Go to Post I'm pretty sure there is a federal sequester on the bandwidth coming out of LSR. - PayneTrain [more]
Unread 02-05-2015, 10:31
jojoguy10's Avatar
jojoguy10 jojoguy10 is offline
Programming/Controls Mentor
AKA: Joe Kelly
FRC #0997 (Spartan Robotics) and FRC #2990 (Hotwire Robotics)
Rookie Year: 2010
jojoguy10 is a glorious beacon of lightjojoguy10 is a glorious beacon of lightjojoguy10 is a glorious beacon of lightjojoguy10 is a glorious beacon of lightjojoguy10 is a glorious beacon of light
Advanced Labview Technique
Hey everyone,
I need a bit of help.
For the summer, I would like to start working on an autonomous programming program that uses icons that can be manipulated to mimic the actual robot moves. I've seen one or two that are like this, but they're written in Java.
I'm trying to figure out a way to have a user "drag" a picture around on a canvas, and have the VI know where that picture is in 2D space.
Thanks!
Unread 02-05-2015, 14:58
wt200999's Avatar
wt200999 wt200999 is offline
Texas Instruments
AKA: Will Toth
FRC #3005 (Robochargers)
wt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud of
Send a message via MSN to wt200999
Re: Advanced Labview Technique
If you go search around at the NI LabVIEW forums or Lavag you can usually find some good gems like this one.
Programming in LabVIEW? Try VI Snippets!
FIRST LEGO League 2004 - 2005
FRC Team 870 Student 2006 - 2009
FRC Team 3005 Mentor 2013 -
Unread 02-05-2015, 16:36
jojoguy10's Avatar
AKA: Joe Kelly
Rookie Year: 2010
Thanks! I'll post on those forums and see what I get!
I like that gem too. I'll check it out as well.
