Go to Post Dear CNN, We're not from indiana. Love, Wildstang - AlecMataloni [more]
Unread 05-16-2015, 11:00 PM
tahmid0517's Avatar
tahmid0517 tahmid0517 is offline
AKA: Tahmid Sheikh
FRC #5036 (The Robo Devils)
Rookie Year: 2015
tahmid0517 is an unknown quantity at this point
Would this code work for kaj drive?
Hi, I'm new to programming and I wrote a piece of code that I don't have access to a robot right now to test on:
frontRight.set(stick1.getY() - stick2.getX());
backRight.set(stick1.getY() - stick2.getX());
frontLeft.set(stick1.getY()+ stick2.getX());
backLeft.set(stick1.getY()+ stick2.getX());
Assuming all the motor and joystick ports are declared correctly and this code is in the teleop periodic section, would this code work as a form of kaj drive where a robot's forward and backward motion is controlled with the left joystick and turning is controlled by the right joystick?
Unread 05-17-2015, 01:21 AM
BigJ BigJ is offline
AKA: Josh P.
FRC #1675 (Ultimate Protection Squad)
Rookie Year: 2007
BigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond repute
Re: Would this code work for kaj drive?
It "would" work - however if the expression inside set() goes above 1.0 it will be cut off. It is worth thinking about how that will affect your controls.
Unread 05-17-2015, 10:25 AM
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Rookie Year: 2013
The easiest way to scale to prevent set values outside of the -1 to 1 range would be to divide everything by 2. Unfortunately, this would reduce your maximum forward speed (and the others as well) by 50%.
It would also be cleaner to get the joystick numbers once rather than call the get() methods repeatedly.
A fairly general way to combine the numbers which allows full speed but prevents bounds errors on the set() methods could be:
Code:
fwd = stick1.getY();
rot = stick2.getX();
scale = Math.max(1.0, Math.abs(fwd) + Math.abs(rot);
frontRight.set((fwd - rot) / scale);
backRight.set((fwd - rot) / scale);
frontLeft.set((fwd + rot) / scale);
backLeft.set((fwd + rot) / scale);
Unread 05-17-2015, 02:19 PM
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
...or you could just use the arcade drive in the Java WPILib and provide the fwd/rev from the left Y; and the turning from the right X
