Go to Post Neat! I like when things break, it's educational! - s_forbes [more]
Unread 11-05-2015, 20:22
Wawa's Avatar
Wawa Wawa is offline
Wawa
FRC #3659 (Mighty Patriots)
Rookie Year: 2012
Wawa is an unknown quantity at this point
Summer ideas for new programmers?
Ok, so I learned (very basically) how to use LabVIEW this year as my team's default programmer and I want to improve for next year. I used a lot of basic code and copied a lot from examples other teams had, and I'd like to know what would make really good practice programming projects. I won't have access to my team's robot, so I'm really looking for projects that will help me get more familiar with different functions and possibly make more advanced code.
Also, I found one new recruit who is interested in programming, but she's more interested in written code. I can teach her the little that I know in LabVIEW, but I also wanted to be able to help her try out Java. We're planning for her to be the main programmer after I graduate next year, so any ideas about how I can start her off and which language I should use?
Our Plan B is our Plan A.
Unread 11-05-2015, 20:45
jgrindle's Avatar
jgrindle jgrindle is offline
Losing Sleep
AKA: John Grindle
FRC #5122 (RobOTies)
Rookie Year: 2015
jgrindle will become famous soon enough
I am currently our teams programmer. We are a text based team, we have experience with java and c++. I personally love text based compared to LabVIEW. But we(team 5122) might have a solution for you dilemma, EasyJ4FRC. This program acts as a logic based programming, except it outputs in Java. Our mentor created EasyJ and is now having me with on it, trying to fix bugs and add cool features. I suggest you and your recruit check it out at http://easyj.team5122.com/
FRC 2015 Season: Programmer, Electrical, PIDTuner, Safety Captain
FRC 2015 Off-Season: Programmer, CAD Designer, Driver, Drive Team Coach, Electrical, Mechanical, PIDTuner
Unread 11-05-2015, 21:07
Re: Summer ideas for new programmers?
I'd suggest that you use the examples and simulator to work on more sophisticated robot techniques. You can do things like make PID loops to drive a fixed distance from a wall, integrate sensors and more advanced techniques for both auto and tele. You can debug, profile, and get more comfortable with the programming tools in LV this way as well.
Similarly, look over the Java examples and build some projects with it, possibly using the linux based simulator. This will also allow the two of you to compare the languages, the libraries, the learning materials, and benefit from the combination. If you have questions, feel free to post.
Greg McKaskle
Unread 11-05-2015, 21:27
Wawa's Avatar
Wawa
Rookie Year: 2012
Thanks!
I really, really, really like EasyJ. I just played around with it and it's very simple and I'm definitely going to use it!
I'm also going to look through the examples for LV again. I tried using some during build season when I was just learning, but I didn't even know how to find the little blocks. As for the simulator, how do I get that?
Unread 12-05-2015, 08:08
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Rookie Year: 2013
To learn programming, you can write any sort of code you want - and that's what I suggest - writing something that you want to write. Desire to stick with it and make it work because you want a specific functionality is a far better motivator than "learning" for the vast majority of people.
Robotics is a bit different than most programming people do today due to the level of feedback required. I suggest that you get or build a robot of some type, with a drive system, some sort of manipulator, and some sensors. Programming it to do complex tasks at a single button (or better yet, going to full autonomous) will improve your skill at programming robots more than coding a video game, editor, or a business or math application. Even if you have to do this in a different language, the patterns and skills you learn will carry over to other languages.
Unread 12-05-2015, 09:03
mshafer1 mshafer1 is offline
Programming Mentor
AKA: Matthew Shafer
FRC #3937 (Breakaway)
mshafer1 is an unknown quantity at this point
There is also a lot of documentation on LABview and tutorials at http://www.ni.com/academic/students/learn-labview/ although this is a more generic set (not specific to FRC) I learned a lot about how LABview works by going through these.
