Go to Post If you smack the bear with a stick, you'd better be ready for a mauling. - sciguy125 [more]
Unread 01-05-2015, 09:52
Mschmeh144's Avatar
Mschmeh144 Mschmeh144 is offline
Impatient maniac
AKA: Matthew
FRC #0144 (R.O.C.K)
Team Role: Driver
Rookie Year: 2014
Mschmeh144 is an unknown quantity at this point
Scrub friction
Hello all
Just a question
We just ran the first test on our new robot, tote bot,which is set up for tank drive, and it seems to have a lot of scrub friction. I don't understand it too well, so I could use some pointers on how to reduce this.
Unread 01-05-2015, 09:55
Mark Sheridan's Avatar
Mark Sheridan Mark Sheridan is offline
Head Mentor
FRC #3476 (Code Orange)
Mark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond repute
Re: Scrub friction
This is a great guide on this subject:
http://www.chiefdelphi.com/media/papers/1443
Team 3476| Mentor| 2014 - Current
Team 3309| Mentor| 2011 - 2016
Team 766 | Mentor| 2006 - 2011 | Alumnus | 2002-2005
Unread 01-05-2015, 09:57
asid61's Avatar
asid61 asid61 is online now
AKA: Anand Rajamani
FRC #0115 (MVRT)
Team Role: Mechanical
Rookie Year: 2013
Re: Scrub friction
If you are using 4 traction wheels in a aquare or long configuration, consider changing the back wheels to omnis.
<Now accepting CAD requests and commissions>
Unread 01-05-2015, 10:32
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Rookie Year: 2013
Re: Scrub friction
I'm not sure if a tote bot has a front/back orientation.
If the weight is not centered equally over the axles, change the wheels on the axle away from the center of gravity to omnis.
Better yet is to go to a 6 (or 8) wheel drop center configuration. This essentially turns a single long configuration into a number of wide ones.
Unread 01-05-2015, 10:53
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Re: Scrub friction
Here's an updated explanation of the physics based on non-cleated wheels with front and rear chained together.
Unread 01-05-2015, 11:23
Mr V's Avatar
Mr V Mr V is online now
FIRST Senior Mentor Washington
FRC #5588 (Reign)
Team Role: Coach
Mr V has a reputation beyond reputeMr V has a reputation beyond reputeMr V has a reputation beyond reputeMr V has a reputation beyond reputeMr V has a reputation beyond reputeMr V has a reputation beyond reputeMr V has a reputation beyond reputeMr V has a reputation beyond reputeMr V has a reputation beyond reputeMr V has a reputation beyond reputeMr V has a reputation beyond repute
Re: Scrub friction
While that is conventional wisdom the actual physics are that it turns it into a situation were two wheels have a high normal force while the other two have a very low normal force. Note the assumption behind that is that the center of gravity is near the center wheels and not close to one of the end sets of wheels.
All statements made on Chief Delphi by me are my own opinions and are not official FIRST rulings or opinions and should not be construed as such.
https://www.facebook.com/pages/Team-...77508782410839
Unread 01-05-2015, 12:27
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
Rookie Year: 2013
Re: Scrub friction
This is true at constant speed. When accelerating, the normal forces increase on the wheels away from the direction of acceleration. That is, in acceleration, the weight goes onto the rear wheels, and in deceleration the weight goes onto the front wheels.
Unread 01-05-2015, 12:57
Mschmeh144's Avatar
Impatient maniac
AKA: Matthew
FRC #0144 (R.O.C.K)
Team Role: Driver
Rookie Year: 2014
Re: Scrub friction
Here is the bot
Unread 01-05-2015, 14:41
Oblarg Oblarg is offline
AKA: Eli Barnett
FRC #0449 (The Blair Robot Project)
Oblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond repute
Re: Scrub friction
Here is the bot
You're going to need omni wheels on either the front or back to turn that thing reliably.
"Mmmmm, chain grease and aluminum shavings..."
"The breakfast of champions!"
Member, FRC Team 449: 2007-2010
Drive Mechanics Lead, FRC Team 449: 2009-2010
Alumnus/Technical Mentor, FRC Team 449: 2010-Present
Lead Technical Mentor, FRC Team 4464: 2012-2015
Technical Mentor, FRC Team 5830: 2015-2016
Unread 01-05-2015, 17:34
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
Rookie Year: 2013
Re: Scrub friction
For a 12x18" robot going to six wheels would be awful tight unless you went smaller than 4" wheels. I would recommend changing the two at the radio end to 4" omnis to minimize the scrub force resisting rotation, and to maximize the scrub force in resisting strafing motion, especially if it is applied near the CoG.
You may have some swaying motion when you go to two omni wheels, whichever end you put them on. You will probably have more swaying one direction than the other - experiment with this to determine which end should be the preferred "front". As I recall from our Ultimate Ascent 'bot, we did better to push from the solid wheels towards the omnis, but we were not driving the omnis, so YMMV.
I'm curious - you referred to this as a tote 'bot. How are you going to secure the tote to the chassis? One big hole or four little ones?
Unread 04-05-2015, 09:55
Mschmeh144's Avatar
Impatient maniac
AKA: Matthew
FRC #0144 (R.O.C.K)
Team Role: Driver
Rookie Year: 2014
Re: Scrub friction
This robot will have the tote sit on top of it, and connect to the frame of the tote using some sort of easy or quick connections,as I don't want to have to take parts off to remove the tote.there is no bottom to the tote we selected for the robot
We also added a set of omni wheels to the back of the robot. Which did give it some success. It was cruising around the lab this morning, until I floored it and reversed it too hard.
I underestimated the tourqe of the CIM motors we used. Resulting in a bent front axle. That part will be reinforced heavily to prevent damage like that ever again. Here is a photo of the front axle in its bent state
