Go to Post You can be extra safe or you can be competative - its your choice. - Raul [more]
Go Back   Chief Delphi > Other > Math and Science
Unread 19-06-2015, 20:54
Richard Wallace's Avatar
Richard Wallace Richard Wallace is offline
I live for the details.
FRC #3620 (Average Joes)
Rookie Year: 1996
Re: bending a new hook on a spring
Originally Posted by Ether View Post
I assumed the other spring is for a washer with a lighter (smaller) or heavier (larger) tub.
This is correct. However, the question is a very good one.
The washers that used these springs have not been produced for several years now. The older washer design had several variations, using at least a dozen different motors of varying speed and power ratings. Because the range of weights of those motors, different suspension spring forces were required.
More recent washer designs (since ~2010) use smaller, more efficient motors, and their suspension systems are completely different. They also hold more laundry, and consume less water and energy, compared to the older designs.
Originally Posted by gblake View Post
On the other hand, that ductility might mean that the metal you bend won't stay bent.
Having used these springs in several experimental situations, and bent their straight segments into various configurations, I can confirm that this is also correct.
Richard Wallace
since 2003
Unread 19-06-2015, 20:31
gblake's Avatar
gblake gblake is offline
6th Gear Developer; Mentor
AKA: Blake Ross
no team (6th Gear)
gblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond repute
Originally Posted by FrankJ View Post
The trick will be bending it. The straight portion has not been plastically deformed so it should have all of its ductility left. Putting the same radius bend as the original hook shouldn't break it.
Blake Ross, For emailing me, in the verizon.net domain, I am blake
VRC Team Mentor, FTC volunteer, 5th Gear Developer, Husband, Father, Triangle Fraternity Alumnus (ky 76), U Ky BSEE, Tau Beta Pi, Eta Kappa Nu, Kentucky Colonel
Words/phrases I avoid: basis, mitigate, leveraging, transitioning, impact (instead of affect/effect), facilitate, programmatic, problematic, issue (instead of problem), latency (instead of delay), dependency (instead of prerequisite), connectivity, usage & utilize (instead of use), downed, functionality, functional, power on, descore, alumni (instead of alumnus/alumna), the enterprise, methodology, nomenclature, form factor (instead of size or shape), competency, modality, provided(with), provision(ing), irregardless/irrespective, signage, colorized, pulsating, ideate
