Go to Post Yippee! Someone else that can have their every word over-analyzed, mis-read, inverted, converted, perverted, misinterpreted, reverted, and garbled besides just me! - dlavery [more]
Unread 20-06-2015, 17:18
MikLast's Avatar
MikLast MikLast is offline
CAO/Drive Coach
AKA: Mikal Dieatrick
FRC #4513 (Circuit Breakers)
Team Role: Leadership
Rookie Year: 2014
MikLast is a splendid one to beholdMikLast is a splendid one to beholdMikLast is a splendid one to beholdMikLast is a splendid one to beholdMikLast is a splendid one to beholdMikLast is a splendid one to behold
Best wheels for football field?
We finished our first show bot (a T-Shirt cannon) and proudly showed it off at founders day today. After the parade, we were asked if we could shoot T-shirts during football games next year, and agreed to give us at least $500 for everything we needed to make sure it would work in the grass. $300 is going to T-shirts, while the rest is going to getting wheels and anything else we need to keep the bot going while on the field.
This brings up my question. We are using the 6" KOP wheels, but we rather not use those as we are afraid that they will wear too fast. One wheel we have looked at is the 8" pneumatic wheels from andymark, along with the plaction and the rubber treaded wheels. From looking in past threads many have said to go with the pneumatic wheels, but most threads were a couple years old and i wanted a more recent opinion.
Which wheels should we go for, and why?
Check out the FRC Discord!
2014: programmer, scout
2015: programmer, admin, drive team
Innovation in control award, WVHS district event
Innovation in control award, CWU district event
finalist, PNW district championship
2016: CAO, Drive team.
Excellence In Engineering awad, WVHS District event
Unread 20-06-2015, 17:26
SJaladi's Avatar
SJaladi SJaladi is offline
Mechanical Mentor
AKA: Sarath Jaladi
FRC #1923 (The MidKnight Inventors)
Rookie Year: 2013
SJaladi has a reputation beyond reputeSJaladi has a reputation beyond reputeSJaladi has a reputation beyond reputeSJaladi has a reputation beyond reputeSJaladi has a reputation beyond reputeSJaladi has a reputation beyond reputeSJaladi has a reputation beyond reputeSJaladi has a reputation beyond reputeSJaladi has a reputation beyond reputeSJaladi has a reputation beyond reputeSJaladi has a reputation beyond repute
Re: Best wheels for football field?
While I've never actually driven a T-Shirt Cannon robot on a Football field, my past experience with pneumatic wheels vs. other common FRC wheels tells me that pneumatic wheels are probably the way to go for driving on turf/grass. The one thing you will want to watch out for though is that if your center drop (I'm assuming you're running at least 6 wheels, in the standard tank configuration) is too small then the deformation of the pneumatic wheels under the weight of the robot will cause all the wheels to touch the ground and cause increased turning scrub. Therefore you may have to play around with finding the right pressure to inflate the wheels to and the right amount of center drop.
Unread 20-06-2015, 17:35
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
It is possible to vary the pressure by individual wheel to exaggerate the drop, too.
Incidentally, some 6" McMaster pneumatic casters with custom hubs could be used--I haven't seen them much lately on FRC fields, but there are some that were routinely modified to be run in an FRC drivetrain. If you have some machining options available, you might find that to be a good way to go, as you can swap in your current wheels if you aren't running on the football field.
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 20-06-2015, 17:41
evanperryg's Avatar
evanperryg evanperryg is offline
IT'S THE BUMP N' DUMP
AKA: Evan Grove
FRC #4536 (The Minutebots)
Rookie Year: 2011
evanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond repute
We're working on a t-shirt cannon as well! In the past, we've run robots with 6" traction wheels on football fields with no problem.
FRCDesigns Contributor | "There is only one corner of the universe you can be certain of improving, and that's your own self." -Aldous Huxley
2012-2016 | FRC Team 2338: Gear it Forward
2013
Wisconsin Regional Winner 2014 Midwest Regional Finalist 2015 Midwest Regional Chairman's Award, Finalist, Archimedes Division Champion, IRI Semifinalist 2016 Midwest Regional Chairman's Award, Finalist, Archimedes Division Gracious Professionalism Award, R2OC Winner
2015 | FTC Team 10266: Mach Speed
2015
Highland Park Qualifier Winner, Motivate Award
2017-???? | FRC Team 4536: The Minutebots
Thanks to the alliances and friends I've made along the way: 33 74 107 111 167 171 234 548 1023 1089 1323 1625 1675 1732 1756 2064 2077 2122 2202 2358 2451 2512 2826 3936 3996 4039 4085 4241 5006 5401 5568 5847 5934
Unread 20-06-2015, 17:42
MikLast's Avatar
CAO/Drive Coach
Rookie Year: 2014
(I'm assuming you're running at least 6 wheels, in the standard tank configuration) .
