Go to Post Hallry's back! Tell a Friend! - Tyler Olds [more]
Unread 16-05-2015, 00:51
rponmalai's Avatar
rponmalai rponmalai is offline
UCI
AKA: Ravi Ponmalai
FRC #3476 (Code Orange)
Rookie Year: 2012
rponmalai is a glorious beacon of lightrponmalai is a glorious beacon of lightrponmalai is a glorious beacon of lightrponmalai is a glorious beacon of lightrponmalai is a glorious beacon of lightrponmalai is a glorious beacon of light
pic: Offseason Gearbox
Unread 16-05-2015, 01:05
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Team Role: Mechanical
Rookie Year: 2013
Re: pic: Offseason Gearbox
Looks very clean.
I like the use of thunderhex and circlips to retain shafts and use round bearings, but for the amount of manufacturing this requires you may want to use 1/2" bearings and shafts with ends rounded. It's a pretty simple lathe job that IME is comparable to an e-clip slot.
You could probably get away with only 4 standoffs, but for mounting purposes you could keep it like it is I guess.
I noticed on the plates your radii are pretty variable, with a 0.04 radius in one of the plates. Depending on the machine, this could make it take considerably longer to machine than using a single larger radius throughout, as a larger endmill can take off more material in general in a certain amount of time.
Overally a pretty sweet gearbox.
It looks like it fits very well into the back of your WCD.
<Now accepting CAD requests and commissions>
Unread 16-05-2015, 01:15
R.C.'s Avatar
Happy Birthday! R.C. R.C. is online now
2017... Oooh Kill em, Swerve!
AKA: Owner, WestCoast Products
FRC #1323 (MadTown Robotics)
R.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond repute
Originally Posted by asid61 View Post
Looks very clean.
The better way to handle this is to use 3/8" Hex shaft and flip the bearing so the flanges are on the inside that way the bearing is geometrically retained.
Also if possible round down the shafts if possible so you can use a cheaper bearing etc...
R.C.
Owner, WestCoast Products || Twitter
MadTown Robotics Team 1323
Unread 16-05-2015, 02:43
MStump's Avatar
MStump MStump is offline
Mentor
AKA: Michael Stump
FRC #3309 (Friarbots)
Rookie Year: 2012
MStump is a splendid one to beholdMStump is a splendid one to beholdMStump is a splendid one to beholdMStump is a splendid one to beholdMStump is a splendid one to beholdMStump is a splendid one to beholdMStump is a splendid one to behold
I agree, using 3/8 with rounded ends is pretty nice, simple, and light. You can also use the smaller 7/8 OD bearings.
All in all it looks really clean and nice. I came up with a similar design at the beginning of the season to mount our gearbox at the back of the frame but it did not end up looking nearly this nice haha.
My suggestions for minor improvement:
1. Use the 3/8 shaft mentioned previously for the first stage reduction.
2. Take advantage of the upper bolt on the lower cim for a standoff instead of having another hole solely for a standoff.
3. I wasn't able to download the model but make sure you have straight access to all your bolts on your CIMs. It'll make maintenance a lot easier but I'm sure you already thought of that.
4. Add additional mounting holes and bolts so that it isn't completely resting on the output shaft. (There might be something I'm missing but I can't see where else it would directly mount to the frame.
5. Also just an idea to consider, having only one plate that is repeated on both sides of the gearbox saves some time cadding, machine programming, and machining. However, it also adds a little bit of weight. So if you have the time making two plates is probably better, but if you are in a rush it may be better to forgo the second plate.
Michael Stump
FRC Team 3309 Friarbots
Mentor 2015-Present
Student 2011-2015
Unread 16-05-2015, 01:20
mman1506's Avatar
mman1506 mman1506 is online now
Focusing on Combat Robots!
AKA: Marcus Quintilian
no team (WARP7)
Rookie Year: 2012
mman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond repute
I think your being a little picky. CAM software will try to cut the tightest radius it can with tool specified. You should be able to cut 90% of the lightening holes with a .25 end-mill and then finish things up with a 1/8 end-mill. All in all it should take 8-15 minutes a plate with decent end-mills.
2014-2015: FRC 865 Warp7 Team Captain
2016: FRC 865 Mentor
2017: Free Agent Mentor, Ref, Inspector
Unread 16-05-2015, 01:27
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
Rookie Year: 2013
Wait really? I was told I had to put all the radii in manually even for a CNC.
I've been lied to... lol.
Unread 16-05-2015, 02:05
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
You generally want to design the pocket radii some amount larger than the radius of the tool you intend to machine it with. This is to prevent the tool from encountering a sudden and peaking chip load when it gets into the tight corner. It needs some room to still move in the corner, so it isn't contacting all around at the same time.
Unread 16-05-2015, 02:20
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
Rookie Year: 2013
Can CAM do this for you or do you have to put in all the radii manually?
What size endmill would you normally use as a minimum for something like this?
Unread 16-05-2015, 03:03
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
FRC #0254 (The Cheesy Poofs)
You should just use the fillet tool in solidworks/inventor/whatever and add .010+ to the nominal radius when you create the fillets.
I dislike using anything less than 1/4" diameter in 1/4" plate. with 1/4" cutter diameter you can go full depth (with a reasonably rigid machine and good chip evacuation). 3/16" and smaller won't allow you to do that.
2001-2004: Team 100
2006-Present: Team 254
Unread 16-05-2015, 21:38
Dylan179's Avatar
Dylan179 Dylan179 is offline
FRC #0179 (Children of the Swamp)
Dylan179 has much to be proud ofDylan179 has much to be proud ofDylan179 has much to be proud ofDylan179 has much to be proud ofDylan179 has much to be proud ofDylan179 has much to be proud ofDylan179 has much to be proud ofDylan179 has much to be proud ofDylan179 has much to be proud of
Is the bering on the output shaft pushed out some?
Unread 17-05-2015, 01:34
rponmalai's Avatar
UCI
AKA: Ravi Ponmalai
Rookie Year: 2012
Yeah the flange is actually on the inside of the tubing and that gap is for the thickness of the tubing.
Unread 17-05-2015, 02:10
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
Rookie Year: 2013
How will you get it into the tubing?
Unread 17-05-2015, 02:12
Joey Milia's Avatar
Joey Milia Joey Milia is offline
FRC #0192 (GRT)
Rookie Year: 2011
Joey Milia is a splendid one to beholdJoey Milia is a splendid one to beholdJoey Milia is a splendid one to beholdJoey Milia is a splendid one to beholdJoey Milia is a splendid one to beholdJoey Milia is a splendid one to behold
And once you do how will you get it to stay in the wall of the tubing?
Unread 16-05-2015, 02:06
Cory's Avatar
AKA: Cory McBride
If you don't enter the radii you will end up with sharp corners in your toolpath or with finishing passes that take out huge chunks in the corner, not the (for example) .015" you may be running around the rest of the chain. You'll get a radius there, but it will be harder on your tool than desirable and will leave a poor surface finish.
It's always best to make your radii slightly larger than the cutter you intend to use, so that you can roll the cutter through the corners instead of coming in and making a sharp line entry/exit. We usually use .010-.015 more on the radius to help with this.
2001-2004: Team 100
