Go to Post It is the team that they build that is the important accompliishment.. - Wayne C. [more]
  #16   Spotlight this post!
Unread 16-06-2015, 08:37
Kevin Leonard Kevin Leonard is offline
Professional Stat Padder
FRC #5254 (HYPE), FRC #20 (The Rocketeers)
Rookie Year: 2011
Kevin Leonard has a reputation beyond reputeKevin Leonard has a reputation beyond reputeKevin Leonard has a reputation beyond reputeKevin Leonard has a reputation beyond reputeKevin Leonard has a reputation beyond reputeKevin Leonard has a reputation beyond reputeKevin Leonard has a reputation beyond reputeKevin Leonard has a reputation beyond reputeKevin Leonard has a reputation beyond reputeKevin Leonard has a reputation beyond reputeKevin Leonard has a reputation beyond repute
Re: Cycloidal Gearboxes, a game changer?
Originally Posted by BBray_T1296 View Post
I just drew up and 3d printed a 6.66:1 one for a CIM, and it works like a charm. I can put enough torque on it I am worried the solid PLA will break and cannot backdrive it. With the drawing I was happy with, by swapping out 2 small parts I could easily change it to 5:1, 10.5:1, or 22:1. it is also super compact, being only 2x2x0.9", it is comparable in size to a versa-planetary and if made from alum/steel could easily handle more force*.
Another interesting point about this transmission is while the output is coaxial the input, they are counter-rotating
*Planetary gearboxes generally fail under load when teeth shear off inside. All failure points inside this gearbox are much thicker than the tiny gears we generally see and in theory would handle more force before shearing
Can you post a picture of this? And perhaps a video of it handling decent amounts of torque?
I'm very curious about how this 3d printed version holds up. If that can handle certain loads, there's no reason a metal equivalent wouldn't work fantastic.
All of my posts are my opinion only and do not reflect the views of my associated teams.
College Student Mentor on Team 5254, HYPE - Helping Youth Pursue Excellence
(2015-Present)
Alumni of Team 20, The Rocketeers (2011-2014)
I'm attempting a robotics blog. Check it out at RocketHypeRobotics.wordpress.com Updated 10/26/16
  #17   Spotlight this post!
Unread 03-07-2015, 18:03
tafipapi's Avatar
tafipapi tafipapi is offline
FRC #4403
tafipapi is an unknown quantity at this point
I just drew up and 3d printed a 6.66:1 one for a CIM, and it works like a charm. I can put enough torque on it I am worried the solid PLA will break and cannot backdrive it. With the drawing I was happy with, by swapping out 2 small parts I could easily change it to 5:1, 10.5:1, or 22:1. it is also super compact, being only 2x2x0.9", it is comparable in size to a versa-planetary and if made from alum/steel could easily handle more force*.g
Did you use the hypocycloidal ecuation to draw the profile of the gear??
I just designed one using tangent semicircles and im planning to build it, but im concerned that this characteristic may not contribute to the non-backdrivable feature.
  #18   Spotlight this post!
Unread 03-07-2015, 18:58
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Team Role: Mechanical
Rookie Year: 2013
The zip file here: http://www.chiefdelphi.com/forums/sh...47&postcount=7
Has SolidWorks parts and equations and stuff to generate the correct cycloidal profile/ make a cycloidal gear. Semicircles may not work properly.
<Now accepting CAD requests and commissions>