We are actually running a 4 wheel standard tank, i am guessing that might make a difference.
Unread 20-06-2015, 17:54
EricH's Avatar
New year, new team
FRC #1197 (Torbots)
What's the wheelbase and track width? That's what would really make the difference, in terms of turning a 4WD tank.
Wheelbase: front axle to back axle (actually wheel point of contact with ground, but axle is usually close enough)
Track width: distance from left wheel to right wheel
If the wheelbase/trackwidth number is near 1, you're probably OK. If the wheelbase/trackwidth is significantly <1, no trouble at all (though I would consider adding a wheelie bar). If it's significantly >1, you will not want high-traction pneumatics on all 4 wheels, and may want to put some Colsons or slick-ish wheels on one end or on diagonal corners. Speaking of Colsons... that's another option to think about; I happen to know that they'll work in some fairly non-typical-FRC applications and keep coming back for more.
Past teams:
Unread 20-06-2015, 18:14
MikLast's Avatar
CAO/Drive Coach
Rookie Year: 2014
i will not have this for a few days, until then what else can you recommend?
Unread 20-06-2015, 18:28
EricH's Avatar
New year, new team
FRC #1197 (Torbots)
Not much--I haven't done much robot driving on anything but carpet. That being said, I've been on a team that built one to handle a very dusty surface.
Though... I would suggest checking ground clearance. You won't need much, but you'll need more than in FRC...
Past teams:
Unread 20-06-2015, 20:37
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Rookie Year: 2013
We use pneumatic wheels for our t-shirt cannon. Our chassis is AM 31" nanotube (27.5" wheelbase, 6 wheel, with 1/8" drop) using Harbor Freight pneumatic wheels with the bearings removed and replaced with bushings for keyed shafts. Don't do this! The scrub is pretty bad, as we can't get the bushings in tight enough to get rid of the wobble. We're upgrading to AM pneumatic wheels and hubs this summer. Between the more solid hubs and slightly underpressuring the corner wheels, we figure we can make a much more nimble robot. Time will tell; if this doesn't do it, we may have to modify the center axle to lower it a bit more or replace the nanotube frame.
As far as pneumatic wheels, I definitely recommend them over solids; much less likely to tear up grass and race track surfaces due to the larger area of coverage.
Unread 20-06-2015, 21:09
fargus111111111's Avatar
fargus111111111 fargus111111111 is online now
AKA: Tim W
FRC #0343 (Metal in Motion)
Rookie Year: 2010
fargus111111111 is on a distinguished road
Our t-shirt shooter, seen here, http://www.chiefdelphi.com/media/photos/31867, is several years old but we are still running all the original wheels but one. They are solid, but wide and have a lot of rubber on them. After a recent upgrade to a four cim drive it runs with almost no problems on grass, pavement, and all floors.
Edit: I think they are old from am, but I'm not sure.
Unread 22-06-2015, 17:10
MoistRobot's Avatar
MoistRobot MoistRobot is offline
AKA: Jon Charboneau
FRC #0832 (OSCAR)
Rookie Year: 2007
MoistRobot is a glorious beacon of lightMoistRobot is a glorious beacon of lightMoistRobot is a glorious beacon of lightMoistRobot is a glorious beacon of lightMoistRobot is a glorious beacon of light
832 uses 2 powered pneumatic wheels and 2 casters on their t-shirt cannon. No scrub, but going straight can be iffy at times. It's been working well for years.
Unread 23-06-2015, 15:48
SJaladi's Avatar
Mechanical Mentor
AKA: Sarath Jaladi
Rookie Year: 2013
One thing you can do is try these 6in wheels from AndyMark
They should bolt right onto your existing setup and if I recall correctly from when I was playing around with one of these, they are cast with a relatively hard urethane rubber and should wear very slowly. Also I believe they are fairly slippery so if you don't have any problems with your current drive setup in terms of turning scrub, these should sub in really nicely for driving on pretty much any surface. The only place that pneumatic wheels would give you a significant advantage is on uneven surfaces where the wheels will absorb some of the shock load. If possible you may want to test both wheels or some combination of them on a variety of potential surfaces to find the best combination.
Unread 23-06-2015, 16:27
BariSaxGuy's Avatar
BariSaxGuy BariSaxGuy is offline
FRC #5013 (Trobots)
Rookie Year: 2013
BariSaxGuy is an unknown quantity at this point
This year, our t-shirt cannon runs on tank tracks from BrecoFlex. We got the idea from team 1619's design
Unread 23-06-2015, 18:18
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
FrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond repute
We use pneumatic scooter wheels in the front, casters in the back, 4 CIM tank drive geared for a fast walk, around 10 ft/s. The casters give you zero scrub. Makes turning in grass easier. It is also non marking on the basketball court. Our previous chassis was our 4 wheel narrow from breakaway.
If you don't know what you should hook up then you should read a data sheet
