Go to Post we can crank up the volume and let the world know that we are nerds with a pulse! - dlavery [more]
Unread 04-06-2015, 23:05
bstew's Avatar
bstew bstew is online now
FRC #3928 (Team Neutrino)
Team Role: CAD
Rookie Year: 2015
bstew is a splendid one to beholdbstew is a splendid one to beholdbstew is a splendid one to beholdbstew is a splendid one to beholdbstew is a splendid one to beholdbstew is a splendid one to beholdbstew is a splendid one to behold
pic: LEGO Coaxial Swerve Module
Unread 04-06-2015, 23:14
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Team Role: Mechanical
Rookie Year: 2013
Re: pic: LEGO Coaxial Swerve Module
Originally Posted by bstew View Post
I love it, espcially the turntable to turn the module! LEGO swerves are cool.
I recommend tetrix (?) chain. Using gears to do it would be awkward looking IMO.
<Now accepting CAD requests and commissions>
Jarren Harkema's Avatar
Jarren Harkema Jarren Harkema is offline
Dancing Drive Coach
FRC #4967 (That ONE Team)
Rookie Year: 2013
Jarren Harkema is a name known to allJarren Harkema is a name known to allJarren Harkema is a name known to allJarren Harkema is a name known to allJarren Harkema is a name known to allJarren Harkema is a name known to all
I have worked a lot with LEGO technic construction, even tried my hand at this a couple of times. 24t gears between turntables was promising. You will be putting way to much stress on chains. The key for all of this is to support the gears as best as possible. Your module is nice and compact. The only recommendation I would have is replace the 3-long axel on that 12t with something to run the full length between the two 3x5 liftarms. This will keep the 12t from skipping with the 20t, attached to the wheel, as well as prevent the driving gear from falling off its axel.
Unread 05-06-2015, 00:05
Gregor's Avatar
Gregor Gregor is offline
#StickToTheStratisQuo
AKA: Gregor Browning
Rookie Year: 2012
Gregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond repute
How much does it weigh?
What are nationals? Sounds like a fun American party, can we Canadians come?
“For me, insanity is super sanity. The normal is psychotic. Normal means lack of imagination, lack of creativity.” -Jean Dubuffet
"Insanity is doing the same thing over and over again and expecting different results." -Albert Einstein
FLL 2011-2015 Glen Ames Robotics-Student, Mentor
FRC 2012-2013 Team 907-Scouting Lead, Strategy Lead, Human Player, Driver
FRC 2014-2015 Team 1310-Mechanical, Electrical, Drive Captain
FRC 2011-xxxx Volunteer
How I came to be a FIRSTer
<Since 2011
Unread 05-06-2015, 03:06
Mike Marandola Mike Marandola is online now
Lead Bumper Mentor
AKA: Mike Marandola
FRC #0316 (Lunatecs)
Mike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond repute
I think you got carried away with the pocketing.
2015 - Pioneer Valley District Finalists/Upper Darby District Finalists/MAR District Championship #1 Seed and Winners with 225 and 203
2014 - Lenape Seneca District Winners/Chestnut Hill District Winners
2013 - Lenape Seneca District Winners/Chestnut Hill District Finalists
2011 - Philadelphia Regional Finalists
2009 - Finger Lakes Regional Finalists
Unread 05-06-2015, 07:47
Richard Wallace's Avatar
Richard Wallace Richard Wallace is offline
I live for the details.
FRC #3620 (Average Joes)
Rookie Year: 1996
Ok, this is pretty cool. Thank you for posting it.
What supports the drive shaft? Is there something to limit upward travel of the drive gear? The rest of your design is easier to see in this render.
Richard Wallace
since 2003
Unread 05-06-2015, 09:03
bstew's Avatar
Team Role: CAD
Rookie Year: 2015
Thanks for all of your helpful replies!
I have a question of my own regarding the TETRIX chain as I have never worked with it. Is it compatible using the LEGO gears as sprockets? I have a good amount of LEGO chain, but it tends to fail quite easily.
If I can't use chain, I have a design that connects all of the modules together with 40 tooth gears. It seems to work well, but I haven't tested it with all four modules because I only have one module until my order of parts arrives.
In the image, some parts are a bit hard to see from this angle, so I can clarify them. The reason the 12 tooth gear is on a 3m axle is because if I extend it across between the liftarms, it rubs on the tire. The way it is now is the best solution I could come up with. And yes, the vertical drive shaft is supported by the black piece that you can barely see right below the turntable. The drive gear cannot move upward because of it.
As for weight, the module weighs about an eighth of a pound, probably one of the lightests swerve designs ever.
I might be able to get a another render at a different angle so that the underside of the turntable can be seen better.
