Re: Design Feedback?
the critical areas. Thanks a lot for the help! |
As far as critique goes, what does the "spool" of your winch look like (from a size perspective). I know that 20:1 for a 2" Diameter spool was just about right for a fast lifter that would meet your desired rating. What DIA are you using for your spool? I too am a bit worried about the cantileer of the spool driving element as shown. How is it supported? Also, will this be another overconstrain on that shaft? |
Seeing I am electrical and controls...
How 'bout an encoder mount on the output shaft? Also at that gear ratio, the lift will backdrive very easily, so you may wish to look at ways to add a brake and a brake release mechanism. |
Yeah we were planning for that since the start of the season, but we never got to it for the lift. Even if its included, I don't think we will have the time to make use of it for automated actions, but If our programmer is confident, then ill go ahaid and add it on. Speaking about back drive, I'm still trying to find something like a break, ratchet, etc. Worm gear is kind of debatable for us since our original lift design used one, but slight miss alignments and improper lubrication caused huge amounts of friction. If anyone can give me some ideas that would be awesome.
We used one this year and it went perfectly. Just stick a piston on the part that would normally connect to the bike handle and you're good to go. I believe we used an Avid BB5 or Avid BB7.Mounting it is a little tricky, but the mounting specs for disc brakes are actually listed online. |
Keep in mind that you'll be stalling the gearbox motors, so keep your current draw well below 40 amps. I wouldnt worry about CIM motors overheating, but breakers like to blow if you keep them hot for a while. |
The versaplanetary gearboxes have two bearings on the output shaft, so anybody who supports the vp output shaft with an additional bearing is locating the shaft in three places. We ran setups with four bearings on the same shaft both this year and last year with no problems, including a bearing that was pressed into a welded sleeve that couldn't have been extremely accurate. I'd guess we can get away with this because of the fit between hex shafts and bearings and the clearance holes for standoff bolts. A #10 is a slip fit in a .1875" hole, so it has almost .01" of slop in the recommended .196" clearance. I'd also assume that the hex bearings which tend to come in a little oversize are also pretty forgiving. |
In general, we have found that once you hit the third bearing, in a third part, you get reduced efficiency, and four is a death sentence. The farther apart the bearings are, the less of an issue this is (I.e. if you have a 24" long shaft, you can probably do two bearings per side). If you need to use more than two bearings per shaft, it can be done, but you need to make an extremely deliberate effort to ensure they are all aligned. In our drivetrain, our gearbox has two bearings, and then the output shaft goes through a third bearing in our tube. We use counterbored standoffs to hold the two gearbox plates captive relative to each other, so those two holes are as aligned as possible. We also counterbore the output bearing so it sticks out of the gearbox. This lets us tuck the bearing into the hole in our drive tube - this hole is cut through both sides of the tube and thus the third bearing is mounted through it as well. When we go to this much effort, we don't run into problems. Quote:
I think the friction he is talking about isn't just the simple contact friction between the carriage and the channel, but the friction caused by misalignment between the two channels. If your chassis / structure isn't rigid enough, load on the elevator will cause some degree of flex between the two channels, which leads to more friction force. It's not something to be written off, certainly. Good design can help keep a chassis rigid and elevator beams roughly coplanar.
#15
