you have to swap out a wheel or fix a chain within a few minutes. Having spacers that mated to the VersaKey pasterns on VexPro wheels and gears would greatly alleviate this issue. I actually attempted to make such spacers myself using our teams 3D printer, but it proved problematic to build without dissolveable support material or hours of sanding off regular support material.
  • It would be great if VEX stocked K1 Chain attachments for 35 chain (and 25 chain if possible). You can buy it from McMaster but it's 3 times more expensive then other sources (which have much slower shipping).
Unread 29-04-2015, 03:18
nathannfm's Avatar
nathannfm nathannfm is offline
AKA: Nathan
FRC #3940
nathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant future
THIS! How am I supposed to use the 3/8 hex bevel gears on a swerve module that has chain to the wheel. 3/8" hex sprockets would save us a ton of time and money.
Why are these not available from vexpro.com and why are they all on backorder, stuff like this makes me nervous about planing to use them in season as much as I would love to try them out.
[2016-20??]: Mentor: FRC Team 3940"CyberTooth"
[2013-2016]: Mentor: FRC Team 365 "MOE"
[2012-2013]: Mentor: FRC Team 3929 "Atomic Dragons"
[2011-2012]: Mentor: FRC Team 365 "MOE"
[2008-2011]: Student: FRC Team 365 "MOE"
[2007-2008]: Student: FTC Team 365 "MOE"
[2005-2007]: Student: FLL Team "The MOEstangs"
Unread 29-04-2015, 04:09
Andrew Lawrence
Posts: n/a
Because they're from WCP, not VEXPro. RC would be the better person to ask, but as I understand it, the two only act as distributors of some of each other's products - they are still their own independent companies (hence why WCP only sells vexpro items and not vexiq or vrc things, and why VEX doesn't sell WCP gears and sensors, among other things).
I'm not too sure about the backorder status (once again RC is the person to ask). Emailing him is the best way of getting information that you don't know, and it seems so many people have questions but don't ask, so please do ask. I'm no official affiliate of the company, but I imagine it's hard for them to know what questions need answering and what could use some clarification if nobody asks them.
  #15   Spotlight this post!
Unread 28-04-2015, 17:14
Anupam Goli's Avatar
Anupam Goli Anupam Goli is offline
PCH Q&A co-founder
AKA: noops
FRC #1648 (G3 Robotics)
Team Role: Team Spirit / Cheering
Anupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond repute
I've gotta say, we've been using VexPro and WCP COTS items more and more lately. We've been on the board with them since 2013, but there were some components that specifically stood out to me this season:
WCP SS gearboxThese gearboxes were really easy to work with. Once we installed them, we just had to spray them with lithium grease maybe once a competition, and that was it. They were easy to use, easy to maintain, and easy to switch motors in and out of. We'll likely be using these guys if we go with WCD-style drivetrains again in the future.
Plastic hex hubs. We used these suckers on our omni wheels. These wheels were live driven and had plenty of weight on them. We didn't have a single one break or cause issues. In a game with actual defense, that may not be the case, but for this year's game, they were cheap and perfect.
There were some things that I'd like to improve, though.
I'm not sure whether it was because of the new Colson mold that included the hub or not, but obtaining Colson Live Hubs this year was kind of a pain. Vex and WCP were out of stock for a majority of the season. Luckily, I remembered that TheRobotSpace existed still, we were able to get the hubs we needed, and quickly (Thanks Clinton Bolinger for the great response time and processing time!). This item may have been more of a niche item now, but 5" and 6" colson wheels still need hubs if we want them live driven.
The only complaint about the Colsons with molded hubs I had was that they seemed to be press-fit for hex shaft, where as the WCP Colson live hubs were loose fit. Sometimes it was a pain to get the smaller colson wheels on and off hex shafts.
It would also be nice to figure out a way to use a CIM or mini-CIM in a VP gearbox without having to cut the shaft down, but that's way easier said than done.
Team 1002: 2008-2012
Team 1648: 2012-2016
Georgia Tech Class of 2016
RIT Graduate Student, CompE
