Go to Post The GDC needs to write the rules once and let the game be what the game is going to be. There's little that's fun about being told exactly how to play with your toys. - Madison [more]
Unread 29-04-2015, 19:08
ToMoPAnae's Avatar
ToMoPAnae ToMoPAnae is offline
AKA: Patrick Fischer
FRC #3620 (Average Joes)
Team Role: Driver
Rookie Year: 2015
ToMoPAnae is a glorious beacon of lightToMoPAnae is a glorious beacon of lightToMoPAnae is a glorious beacon of lightToMoPAnae is a glorious beacon of lightToMoPAnae is a glorious beacon of light
Starting out with Swerve Drive.
I am a student on team 3620, and now that champs are over, we are interested in getting started with learning swerve drive. The problem is we don't know where to start. Does anyone have any advice or suggestions on getting started with a cost-effective swerve drive? We aren't looking for a competition-ready system yet, we just want a lightweight system that we can put on our practice bot to get familiar with the programming. Thanks for any help or assistance you can offer.
Unread 29-04-2015, 19:12
dmorewood's Avatar
dmorewood dmorewood is offline
Lead Designer / Coach
AKA: Drake Morewood
FRC #1218 (Vulcan)
Team Role: CAD
Rookie Year: 2011
dmorewood is just really nicedmorewood is just really nicedmorewood is just really nicedmorewood is just really nicedmorewood is just really nice
Re: Starting out with Swerve Drive.
Andymark sells a swerve drive. You could always look at that for ideas on how to build your own. Or buy one, take it apart and figure out anything you want to change from there. Then build 4 of your own.
Unread 29-04-2015, 19:14
Orionbug's Avatar
Orionbug Orionbug is offline
GO GREEN #YEET
AKA: Enrique Castillo
FRC #3098 (The Captains)
Team Role: Human Player
Rookie Year: 2010
Orionbug is an unknown quantity at this point
I too have been searching around the net looking for swerve drive systems, I found this (http://youtu.be/VRcOsjI2gkE)
It looks like a nice setup and is very simple (even the gear switching) I am looking into using this for summer projects/experiments aswell
_________________________________________
- Pneumatics sub-group
Unread 29-04-2015, 20:03
nuclearnerd's Avatar
nuclearnerd nuclearnerd is offline
Speaking for myself, not my team
AKA: Brendan Simons
FRC #5406 (Celt-X)
Rookie Year: 2014
nuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant future
Oh dear. And I thought ball shifters were bad. Please don't build a shifter that unmeshes and remeshes gears like that video shows. You'll be stripping teeth by match 10!
Unread 29-04-2015, 20:52
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Team Role: Mechanical
Rookie Year: 2013
I had the same doubts. They later completed the swerve without problems (there's a video somewhere), although I don't know if they went thtough build with it.
Ballshifters work fine for the life we expect of them.
AndyMark sells the Swerve and Steer, which is basically everything you need to mechanically build a swerve drive. They were out of stock of assembled kits and shipped some unassembled, but apparently even if they were assembled you had to take them apart and reassemble due to some manufacturing errors and tolerances. Still, to the teams I talked to at champs, they were very easy to implement once you assembled them (buy a couple extra modules).
A lot of people like the Revolution swerve modules sold by team221. They are pretty light, but require you to set up the steering motors and drive motors to transfer power to the module.
If you go custom, be prepared to manufacture all the parts. Design with cost in mind and it won't cost much, but will probably need to manufacture a couple parts. Look around chief delphi; there have been many designs posted over the years.
Go to team 1640's Swerve Central wiki page to learn about their swerves and stuff. It's a great page with lots of resources.
Unread 29-04-2015, 21:07
MaGiC_PiKaChU's Avatar
MaGiC_PiKaChU MaGiC_PiKaChU is online now
Drive Coach
AKA: Antoine L.
FRC #3360 (Hyperion)
Rookie Year: 2012
MaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond repute
We've built some heavy-duty swerve this year, if you want a CAD render PM me!
2012 - 3360 - Junior member
2013 - 3360 - Lead Programmer, Human player
2014 - 3360 - Lead Programmer, Human player
2015 - 3360 - Lead Programmer, Driver
2016 - 3360 - Mentor, Drive coach
InFlight's Avatar
InFlight InFlight is offline
3574 - The King's of Bling
AKA: Jim
FRC #3574 (High Tekerz)
Rookie Year: 2012
InFlight is an unknown quantity at this point
Before starting you'll need to understand the machining capabilities of your team and other available local sources. Do you have CNC or manual
Mills. Skilled machinists on both lathes and mills. Welding or Water Jet? Swerve requires some close machining tolerances to pull off. If you have the some of the capabilities then you can design for what your strengths are. If you have limited capabilities, a purchased solution may be the way to go.
Shifting swerve adds considerable complexity and cost that may not be justified. It's also one more thing that can go wrong. Depending on the game and your strategy it might make sense.
Thank you 2016 Alliance Partners - 948, 1510, 2046, 2521, 2980, 2990, 4911, 4683
Unread 29-04-2015, 21:23
kgargiulo's Avatar
kgargiulo kgargiulo is offline
FRC #4143 (MARS WARS)
Rookie Year: 2012
kgargiulo has a spectacular aura aboutkgargiulo has a spectacular aura aboutkgargiulo has a spectacular aura about
We just finished our fourth year, have run swerve in competition for the last 2 years, and are on our 3rd fully custom design iteration. It is truly a great off season project and I'm glad you're going after it.
