pic: Why aren't omni wheels like this used?
Re: pic: Why aren't omni wheels like this used?
Do you mean with larger rollers? Because AndyMark recently came out with the Duraomni wheels.
I think he means having bigger and smaller rollers that roll more or less inside each other, thus creating an omniwheel without any "bounce"
The only bounce I can think of is with single omni wheels, as you transfer weight from one roller to the next. Even then, the gaps are small enough that you should never significantly lose traction on carpet or similar surfaces. Duallies smooth right through this. The AndyMark DuraOmni (which only has four rollers for each half), is only available as a dualie. |
From the picture, it looks like the frame actually sticks inside the large roller in order to support the end of the small one - in other words, the ends of the large rollers are completely hollow. Make the rollers out of a hard plastic, and I can't see them being easily replaceable should a roller break. Make them out of anything softer/more flexible to let them be easily replaceable, and I don't think they'll stand up to our uses.
The more traditional Omni wheels, on the other hand, do have replaceable rollers - we have 2 pairs of omni's from 2007 that are still running today, although we've replaced the rollers on them a couple of times (a very straightforward process). |
It appears that not everyone knows what an omni wheel like this is, so I will explain.
It has 12 rollers. 6 are 0.375" in diameter, the other 6 are 0.75". They form a nearly continuous 4" circle. Since some seem unfamiliar with the design, as I was until recently, I'll give some possible pros and cons that haven't been mentioned to get started. Pros: Smoother rolling lighter smaller Less vibration? Cons: Difficult to manufacture? difficult to assemble and change rollers less load capacity? fragile? Question marks expectedly denote things I'm not sure about. |
This style omni wheel would be a more challenging to manufacture and assemble, as the outer rollers cover the inner rollers, this is most likely why we do not see them in production currently. As most current omni-wheels are injection molded plastic, the process for molding a wheel of this shape becomes significantly more challenging, due to the angles you see in all of the pins.
A normal injection molding process of a simple part features a 2-part mold. This requires that all faces of the part can be directly accessed by the two faces of the mold. To mold a wheel like this, you would need several extra moving parts in the mold, thus driving up cost. Also, due to the shape of the wheel, each roller is, in a sense, cantilevered from the main hub. If you think about the shape of the hub (without the rollers) there is a lot of pressure riding on very little material. Benefits, however could be a smoother ride when you do not have to deal with the gaps in the standard style omni wheels. In addition, you could achieve a dualie-effect without the space taken up by having 2 wheels side-by-side. For the sake of cost and simplicity is why I believe that we do not see designs like these already in the FRC market. |
That is an interesting design. I would be interested in it, if 1 wheel can support 100 pounds, as having one smooth rolling wheel would likely save space and weight.
Is this out on the market or a design idea? If I were going to build this, I would give the shorter roller twice the diameter so there is room for the axle. This roller could also have a bow-tie look from the side to reduce the gap with the longer roller. D |
The DuraOmni wheel rollers are designed with a 4" wheel in mind. It is smooth rolling and the overlapping rollers create a true 4" diameter circle when viewed concentric to it's center bore. The rollers on AndyMark older omni wheel offerings such as the 4" Dualie Plastic Omni Wheel were originally designed for an 8" wheel, and were used on other wheels to save costs. They do roll fairly well in 'dualie' setups, but are not as smooth rolling as a DuraOmni. I've attached a photo comparison of both.
http://i.imgur.com/UehYLgD.jpg Another reason why omni wheels like the one you posted aren't used in FRC is due to the requirement of more than one mold for the rollers. Molds are expensive, and many FRC teams are looking for high quality inexpensive components for their robots. - Nick |
#10
Can someone post attachments or links to - assembly pictures - assembly videos - IPB - CAD rendering of parts |
#11
http://www.andymark.com/product-p/am-3048.htm I believe other omni wheels use flanged bronze bushings. -Adrian |
