Go to Post Dave Lavery says it's pimp? I don't care if the Pope says it's pimp, it still doesn't pass inspection! - MissInformation [more]
Thread Tools Rating: Thread Rating: 10 votes, 5.00 average. Display Modes
Unread 11-05-2015, 23:47
cxcad cxcad is offline
FRC #1683 (Techno Titans)
Rookie Year: 2012
cxcad will become famous soon enoughcxcad will become famous soon enough
pic: Manually machinable one-speed gearbox
Rookie Year: 2012
Unread 11-05-2015, 23:48
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Team Role: Mechanical
Rookie Year: 2013
Re: pic: Manually machinable one-speed gearbox
Looks solid. What are the two small holes in the center for? How is the gearbox mounted?
<Now accepting CAD requests and commissions>
Unread 11-05-2015, 23:53
Rookie Year: 2012
The two center holes are for the encoder plate, which mounts on the motor side. This is mounted to the frame by using the bolts that go through the spacers.
Unread 12-05-2015, 00:05
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
Rookie Year: 2013
Thsoe bolts look like they're more than 2" apart vertically, so it's difficult to mount to 2x1 with that.
How is the encoder attached to the shaft?
Unread 12-05-2015, 00:09
bkahl's Avatar
bkahl bkahl is offline
Make Champs Great Again
AKA: Bailey Kahl
FRC #0125 (NUTRONS)
Rookie Year: 2013
bkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond repute
Almost impossible to do chain in tube in 2x1 anyway. It's probably designed for 3x1 or larger.
Team 125
College Student/Whatever Brando says
Team 195
Alumni
Facebook
EWCP
Unread 12-05-2015, 00:10
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
Rookie Year: 2013
Originally Posted by bkahl View Post
Almost impossible to do chain in tube in 2x1 anyway. It's probably designed for 3x1.
I think it's possible. We were planning on converting our competition bot to it in the offseason.
Using something like versablocks as bearing blocks allows for more than ample space in the 2x1 for 2 16t #25 sprockets side-by-side.
So this is mounted using the bolts along the bottom? I feel like that could cause the gearbox to flex back, but I could be wrong (something like that happened to our 2012 robot, although it was a slightly different situation).
Unread 12-05-2015, 00:29
Rookie Year: 2012
The bottom bolts. I don't flex should be an issue, because motor load isn't that cantilevered
Unread 12-05-2015, 00:34
Gregor's Avatar
Gregor Gregor is offline
#StickToTheStratisQuo
AKA: Gregor Browning
Rookie Year: 2012
Gregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond repute
It looks like you're trying to direct drive a wheel with this. 11:64 is far too fast unless your wheel diameter is significantly smaller than 4".
What are nationals? Sounds like a fun American party, can we Canadians come?
“For me, insanity is super sanity. The normal is psychotic. Normal means lack of imagination, lack of creativity.” -Jean Dubuffet
"Insanity is doing the same thing over and over again and expecting different results." -Albert Einstein
FLL 2011-2015 Glen Ames Robotics-Student, Mentor
FRC 2012-2013 Team 907-Scouting Lead, Strategy Lead, Human Player, Driver
FRC 2014-2015 Team 1310-Mechanical, Electrical, Drive Captain
FRC 2011-xxxx Volunteer
How I came to be a FIRSTer
<Since 2011
Unread 12-05-2015, 00:43
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
Rookie Year: 2013
~16fps free speed according to JVN calc. We ran that last year.
Unread 12-05-2015, 01:00
Knufire Knufire is offline
Rose-Hulman Institute of Technology
Rookie Year: 2010
Knufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond repute
Actually a COTS product: http://www.team221.com/viewproduct.php?id=133
Team 469: 2010 - 2013
Team 5188: 2014 - 2016
NAR (VEX U): 2014 - Present
Unread 12-05-2015, 01:39
Munchskull's Avatar
Munchskull Munchskull is offline
CAD Designer/ Electrical Consaltant
AKA: Anthony Cardinali
FRC #0997 (Spartan Robotics)
Team Role: CAD
Rookie Year: 2013
Munchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to behold
Could some one explain how you get the chain in the tub. To me it seems like it would be a complex process.
“In theory, theory and practice are the same. In practice, they are not.” ― Anonymous
Anthony Cardinali
4th year of FRC
Class of 2017
Unread 12-05-2015, 01:59
Rookie Year: 2010
Originally Posted by Brendan Browne
Sprocket layout:
Back wheel = Sprocket 1A
Center assemble= Sprocket 1B & 2B
Front wheel= Sprocket 2A
Chains were slightly loose which allowed for easy line up (once its in there the chains rub on the top/bottom wall but they can't go anywhere.
Spacers were round OD so the only hex profile you needed to worry about was lining up the hex axle and hex sprockets. Super glue only held the sprockets in for assembly.
Step 1: Cut Chains to length and assemble the loops (no master link)
Step 2: Super Glue spacers to sprockets creating your internal assembly (118 uses double sprockets with build in extrusions on the side for a single assembly) Double sprockets were not glued together.
Step 3: Press bearings into tube
Step 4: Put sprocket 1A on your back chain and drop through the end of the tube. Used a magnet to help slide the assembly down the tube. Spacers were undersized so it was easier to drop between the edges of the bearings. Used long small screwdrivers to help line it up. Once in line, axle gets put through.
Step 5: Using a machined pocket above the middle assembly, drop the first half of the sprocket assembly into the middle (pairing with the chain you just put in). Throw an axle/rod through to hold the 1B for the next step.
Step 6: Repeat step 4 but this time using sprocket 2A and the second chain.
Step 7: Drop sprocket 2B into the center assembly and slide the axle through both gears.
Now all 4 sprockets, 3 axles, and 2 chains are assembled. Move on to mounting the gearbox and wheel assemblies.
tl;dr, it's not easy.
Unread 12-05-2015, 02:15
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
Rookie Year: 2013
That is one way to do it. I talked to a couple teams at champs (can't remember which) and from what I heard from them it was a largely painless process after the initial installation. Could be something to start a thread about.
I'm sure that no matter which way you do initial installation it's going to be harder than traditional WCD, but the upkeep should be simple.
  #15   Spotlight this post!
Unread 12-05-2015, 12:13
Bryce Paputa's Avatar
Bryce Paputa Bryce Paputa is offline
FF TSL: Frog Farce
FRC #0503 (Frog Force)
Bryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond repute
May have been us, we were in your division. We did this with 17t sprockets in 2x1x.125 and after installation we had very few issues. One thing to remember is that if you use 17t sprockets then you either need to have a half link or have a center to center distance that is divisible by .125 but not .25 (I think, you should check the math on this).