Unread 05-06-2015, 12:10
Dancing Drive Coach
Rookie Year: 2013
Did you try it physically? I didn't have issues with a long axel.
Unread 06-06-2015, 09:25
philso philso is offline
Mentor
FRC #2587
Rookie Year: 2011
philso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond repute
This is cool and so elegantly compact. The one Steve made is cool too.
The 12-tooth gear may end up adequately constrained (for the forces involved) by the gear below it and the one above it, laying horizontally. Those 3x5 L-shaped liftarms are pretty stiff so the gears might not skip.
Did you want to use the chain or 40-tooth gears for turning the modules, for powering the drive wheels or for both? Have you considered using long axles and the knob-gears Calvin referred to? The axles aren't that great at resisting torque but then you get gear lash with a large number of gears.
For "Smart Move", one of the local whizz kids and his partner attempted to build a second robot with swerve/crab drive for the Championship in February, after the Qualfier in November. I think their school ran out of parts and they could not manage to get the software going (no mentors on his FLL team). They did end up winning Third Place in Robot Performance using a robot they started building less than 24 hours before the Championship.
Unread 05-06-2015, 09:17
faust1706's Avatar
faust1706 faust1706 is offline
FRC #1706 (Ratchet Rockers)
Rookie Year: 2011
faust1706 is infamous around these partsfaust1706 is infamous around these parts
Asking the real questions here.
This is a really cool adaption to a complex concept, well done!
"You're a gentleman," they used to say to him. "You shouldn't have gone murdering people with a hatchet; that's no occupation for a gentleman."
Unread 05-06-2015, 10:36
notmattlythgoe's Avatar
notmattlythgoe notmattlythgoe is offline
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
notmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond repute
We're looking at working on some swerve this summer and we might have to build this to play around with control concepts. Awesome job.
Unread 05-06-2015, 10:55
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
This is definitely cool, but I think in order to survive the obstacles from (e.g.) my childhood bedroom you'll probably want 3 pods rather than 4, and maybe some bigger wheels
LEGOs + one of those electric race car tracks (even the simple figure 8) FTW.
Unread 06-06-2015, 02:47
Nato Nato is offline
FRC #3476 (Code Orange) #5810 (X-Bots)
Rookie Year: 2010
Nato is a glorious beacon of lightNato is a glorious beacon of lightNato is a glorious beacon of lightNato is a glorious beacon of lightNato is a glorious beacon of light
Chain is definitely not impossible. If you are going to go the chain route I would probably put a reduction in the modules themselves in order to take stress of the chain. Personally I would just go with gears, and I would certainly run the center axle through the whole module, as others have suggested. Particularly with the 1/2 stud offset, you are going to be slipping gears extremely easily.
To the OP: Search for "synchro drive" in the website I linked and you'll find tons of examples by people who have done very similar things for years now.
And because you are going crab, as an extra challenge, make it drive and steer with one motor total (doesn't have to be at the same time). Yes, it is possible.
Unread 05-06-2015, 13:51
s_forbes's Avatar
s_forbes s_forbes is online now
anonymous internet person
FRC #0842 (Falcon Robotics)
s_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond repute
Definitely want the axle for the idler gear to go across, otherwise it will shake loose / skip teeth / add friction. If you have clearance issues, a different wheel could be used. Lego parts 3482 (wheel) and 3483 (tire) clear the axle with that gear spacing.
More wheels: http://isodomos.com/Visual-Parts-Helper/Lego-Wheel.html
Here's a tiny LEGO swerve drive I made ages ago, using the differential gear piece as the swerve body and bearing. It drove around fine, but in the end they're still tiny plastic parts and can't handle a lot of load.
http://www.chiefdelphi.com/media/photos/28935
http://www.chiefdelphi.com/media/photos/28936
  #15   Spotlight this post!
Unread 05-06-2015, 14:10
Calvin Hartley's Avatar
Calvin Hartley Calvin Hartley is offline
Rookie Year: 2012
Calvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud of
I haven't tried one of these in years, perhaps it would be worth another go.
Perhaps try using the 4-knob gears? They keep a strong connection if you brace them well enough, though you won't get the same ratio, of course.
FRC 4967 That ONE Team 2013-Present, Founder, CAD/Everything Mentor
FRC 2771 Code Red Robotics 2012 and 2013 Drive Team, 2014 Drive Coach, Executive Leadership
FLL Team member 2005-2010, LEGO In Paradise,
FLL Mentor 2009-Present Paradise Teams (nine teams)
FLL Coach 2014-Present - The Lightning Bugs
Gracious Professionalism isn't a set of rules to follow, it's an attitude.
