Go to Post Build a robot that isn't 119.999999 lbs - Peyton Yeung [more]
Unread 03-06-2015, 21:58
lemiant's Avatar
lemiant lemiant is offline
the Dreamer
AKA: Alex
FRC #4334 (Alberta Tech Alliance)
Team Role: Leadership
lemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond repute
Enable PWM outputs immediately on RoboRIO
I'm using a RoboRIO to build a summer project and I want to have code that starts running (and controlling PWM outputs) immediately on startup. How can I achieve that?
Or barring that, where can I look to learn more about the code execution path on a RoboRIO?
FRC Team 4334
2012 - Archimedes Champions, IRI Champions
2013 - Western Canadian Regional Winner, Galileo Quarter-Finalilst
Unread 03-06-2015, 22:06
Thad House Thad House is offline
Volunteer, WPILib Contributor
no team (Waiting for 2021)
Rookie Year: 2010
Thad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond repute
Re: Enable PWM outputs immediately on RoboRIO
It is possible to create a lightweight library that would start up quicker then the current WPILibs. However, the FPGA will always disable all outputs until it received enabled from the Driver Station. NI and WPI do not release the code to the FPGA, so the only way to bypass this would be to rewrite all of the FPGA code.
As for looking at the execution path, here is a mirror of the WPI Libraries. For Java, the entrance point is located in this class if you want to trace the execution path.
All statements made are my own and not the feelings of any of my affiliated teams.
Teams 1510 and 2898 - Student 2010-2012
Team 4488 - Mentor 2013-2016
Co-developer of RobotDotNet, a .NET port of the WPILib.
Unread 03-06-2015, 22:10
FRC libraries have integrated safety features, as you are probably aware.
Is that what you are asking about? Or are you asking something else?
Perhaps some additional info on what the project is and what the PWM is for will open up other suggestions to help.
Greg McKaskle
Unread 03-06-2015, 22:15
lemiant's Avatar
the Dreamer
AKA: Alex
Greg McKaskle
I am using it to interface a computer to motors and sensors in order to control an autonomous golf cart. The goal is to write a C++ ROS package which resides on the RoboRIO and immediately connects to the rosmaster over ethernet on startup, at which point it becomes a slave to the computer and receives sensor input / issues motor control commands.
FRC Team 4334
Unread 04-06-2015, 07:43
I sent a PM with a few options.
Greg McKaskle
