Go to Post You don't have to build a winning robot to build a team, but you won't build a great team unless they are striving to build a winning robot. - Richard Wallace [more]
Unread 14-05-2015, 19:11
Dave_4539 Dave_4539 is offline
AKA: David
FRC #4539 (KAOTICRobotics)
Team Role: Driver
Rookie Year: 2014
Dave_4539 is an unknown quantity at this point
Can you still program a cRIO?
Our team has been talking about some off-season things to do this year. We currently have two roboRIOs, but would like to keep one of them on our Recycle Rush robot. We have two cRIOs currently not in use, and we would like to utilize them if possible. We program in LabView. Any help would be greatly appreciated!
Unread 14-05-2015, 19:14
Beaker's Avatar
Beaker Beaker is offline
624 Programming Alum
AKA: Justin K.
no team (No Team)
Rookie Year: 2013
Beaker is a splendid one to beholdBeaker is a splendid one to beholdBeaker is a splendid one to beholdBeaker is a splendid one to beholdBeaker is a splendid one to beholdBeaker is a splendid one to beholdBeaker is a splendid one to behold
Re: Can you still program a cRIO?
You should still have the option in labview to make a cRIO project when you click File>New Project.
EDIT: They need to be 4 slot cRIOs to work
Team 624 (Student) 2013-2016
BBQ FIRST Creator
Unread 14-05-2015, 19:38
For eight-slot cRIOs, you should use the non-expiring tools that came with it in 2014 season.
Greg McKaskle
Unread 15-05-2015, 14:57
Bonzabonz Bonzabonz is offline
FRC #5052 (RoboLobos)
Rookie Year: 2014
Bonzabonz is an unknown quantity at this point
Yes you can, in fact our team built a robotic carnival game to use for outreach events which wound up being a great success. We just used the 2014 version of LabVIEW to program the cRIO. I believe that there is some way that you can specify the target as a cRIO as opposed to a RoboRIO somewhere in the build specifications to make it work with the 2015 version, but I haven't tested that out for myself.
Unread 22-05-2015, 18:45
BenGuy's Avatar
BenGuy BenGuy is offline
Co-Driver - 3641 - Flying Toasters
AKA: Ben
FRC #3641 (The Flying Toasters)
Team Role: Operator
Rookie Year: 2014
BenGuy is a glorious beacon of lightBenGuy is a glorious beacon of lightBenGuy is a glorious beacon of lightBenGuy is a glorious beacon of lightBenGuy is a glorious beacon of lightBenGuy is a glorious beacon of light
Yes, you can as far as I know, our team plans to continue using them during the offseason to give to members to try programming. We program in C++ and it still works fine.
Ben Wolak
The Flying Toasters Website
Team YouTube
Team Twitter
The real problem with computers is that they do what you tell them to do, not what you want them to do.
Unread 27-05-2015, 13:38
jtrv's Avatar
jtrv jtrv is offline
github.com/jhtervay
AKA: Justin
FRC #2791 (Shaker Robotics)
Rookie Year: 2012
jtrv is a name known to alljtrv is a name known to alljtrv is a name known to alljtrv is a name known to alljtrv is a name known to alljtrv is a name known to all
We have our 2014 bot running. We run it on a separate laptop than our 2015 stuff, just to avoid any weird and annoying conflicts.
We use Netbeans for any code changes, like in 2014, and we have the 2014 Netbeans plugins, along with the 2014 driverstation and whatnot.
We were able to install everything with mild inconvenience, but nothing that required a load of time to fix. Downloading the 5gb NI update was a load of time though..
