Thread Tools |
Rating:
Display Modes |
Re: [FRC Blog] Two Championship Survey Results and Path Forward
In 2014, FTC had its pits about where Archimedes pits were in 2015, and had playing fields on the dome floor. So, this significant separation is new.
Because the survey asked respondents to choose their top N items. The decision to split the Championship has only minor effects on cost for most teams.
This also brings up an interesting point: Had this survey been given out before the announcements, I guarantee we'd see a different set of responses, and some different priorities (cost reduction would've been higher priority, and one true champion would've been less important). I hope the committee will come up with a solution for region locking so that I don't have to go on vacation to California and Washington to see some inspirational teams and my skunk buddies... |
- Cost doesn't matter to me. - This split doesn't affect my costs as significantly as it affects other things I want to check off. - If the CMP doesn't give me 1, 2, and/or 3, cost doesn't matter because because I'm not going to fundraise (even some minimum reasonable cost) to go--e.g. I'll go to another regional, or save it for IRI, or build a better robot, or put it in the bank, or... - And probably at least several other reasons. No need to jump to conclusions about respondents. |
I'm working of the assumption that they are using the survey to see what they can change in both the near and far future to get people what they want. Money being 5th sounds like costs can go up for other things which for many they can't.
55/88 = 62.5, neutral voters were removed from the total as well. So 62.5% of respondents who did not answer neutral were in the opposing range, which is exactly what his statement said.
#11
I see. But that doesn't actually represent the response to the survey. That's only a poll of those who are biased one way or the other. It's not like the neutral opinions don't count.
#12
We can speculate all we want about the opinions of the people who didn't vote, but there's nothing to delineate the reasonableness of those speculations. It's a measure of mandate that's intended to elucidate the misleading nature of the "average" purported in the blog. As yet we don't know of any way to properly center the data (the actual average of 1 to 10 is 5.5, whereas neutral is a "5"). Directly calculating the relationship between those who fall on one side or the other of neutral provides another sort of insight into the flaw in the scale. |
#13
However, unless you have a mathematical or industry standard to support the conclusion that 62.5% is more misleading than 4.45, I disagree. At the very least, Richard actually told us directly what his calculation was in the midst of a discussion that already took issue with the neutrality of the 5 average. Frank left his misleading calculation to be discovered, which is a huge problem in itself. I don't think that this was intentional by Frank. A very big part of this problem is that this is an intuitive scale on its face, but he should've done his homework before making a highly misleading and unqualified statement that included both the term 'average' and the term 'neither oppose nor favor'. The correct 'intuitive' truth that we're looking for--i.e. what the average looks like when centered about neutral--is somewhere between Richard's calculation and Frank's average. There's no way to access it. Do you have a better method of getting closer? This is an iterative issue; Karthik took one approach, I tried another averaging technique. |
#15
As someone who has participated in the planning and execution of customer surveys and clinics before, I'm just going to leave this here for future reference.
Likert Scale |
