Go to Post What really drove us was not our achievements, but our failures. - BEEKMAN [more]
Unread 05-09-2015, 11:02 PM
tahmid0517's Avatar
tahmid0517 tahmid0517 is offline
AKA: Tahmid Sheikh
FRC #5036 (The Robo Devils)
Rookie Year: 2015
tahmid0517 is an unknown quantity at this point
Help with Eclipse in Linux?
I followed all the steps on the WPI page to to get started wih FRC Java Programming,including installing all the development tools and the FRC plugin, but when I go to create a project, I don't have the option of creating a WPI Robot Project.
Unread 05-10-2015, 12:05 AM
bludeath's Avatar
bludeath bludeath is offline
AKA: Gabriel Finke
FRC #4565 (Skyline Coyotes)
Rookie Year: 2013
bludeath is a jewel in the roughbludeath is a jewel in the roughbludeath is a jewel in the rough
Re: Help with Eclipse in Linux?
What version of Linux are you running? I'm personally running Ubuntu 14.04 with eclipse along with the java plugin.
Unread 05-10-2015, 02:21 PM
legts legts is offline
Autonomous Queen
FRC #2399 (The Fighting Unicorns)
Rookie Year: 2012
legts is an unknown quantity at this point
Hi! What version of Linux do you use? I'm running RHEL and it is working fine for me. I had some issues getting familiar with Eclipse but none like the one you are describing. What steps do you take to create a new robot project? (Aka what do you click on in your quest to make a new robot Java project)
Programming Captain on team 2399 for the 2016 season.
Programmer on team 2399 The Fighting Unicorns since 2014!
Engineering Inspiration Award GPR 2015
Semi-finalist Buckeye 2015 (thanks 4269 and 1987!)
Unread 05-10-2015, 02:35 PM
tahmid0517's Avatar
AKA: Tahmid Sheikh
Rookie Year: 2015
I'm using elementary os. I click on new>project to create a new project but I don't get the option of creating a robot project. I get the option creating a java project but not a wpi robot project.
Unread 05-10-2015, 02:42 PM
Autonomous Queen
Rookie Year: 2012
Click on new, then project, then Other, which will bring up a window. Scroll down and maximise the WPI Robot Java window, then click on Robot Java Project.
Unread 05-10-2015, 03:27 PM
krieck's Avatar
krieck krieck is offline
AKA: Keith
FRC #2846 (Firebears)
Rookie Year: 2012
krieck is an unknown quantity at this point
I have Eclipse/WPILib installed on Ubuntu and also on Elementary OS. Both work fine for me.
My first guess is that the plugin didn't install correctly. Plugin installation should have created a directory in your home directory called "wpilib". Also, try going to the Help menu and selecting "Installation Details", which will pop up a dialog window. Under the "Installed Software" tab, you should see "Robot Java Development". If "wpilib" or "Robot Java Development" are missing, you should revisit the installation procedure.
Unread 05-11-2015, 06:27 AM
AverageGuy AverageGuy is offline
AKA: Jim Lynch
FRC #4080 (Reboot)
Rookie Year: 2013
AverageGuy is an unknown quantity at this point
When I click on File/New/Project I see the following in Eclipse Luna:
If you don't then I agree that for some reason your plugin didn't install correctly.
Jim
Unread 08-08-2015, 08:12 PM
SamcFuchs's Avatar
SamcFuchs SamcFuchs is offline
Programmer
AKA: Sam Fuchs
FRC #0236 (TechnoTicks)
Rookie Year: 2014
SamcFuchs will become famous soon enoughSamcFuchs will become famous soon enough
Click File > New > Other > (WPILib Robot Java Deveopment) > Robot Java Project
Not just Project. Also, ctrl+n should get you there.
