Go to Post note: spelling, punctuation and good grammar are your friends - use them and enjoy the benefits of legible, understandable prose - dlavery [more]
Unread 21-05-2015, 11:47
z_beeblebrox's Avatar
z_beeblebrox z_beeblebrox is offline
Custom User Title
AKA: Cal
FRC #4183 (Bit Buckets)
Rookie Year: 2012
z_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond repute
pic: Wood Coast Drive
Unread 21-05-2015, 11:48
rutzman rutzman is offline
AKA: Ryan
FRC #2614 (MARS)
rutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant future
Re: pic: Wood Coast Drive
I heard at World's that you were limited in the size of the pieces that you could cut by the size of your laser cutter. Can you handle larger pieces now, or is this more of a theoretical design?
Unread 21-05-2015, 12:33
Custom User Title
AKA: Cal
Rookie Year: 2012
All the pieces fit within our laser.
2012 Utah Regional Rookie All-Star
2013 Phoenix Regional Judge's Award for "design process and prototyping"
2014 Hub City Regional Quality Award, Arizona Regional Excellence in Engineering Award
2015 Arizona East Regional Creativity Award, Winner
2016 Arizona North Regional Finalist, Arizona West Excellence in Engineering Award, Finalist
Unread 21-05-2015, 14:20
AdamHeard's Avatar
Lead Mentor
FRC #0973 (Greybots)
I would remove all the diamond pocketing in the mock "rails". It cuts the fiber up so much, and it'd be hard to justify the weight it saves for the decrease in strength for a more traditional FRC game with contact.
Unread 21-05-2015, 17:48
Necroterra's Avatar
Necroterra Necroterra is offline
Rookie Year: 2015
Necroterra will become famous soon enough
Yeah, taking a second look at it, the belly pan definitely wouldn't survive a contact game. I think you could design the gearbox crossbrace to handle that though.
2015 Arizona East - Regional Winners, Creativity Award
Unread 21-05-2015, 18:08
Custom User Title
AKA: Cal
Rookie Year: 2012
That makes sense; will do. Edit: Removing the holes only cost ~.5lbs; not that big a deal, given how light the chassis is anyway.
The intent is to epoxy 1/8" plywood plates to the center of the belly pan, making it one piece. I'm planning on adding a brace between the gearboxes.
Unread 21-05-2015, 19:03
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Team Role: Mechanical
Rookie Year: 2013
Very cool. 31lbs with a 6-cim drive is very impressive, too.
<Now accepting CAD requests and commissions>
Unread 23-05-2015, 00:18
dtengineering's Avatar
dtengineering dtengineering is online now
Teaching Teachers to Teach Tech
AKA: Jason Brett
no team (British Columbia FRC teams)
dtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond repute
When you take a thin layer of fiberglass and epoxy it over wood the strength and stiffness goes off the chart... you'd have to figure out a way to fillet the corners a bit to allow the glass to flow smoothly over the edges.
Actually, once you got good at glassing you could replace the plywood with balsa and go for...
Oh, wait. You said this weighs 6.5 lbs? Yeah, I don't think the weight savings will be worth it. Wood is pretty amazing on it's own.
Jason
Unread 23-05-2015, 11:58
carpedav000's Avatar
carpedav000 carpedav000 is offline
Studenting is hard, but worth it!
AKA: David Carpenter
no team (Jerry-Rigg school of DuctTapeology)
Rookie Year: 2010
carpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant future
I'm new to the idea of wood construction, would it be worth it to replace the front and side panels with polycarbonate?
Unread 23-05-2015, 12:06
Scott Kozutsky's Avatar
Scott Kozutsky Scott Kozutsky is offline
FRC #0865
Rookie Year: 2010
Scott Kozutsky will become famous soon enough
The main advantages of wood (IMO) are that it's dirt cheap and can be laser cut very quickly and easily. Polycarbonate is neither.
2010-2012 FRC 865 Warp7 Student, Mechanical
2013 FRC 1310 RUNNYMEDE ROBOTICS Student, Mechanical, Design
2014 FRC 865 Warp7 Student, Mechanical, Design
2015 FRC 865 Warp7 Alumni, Mechanical Mentor
Unread 23-05-2015, 12:18
Rookie Year: 2010
While both are true, I saw that someone was concerned about cutting the fiber up too much. I don't necessarily understand what that is, so I was guessing that is was something to do with structural integrity. Polycarbonate is (IMO) much more suited to take impact than plywood is, hence me asking the question in the first place.
Unread 23-05-2015, 12:58
mman1506's Avatar
mman1506 mman1506 is offline
Focusing on Combat Robots!
AKA: Marcus Quintilian
no team (WARP7)
Rookie Year: 2012
mman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond repute
Polycarbonate cannot be cut on commercial laser cutter. It releases dangerous fumes when melted.
2014-2015: FRC 865 Warp7 Team Captain
2016: FRC 865 Mentor
2017: Free Agent Mentor, Inspector
Unread 23-05-2015, 15:03
Custom User Title
AKA: Cal
Rookie Year: 2012
Plywood's not bad at impacts; it's springy and returns to shape when metal dents. Until our safety captain forbade it, I demonstrated that by hitting our demo swerve module with a hammer. We also ran over our prototype drivetrain with a car, with only minor damage.
We also use wood since it's so fast to make; we get turnaround times less than half an hour on our laser, while we'd have to cut Lexan by hand.
Unread 23-05-2015, 23:11
Sperkowsky's Avatar
Sperkowsky Sperkowsky is offline
Professional Multitasker
AKA: Samuel Perkowsky
FRC #2869 (Regal Eagles)
Team Role: Leadership
Rookie Year: 2014
Sperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond repute
Originally Posted by EricH View Post
Ah. (Makes me wonder why acrylic is found with FRC teams--and their "unskilled" drillers--around, but that's beside the point.)
Now, for the impact resistance: polycarb vs birch. Polycarb deflects, birch absorbs. They're about the same, but I'm going to have to give that to the plywood on strength-to-weight ratio. The main issue with birch ply is that it absorbs by getting dented or, eventually, splintering. (Acrylic never even enters this discussion, as the "standard" test for identifying unknown clear plastic is to clamp firmly and hit with the biggest hammer in the area--if it doesn't break, use the polycarb, otherwise it was acrylic.)
Plywood loses to poly on strength to weight. Lexan is crazy strong. I stood on a freely Standing peice of 1/16 lexan and it just bent I stepped off bent right back into shape no problem. I can't say the same for a piece of 1/16 plywood.
  #15   Spotlight this post!
Unread 23-05-2015, 23:20
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Originally Posted by Sperkowsky View Post
Plywood loses to poly on strength to weight. ... 1/16 lexan ... 1/16 plywood.
FWIW: That's strength to volume, not weight.
