Re: Sheet Metal Fabrication vs. Using Channel
All he is saying is that if you take weight from the chassis and put it into a system that is even half an inch higher, you have raised your COM. Depending on your robots design, this may not be an issue.
Oh, okay.
It would depend on the game more or less. Sheet metal allows much more flexibility in shape to allow the robot to better fit the game piece(s). If it's a game heavy in defense, I would want the sturdiest bot on the field to withstand pushes of other bots and push others with ease, not having to worry about any weak points whatsoever.
Well, yes, but you could just lose the weight completely and not even put it into a different system. You would just end up with a lighter robot in general.
...and then, if you are concerned about being at maximum weight (perhaps you want to maximize traction) you have the ability to put additional weight exactly where you want it to create the best result.
The vast majority of sheet metal is done with 5052-H32 alloy aluminum due to how easy it is to bend. This ease of bending comes at a strength cost. (Matweb reports 13 ksi for 5052 and 40 ksi for 6061-T6). More material is then required to make the sheet metal design strong. I'd be very surprised if you could make a sheet metal drive base that is as strong and light as a well designed tube stock drive base (and I've designed a number of sheet bases). |
What about milling/laser cutting lightening patterns into channel stock?
Completely doable. When I was on 2220, we did waterjet triangle cutouts on 4" channel in 2011, circular cutouts in 2012, and then we switched to tube for 2013 and 2014, which had rounded rectangular cutouts. Only had strength issues in 2012, and that was because of other stupid design choices. 2014 we had some of the most aggressive drive train lightening I've ever had manufactured and we had precisely zero issues with our drive train.
Channel and angle are certainly accessible to more teams; We don't have any real ability to work sheet metal efficiently and effectively.
Most of the places that I have seen sheet metal used effectively that I could not even imagine how to do with angle/channel (short of a whole lot of welding, and reducing strength) were in the form of manipulators, for example some relatively flat claws with rollers between the two sheets such as were used by several ball pickups for Aerial Assist and a number of RC grabbers for Recycle Rush, and long arms with lots of lightening that looked almost like cantilever bridges until you got a bit closer. Most of the chasses based on sheet metal appear to be executable in angle or channel extrusion for not a whole lot of additional weight, though I will admit that these are appearances, and quite possibly deceiving. |
#10
NOTE: the COM in my profile picture
you may be correct in the pressure needed to distort the metal (I don't have SolidWorks on this computer so i can't check) though this is when the metal is still in it's flatted form, my Dad is a civil engineer and I've asked him on shapes that would bare loads of weight, if you ever see a 'I' beam holding up a floor or roof you can see that vary little metal is required to hold a lot of weight, this is due to the form it had ( |-| ) <-- shape of an I-Beam) The flat side of this beam give the middle layer it's required strange as it distributes the force being applied to it, the same goes for sheetmetal, if i have my flat piece of metal and apply said amount of force what i would get would be a traditional bend, how ever if i took that flat piece of metal and Bent bother sides so that it was making an ( [ ) form, and now tried to bend it with the same amount of force, you would see that the metal would no longer bend due to the extra support given off by the two linear walls, this is why support beams are in shapes of U's, I's, T's and L's, also triangles (but thats a completely different level of supports) if i remember correctly 9 so don't take this last part as fact... i believe it requires the for needed to bend the flat plate plus the force required to bend the two walls hight wise. all in all it is definitely a much more rigid way of making a robot base And this time it's 3:27 AM!! |
#11
Now, whether or not this is race to the top is in fact advisable, practical, or even desirable for your robot and team is a whole other matter. Resource sets, integration with the rest of the robot, ability to work the fabrication process into a build season, factors of safety and how far you want to go with them on the most important robot subsystem, ease of sourcing appropriate materials, and so on are all valid considerations, much moreso than squeezing the last couple tenths of pounds out of the drivetrain. My team does sheet metal drives and plans to continue to do so for a number of reasons, but pursuit of absolutely optimal strength/weight ratio is not of of them. I'm sure 971 has similar reasons. If you want to learn more about the complex ways in which sheet metal parts can interact to add strength to a chassis, I suggest checking out some of 971's drive bases. Some very impressive work. Last edited by Joe G. : 06-05-2015 at 06:20. |
#12
as for ease of fabricating, I would agree with you in saying that it is much more time consuming if you don't have a laser/water cutter or CNC machine, and even if you do it still would take much more time then extruded tubing, that much i do not disagree with you on. |
#13
-Adrian Last edited by Adrian Clark : 06-05-2015 at 13:09. |
#14
You might want to ask your father why he uses I-beam and channel and if he (an other Civil Engineers and Architects) uses other profiles. The industrial buildings that I work in (manufacturer of large electrical equipment) have all sorts of square, rectangular and round steel tube, as well as I-beams, being used as pillars to support the roof structures. This complex of buildings has been expanded at least 4-6 times over the last 30 years. You can only compare the weight of your robot built from tubing to a sheet metal one designed to same specification if both designs have been optimized properly for the stresses that they will experience and to minimize weight. I suspect that this optimization exercise is beyond the capabilities of most FRC teams since it would involve using tools such as finite element analysis and a very thorough modeling of the stresses that will be experienced by the structure. While you know your robot made from tubing was overweight, you do not know if your sheet metal CAD design is strong enough since, I presume, it was never built. Quote:
#15
Drive bases have a lot of mixed loads. Cantilevered wheels put a torque on the tubestock. Even drive bases which support both sides of the wheel shaft have torques put on them when one corner lifts up on something, or you have high lateral acceleration. I-beams are very strong in the direction of the I, not in the orthogonal direction, and definitely not in torsion. Check the torsional strength of an i-beam. Drive bases aren't their target application.
I challenge you right back to draw up a sheet drive base and a tubestock drive base and use CAD to weigh both of them. I'm willing to bet you can get the weight of the tube stock drive base significantly lower (a couple pounds) than the sheet base for a comparable strength. I've been comparing our chassis weight against 254 and 973's for years, and they have consistently come up a couple pounds lighter than ours. With sheet metal, there is a minimum flange length. If you are going to make a structure (like we do) which is a tube holding your wheels, you need 3/8 - 1/2" of material on each side of each bend. That's 4" of material just in the corners, not including any material used to connect those sides together. Overlapping flanges to attach 2 pieces of sheet together just add to that number. Compare that to the 6" of tube perimeter in a 1x2 that is traditionally used on a WCD, and you are going to have a lot of trouble doing better than the 1x2. We do a sheet metal drive base because we have sponsors who are sheet metal shops and we know how to work with it. We can design in our superstructure mount points and bumper mounts, and get a bunch of parts back while we continue designing the superstructure that only need to be riveted together to have a robot. I really love our drive bases, but getting the weight down that last little bit is one of those things that we struggle with and end up just giving up on. |
