Go to Post So perhaps those that are so eager to complain might realize that if they spent a little less time complaining and a little more time analyzing the problem and developing solutions, then they might have a little less to complain about. - dlavery [more]
Unread 12-06-2015, 18:09
DavidGitz's Avatar
DavidGitz DavidGitz is offline
Lead Technical Advisor
FRC #1208 (MeTool Brigade)
Team Role: Coach
Rookie Year: 1996
DavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud of
Send a message via AIM to DavidGitz Send a message via MSN to DavidGitz Send a message via Yahoo to DavidGitz
Power Switch
NOTE: This is for a non-FRC application.
I have a robot that I would like to power from a Battery (3S LiPo with a Traxxas Female Connector) or a Power Supply (12V with a Traxxas Female Connector). Among the electronics on the robot is a linux board that would not do very well with removing power without a proper shutdown process. While in development the robot would be powered off the power supply, and when testing would run off the battery. So switching between the two would be common. I don't want to run the power supply and battery in parallel as that would not have very good consequences, so I'm looking for some type of power switch that can switch between either the power supply or the battery but acts as a "make before break", so power is never interrupted to the rest of the robot.
Does anyone have any recommendations for a switch like this? The cost ideally would be around $20-$30, the robot sees at most 30A @ 12V and can't be too big, maybe an inch or two. Here are some reference pictures: https://github.com/dgitz/icarus_rover/wiki
