Go to Post a good team can do almost anything - Wayne C. [more]
Thread Tools Rating: Thread Rating: 4 votes, 5.00 average. Display Modes
Unread 23-06-2015, 22:19
Delphine's Avatar
Delphine Delphine is offline
FRC #0948 (Newport Robotics Group)
Team Role: Electrical
Rookie Year: 2014
Delphine is an unknown quantity at this point
Off season Projects
Did your team do any off season projects using electrical components or pneumatics? Our team is looking for some fun/good learning experience type projects using electrical components and pneumatics to help everyone be better prepared for build season, and I'd love to hear what other teams have done
Unread 23-06-2015, 22:46
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Rookie Year: 2013
Re: Off season Projects
Our big off-season project this year is a game designed to encourage development of sensors, active pickups, and autonomous code. The rules are being posted on this thread. This project is being done one essentially alternate Saturdays through about November.
On Monday evenings, we're doing "small projects", one of which includes creating a pneumatic system using the 2015 control system. Our 2015 robot was so simple (literally four CIMs on separate gearboxes) that we did not use any pneumatics; it was our first all-electric year. Other small projects include an "infinite possibilities" pit display (an infinity-shaped roller chain executed in PVC, driven by window motors), some experimentation into how the coefficient of friction of rubber on carpet depends on the normal force, and some upgrades to our air-powered t-shirt launcher.
We're also planning some business side projects; my understanding is that they will get their own time slot (possibly Thursday evenings).
MikLast's Avatar
MikLast MikLast is offline
CAO/Drive Coach
AKA: Mikal Dieatrick
FRC #4513 (Circuit Breakers)
Team Role: Leadership
Rookie Year: 2014
MikLast is a name known to allMikLast is a name known to allMikLast is a name known to allMikLast is a name known to allMikLast is a name known to allMikLast is a name known to all
Our first T-shirt cannon was made with penumatics, and we had a ton of fun showing it off last weekend at the Founders day parade, great way to tart off learning about that if you wanted to.
Check out the FRC Discord!
2014: programmer, scout
2015: programmer, admin, drive team
Innovation in control award, WVHS district event
Innovation in control award, CWU district event
finalist, PNW district championship
2016: CAO, Drive team.
Excellence In Engineering awad, WVHS District event
Unread 25-06-2015, 15:36
DrewMatic's Avatar
DrewMatic DrewMatic is offline
Djibouti
AKA: Drew T
FRC #0240 (T.E.M.P.E.S.T)
Rookie Year: 2014
DrewMatic is an unknown quantity at this point
By any chance could you post a picture so I could see your t shirt cannon?
Projects we have completed demonstrate what we know, but future projects decide what we learn.
Unread 27-06-2015, 19:52
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
Rookie Year: 2013
The "early season" version of 3946's air cannon was written up by my daughter Veronica with video on the school newspaper. The guy who was shooting video was not part of the team; he focused more on crowd response than the launcher. The only clear shot of the launcher 'bot is about 1:25 when I'm manually turning it. The 3946 team on the field that evening also includes Matt Marton (our student mentorship award winner for 2015), Jesse Hobson (head coach), and Veronica Michel (author of the article).
When we had a break in home games for several weeks, we did a complete rebuild. The new version is narrower (meaning we can roll it through a door, rather than having to take the barrels off and carry it through sideways), lighter, has shorter, wider, white barrels, and features a rain shield for the electronics made from a rubbermaid tote. We don't have to manually turn the narrower robot as I did the wider one. Note that even on the early robot there is no PVC before the valves, but a painted black iron tank and galvanized pipe. PVC is not rated to handle air pressure: because it breaks rather than tearing (steel tears), it generates way too much shrapnel when it fails. The rebuild this summer will feature better wheels (so it is really a drop center drivetrain), RC steering of the barrel, range control through solenoid timing, a sound system, confetti cannons, programmable LED lighting, and we'll probably also replace the PVC barrels with metal, though even our professional pneumatics guy doesn't sweat an "open" PVC pipe carrying pressure.
Oh, yes - the pressurized air is from a scuba tank, regulated down to about 40-50 psi for storage in the black iron tank. We have 1" pipes from the black iron tank to the solenoid valves, which are 3/4" diameter. Our current system opens the solenoid for a constant 50ms. 60 psi, a 50ms solenoid time, and an orientation due west can toss a t-shirt from the running track over the top of our press box and onto Ninth Street.
We came up with a simple t-shirt roll to load the launcher:
  1. Lay the t-shirt flat
  2. Lift the lower hem until the fold reaches the armpit.
  3. place the next fold even with the "shoulder seams"
  4. "accordion fold" until you run out of shirt
  5. Fold the left sleeve over the accordion folded bodice
  6. Roll from the left side until you are about halfway down the right sleeve
  7. Flip the end of the right sleeve around the cylinder (much like rolling socks)
  8. Load the resulting cylinder in the air cannon!
The new 3" barrel works just right for size large heavy weight (e.g. Gildan or FOTL) shirts. For larger or thicker shirts, make a longer cylinder. For smaller or thinner shirts, make shorter "accordion folds" to get the appropriate diameter.
Unread 27-06-2015, 23:48
MikLast's Avatar
CAO/Drive Coach
Rookie Year: 2014
I will see what i can get, i cant get anywhere near the bot until august.