In addition to the good hardware- and manufacturing-centric advice so far... don't forget the software. I know we got a lot of help from Bomb Squad getting started on the software and have run with it since then.
We have posted CAD software from (I think) Rev 2 of our swerve on CD. I don't think Rev 3 is posted anywhere yet. We're happy to talk with teams about it. Although I'm posting here I am not thw mentor on our team who's worked with the students on this, and I'd have the students talk to you anyway. PM me if you'd like to talk to our students on the modeling, mechanical, or software side. I've got a similar request from another team and maybe we could coordinate (after AP exams and finals).
Mentor, FRC MARS/WARS 4143 http://www.marswars.org
Mentor, FLL Peoria Montessori 8432
Good judgment comes from experience.
Experience comes from bad judgment.
Unread 29-04-2015, 22:01
InFlight's Avatar
AKA: Jim
Rookie Year: 2012
I actually just saw your 4143 swerve drive in Curie and spent some time talking with your students. From my notes you had the six wire rotary switch with the motor/gearbox on the pivot. Nice approach to eliminate the bevel/miter gears. I think the only thing missing was any speed encoder feedback.
Unread 29-04-2015, 21:57
Orionbug's Avatar
GO GREEN #YEET
Rookie Year: 2010
Like I was saying "Experiment" with similar kinds of drive shifting, not exactly what he was doing. Something that would be a better implementation (I didn't really like the gear switching myself) would be nice.
On a side note:
Making a custom swerve drive over the summer would be a fun project, not as fun as just buying it.
Unread 29-04-2015, 20:51
marshall's Avatar
marshall marshall is online now
My pants are louder than yours.
FRC #0900 (The Zebracorns)
marshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond repute
I can't speak highly enough for 221 Systems' stuff. They are amazing. We used the revolution pro modules this year and they were great. http://www.team221.com
"La mejor salsa del mundo es la hambre" - Miguel de Cervantes
"The future is unwritten" - Joe Strummer
"Simplify, then add lightness" - Colin Chapman
Unread 30-04-2015, 00:21
kgargiulo's Avatar
Rookie Year: 2012
Yes, we are all about #teamsliprings, but sincerely wish FIRST would reinstate the mercotac model as legal. We had double, arguably triple, redundancy in the slip rings we used this year, but they were... not elegant. Until we put them in the 3d printed towers to get some clearance we needed.
We also like the simplicity of the straight gearing (including for encoders). The bag motors and vex planetary gearboxes for steering have worked well for us. One hitch in the gearboxes required a custom fix to overcome a gear alignnent/retention problem (we talked to vex, they endorsed the fix and seemed to be familiar with the problem)
Unread 30-04-2015, 00:24
kgargiulo's Avatar
Rookie Year: 2012
I should add, no chain. At least not on the swerve. We had enough elsewhere.
Our "motor-in-wheel" variant is interesting too. I know we had a module out in the pit on display bur did not run that one in competition.
Unread 30-04-2015, 13:52
TheModMaster8's Avatar
TheModMaster8 TheModMaster8 is offline
Active Alumni
FRC #5492 (Robo Jockeys)
TheModMaster8 is a jewel in the roughTheModMaster8 is a jewel in the roughTheModMaster8 is a jewel in the rough
https://grabcad.com/library/swerve-d...or-frc-robot-1
Look at this one, this was made by my twin brother Tristan, he dedicated 6 months to this and is still make improvements on it (so this isn't the final version, this is also based of Team 16's swerve (which is the godfather to all swerve drive in FIRST) if you have any questions about this file or you don't have access to a 3d CAD program i can post some screenshots, just send me a message.
  #15   Spotlight this post!
Unread 30-04-2015, 14:18
Scott Kozutsky's Avatar
Scott Kozutsky Scott Kozutsky is offline
FRC #0865
Rookie Year: 2010
Scott Kozutsky will become famous soon enough
There are several places you should look for awesome swerves that were not yet mentioned:
1717-IMO best swerve in FRC; light, well driven 2 speed, I don't know of any failures
http://wiki.team1640.com/index.php?t...rain_Team_Page
1640-excellent documentation. You can look up the design process and I believe CAD models all the way from where they started.
http://wiki.team1640.com/index.php?title=Swerve_Central
3928-the pioneers of cim in wheel swerve
http://www.chiefdelphi.com/forums/sh...d.php?t=104504
2451-continued development on neutrinos swerve
http://www.chiefdelphi.com/media/photos/40298
696-new swerve this year, very elegant IMO
http://2015blog.team696.org/?paged=7
aren hill personal swerve
http://www.chiefdelphi.com/media/photos/41030
I didn't link pics directly but you should be able to find some good stuff based on that.
2010-2012 FRC 865 Warp7 Student, Mechanical
2013 FRC 1310 RUNNYMEDE ROBOTICS Student, Mechanical, Design
2014 FRC 865 Warp7 Student, Mechanical, Design
2015 FRC 865 Warp7 Alumni, Mechanical Mentor
