Go to Post Duct tape can fix everything except relationships with other people. - dixonij [more]
Unread 30-04-2015, 00:08
Spoam's Avatar
Spoam Spoam is offline
AKA: Pedro M.
FRC #0955 (CV Robotics)
Rookie Year: 2012
Spoam is a jewel in the roughSpoam is a jewel in the roughSpoam is a jewel in the roughSpoam is a jewel in the rough
Help with state-space controller?
I'm trying to write a full state feedback controller for a DC motor (with a load attached). I derived the same model as 971 with voltage as input, displacement as output and [position, velocity] as the state. I used 971's eigenvalues and model constants because I'm a newbie and neither know how to pick poles myself, nor how to pick weighting factors to do LQR. The simulation I wrote seems to converge fine for a desired position (e.g. [1,0]). However, for a velocity it converges to about 65% of the velocity I want (e.g. a desired state of [x_hat(k), 1] asymptotically approaches [x_hat(k), .65] instead) (and what it converges to depends on the poles, which seems bizarre to me; my intuition tells me <1 eigenvalues should stabilize to 0 not something arbitrary like .35). Anyone know why?
Here's the simulation code I wrote in matlab
Code:
Kt = .498192/85;
R = 12/85/2;
Kv = (17800/60*2*3.141592)/(12 - 12/85/2*1.4);
J = .0032;
G = 11/34;
%^971's values
%time step
dt = .1;
%not affected by anything but input and inertia
A = [0      1
     0 -Kt/(Kv*R*J*G^2)];
%can directly control acceleration
B = [   0
     Kt/(R*J*G)];
%can observe position
C = [1 0];
%put A and B in discrete time space
A_d = expm(A*dt);
B_d = pinv(A)*(A_d - eye(size(A_d)))*B;
%I have no idea how to pick poles
%so here are 971's
P_K = [.6 .981];
P_L = [.45-.07i,.45+.07i];
K = place(A_d,B_d,P_K);
L = place(A_d.',C.',P_L).';
%initialize
x = [0;0];
y = C*x;
x_hat = [0;0];
t=0;
while t<100;
    Rs = [x_hat(1);1];
    u = K*(Rs-x_hat);
    u(u>12) = 12;
    u(u<-12) = -12;
    x_hat = A_d*x_hat +B_d*u + L*(y - C*x_hat);
    x = A_d*x + B_d*u;
    y = C*x;
    t = t+dt;
end;
Also, I imagine to use it as a real controller I would just replace "C*x" with an encoder/sensor value and feed u to the motor controller, correct?
If the code is completely wrong somewhere please tell me
2015 PNW District Champions (955, 1983, 2930)
Co-Creator of 955 OPR
Unread 30-04-2015, 07:05
James Kuszmaul James Kuszmaul is offline
NEFIRST CSA
FRC #0971 (Spartan Robotics)
Rookie Year: 2011
James Kuszmaul has much to be proud ofJames Kuszmaul has much to be proud ofJames Kuszmaul has much to be proud ofJames Kuszmaul has much to be proud ofJames Kuszmaul has much to be proud ofJames Kuszmaul has much to be proud ofJames Kuszmaul has much to be proud ofJames Kuszmaul has much to be proud ofJames Kuszmaul has much to be proud ofJames Kuszmaul has much to be proud of
Re: Help with state-space controller?
The reason for this is that, in order to sustain a constant velocity, the motor will require a non-zero voltage, but when you reach your goal velocity, R - x_hat = 0 and so the output voltage is zero and so the motor will not actually achieve that velocity. In order to handle this, you need to add a feed-forward value to U which is proportional to the goal velocity.
Another trick that 971 has used in the past is, instead of always updating the position goal to be the same as the current position, instead, on each timestep, update the position goal by the velocity goal * dt and make sure that the position goal never runs off too far from the current position.
Code:
A_d = expm(A*dt);
Since you're using matlab, you may as well use the provided c2d function; python has no such function, hence why 971 implemented it themselves.
That is correct.
Nothing strikes me as wrong; I haven't tried running your code myself though.
Good luck getting this working; I had a lot of fun learning this stuff in High School.
FRC971 (Student) 2011-2014
FRC190 (College Mentor-ish) 2014
WPILib Development 2014-present
