Security vulnerability in D-Link Routers
I don't know if this affects the FRC control system or not. I'm not at the shop, so I can't check the model # of our radios. Either way, it's FYI for those who may be interested.
http://arstechnica.com/security/2015...ndnet-routers/ http://securityadvisories.dlink.com/...?name=SAP10055 Home and small-office routers from manufacturers including Trendnet and D-Link are vulnerable to attacks that allow attackers anywhere in the world to execute malicious code on the devices, according to an advisory issued over the weekend. The remote command-injection bug affects routers that were developed using the RealTek software development kit. That includes routers from Trendnet and D-Link, according to the developer who discovered the vulnerability. There's no comprehensive list of manufacturers or models that are affected, though more technical users may be able to spot them by using the Metasploit framework to query their router. If the response contains "RealTek/v1.3" or similar, it's likely vulnerable. The remote code-execution vulnerability resides in the "miniigd SOAP service" as implemented by the RealTek SDK. Security researcher Ricky "HeadlessZeke" Lawshae reported it to HP's Zero Day Initiative (ZDI) in August 2013. ZDI, which uses such vulnerability information to block attacks in its line of intrusion prevention services, then reported it to officials inside RealTek. After 20 months of inaction, the HP division disclosed it publicly even though no fix has been released. "Given the stated purpose of Realtek SDK, and the nature of the vulnerability, the only salient mitigation strategy is to restrict interaction with the service to trusted machines," ZDI officials wrote in an advisory published Friday. "Only the clients and servers that have a legitimate procedural relationship with products using Realtek SDK service should be permitted to communicate with it." ZDI officials went on to recommend the use of a firewall to block outside connections. Other researchers said that turning off a router's universal plug and play may also prevent exploits. Update: D-Link has issued an advisory that lists six specific models that are vulnerable to the attack. A Trendnet spokesman, meanwhile, e-mailed Ars to say company representatives have no record of of being notified of the bug. As Ars reported earlier, the report was sent to RealTek. Last edited by Tim Sharp : 01-05-2015 at 20:23. Reason: Corrected spelling |
Re: Security vulnerability in D-Link Routers
The DAP-1522 that FRC uses is not listed.
