Go to Post ...When you use ";"s instead of "."s; darn Java; - machman-2823 [more]
Unread 12-05-2015, 21:54
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Rookie Year: 1999
Tom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond repute
Where to find the updates and driver station for LabVIEW 2014?
I'm trying to set up a laptop with the software capable of programming the 4 and 8 slot cRIO's. So I'm looking for a copy of Labview 2014, and the FIRST updates + the driver station. Anyone have links for it? Most all the NI links point to 2015 (even the ones labelled 2014).
Unread 13-05-2015, 13:23
Bpk9p4's Avatar
Bpk9p4 Bpk9p4 is offline
FRC #1756
Rookie Year: 2010
Bpk9p4 is on a distinguished road
Re: Where to find the updates and driver station for LabVIEW 2014?
You can get both from here
https://decibel.ni.com/content/docs/DOC-34731
I am not sure if it will work with the cRIO but that is what teams used this year for the roborio
Unread 13-05-2015, 14:15
wt200999's Avatar
wt200999 wt200999 is offline
Texas Instruments
AKA: Will Toth
FRC #3005 (Robochargers)
wt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud of
Send a message via MSN to wt200999
To be clear, are you referring to the software from the 2014 FRC season?
In 2014 we used LabVIEW 2013, this year we use LabVIEW 2014 (called FRC 2015 listed on the NI site pointed to in the above post by Bpk9p4).
Programming in LabVIEW? Try VI Snippets!
FIRST LEGO League 2004 - 2005
FRC Team 870 Student 2006 - 2009
FRC Team 3005 Mentor 2013 -
Unread 13-05-2015, 17:17
ozrien's Avatar
ozrien ozrien is online now
Omar Zrien
AKA: Omar
ozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant future
Hey Tom, I still have the install disks for Aerial Assist, if you want to borrow PM me or stop by the office. Not sure about the mid-season updates though, I can't find those on my PC.
Unread 13-05-2015, 19:02
Tom Line's Avatar
Rookie Year: 1999
Yep - I'm referring to the software we used for Aerial Assist, that is still compatible with the 8 slot cRIOs. Does anyone have the driverstation / updates on file somewhere?
Unread 15-05-2015, 08:10
Doug Norman's Avatar
Doug Norman Doug Norman is offline
no team (National Instruments)
Doug Norman will become famous soon enoughDoug Norman will become famous soon enough
I'll look into putting the LabVIEW for FRC 2014 installers on our web site. Of course you will still need your serial number to license the install.
Update - I found that we have the FRC 2014 installers available here.
Look for these links:
Download the 2014 NI Software for FRC
Download the 2014 Update Suite
Doug Norman
